Looking for info on "oil catch cans"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorrinRadd, Mar 26, 2022.
  1. Mar 26, 2022 at 9:58 AM
    NorrinRadd
    NorrinRadd [OP] Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    TW search isn't being nice to me. Recently saw a fb post about oil catch cans. Had never heard of such a thing. Watching the videos seems to make sense to install one, since "it can't hurt so why not?" seems to be the prevailing thought.
    Anyone have a link for more info? I read that the 2GR-FKS has both direct injection AND port injection, so at low RPM/speed the intake valve is getting washed with fuel so this isn't needed. Can anyone verify that please?
  2. Mar 26, 2022 at 10:07 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  3. Mar 26, 2022 at 10:18 AM
    NorrinRadd
    WA
    Thanks for the vid but it is only installation and no discussion about why or why not, or if the 3rd gen has both direct and port injection or not.
    Mark77 likes this.
  4. Mar 26, 2022 at 10:23 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    The 2GR-FKS does have both PI and DI fuel systems. An oil catch can could be useful if there is significant oil being purged into the intake plenum via the PCV system. On a healthy engine this should be insignificant and the small amount of oil vapor that is combusted should make no measurable difference in power, fuel efficiency, etc. I've heard of catch cans being used for the issue that some have where oil pools at the back of one of the heads when on a steep incline for extended amount of time, but I have not put much effort into understanding the issue and "solution" in detail.
    OmahTako, Mark77 and ktbell444 like this.
  5. Mar 26, 2022 at 10:28 AM
    NorrinRadd
    WA
    I think the concern is long term carbon build up on the intake valves and surrounding area. Wanting to keep my truck forever but don't want to waste money on something useless, thus the questions.
    Mark77 likes this.
  6. Mar 26, 2022 at 10:31 AM
    uurx
    '12 t|x pro
    the install video is what you need
    you need a catch can right away
    go buy one today
    :boink:
    Junkhead and Mark77 like this.
  7. Mar 26, 2022 at 10:48 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I weighted the benefit and decided not to because:
    1. the port injection can clean the intake valves pretty well
    2. I maintain the truck religiously, the piston rings work properly, thus minimal blow-by
    3. I also don't tow or keep the RPM high all the time so even less chance of blow-by
    4. because 2 and 3 the crankcase doesn't need constant venting
    but, I'm 100% sure if you install the catch can, you will catch some. If you drive the truck hard, then you catch more to make it worth it
    OmahTako and uurx like this.
  8. Mar 26, 2022 at 10:56 AM
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    My intake runners were gunky as hell when I put my supercharger on. 40,000 miles. I installed a catch can the same week to prevent all that gunk from making its way into my s/c.
  9. Mar 26, 2022 at 10:57 AM
    eurowner
    eurowner Duke Sky
    Scoty
  10. Mar 26, 2022 at 11:02 AM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    Catch cans are a must if the vehicle is only Direct injection. since this will keep the intake manifold cleaner for longer. but toyota was smart and did DI and port injection with the port injection they can clean some of the gunk left behind by the PCV system. with my old sonata i had to do a intake service ever 12k miles. that was $300 dollars at the dealer or $15 if you DIY but it was a pain. now i just put a bottle of Techron( or your favorite system cleaner) and that will keep it as clean as posible.
  11. Mar 26, 2022 at 11:04 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    So, get a catch can AND a cold air intake? How about a throttle body spacer?
  12. Mar 26, 2022 at 11:19 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Its only needed if you offroad. The reason being that at extreme angles we have seen cylinders 5/6 get flooded through the PCV which causes a lot of burning (white smoke) or worst case engine failure. Outside of daily use they are not needed.
    eurowner likes this.
  13. Mar 26, 2022 at 2:36 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    I do a lot of high angle climbs while off road, I was constantly having smoking / stalling / failure to restart. I’d have to coast backwards down these inclines till it was flat then crank and crank and crank to get it to restart and then it’d blow smoke for a few minutes.
    I installed a catch can.
    I off-road even harder now and have not had a single repeat of the problem since.
    If you just daily the truck and maybe do an overland trip once or twice a year you’re fine, save your $25. I crawl my truck every weekend and it made all the difference for me, well worth the $23.99 I paid for my can off Amazon.
    Kodiak420 and eurowner like this.
