Looking for part number, cat. hanger bracket
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmndr brain, Apr 14, 2017.
  1. Apr 14, 2017 at 8:02 PM
    cmndr brain
    cmndr brain [OP] Member
    I recently changed my rear catalytic converter on my 2001 Tacoma V6 3.4L. The metal hanger bracket that connects the cat. to the rubber support rings on the old was almost rusted through. I would like to replace it. Does anyone know the part number for a catalytic converter hanger bracket? (Circled in the only image I could find with that part). Thank you in advance.2011-09-18_231609_pic.jpg
  2. Apr 14, 2017 at 10:06 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it's part of the piece that the cat is on, welded on to be exact.
  3. Apr 15, 2017 at 7:19 AM
    cmndr brain
    Thank you for the reply but, mine was not welded on. It was put on with some kind of push rivets or something. I was able to get the old one off by drilling out the rivets. There is a welded piece for this part to attach to on the old and the new cat has that welded piece. It's a circular bent tube that attaches to the welded piece on the cat. and then connects to the rubber support rings. I just used some bolts, but the actual hanger bracket is very thin at the bolt holes due to rust. In the attached pic, the blue arrow points to the welded piece on the cat and the red arrows point to the bracket I would like to replace. Again, thank you.catbracket.jpg
  4. Apr 15, 2017 at 7:32 AM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
  5. Apr 15, 2017 at 8:38 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think Walker Has that as well
  6. Apr 15, 2017 at 1:40 PM
    cmndr brain
    Rob,
    If you are in upstate ny, like me, then you know all about rust. That is the part I'm looking for. Little pricey for a bent tube but, at least I now have a part number and can continue my search. Thank you very much.
    robupstateny[QUOTED] likes this.
  7. Apr 15, 2017 at 5:06 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    hmm, after 13 years I'd just assumed it was welded. rust has made every other bolt/nut impossible to distinguish so mine is probably shot :(
    robupstateny likes this.
