Looking for experience with waterproofing a cap/bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by JuniorVarsity, Jan 11, 2025.
  1. Jan 11, 2025 at 7:06 PM
    JuniorVarsity
    JuniorVarsity [OP] I'm not a pickup truck guy. I have two.
    PacNW
    1999 Tacoma SR5 4x4, 2021 TRD Sport Access Cab
    Friends,
    My daughter plans to take the 1st gen on a road trip, and we're going to build out a bed frame situation for her in the back. Have an old camper shell ("Range Rider" brand) that is handy, but has never been water tight even with careful application of the rubber gasket and butyl tape at the corners near the cab.
    I'm really hoping to seal it up as best I can; looking for anyone's practical experience.
    So far, I've removed the drop in bed liner and cleaned it and the bed. Removed the shell, shell windows and back window. Cleaned the hell out of everything. Pics below for fun.
    Before disassembly, put some paper towels around the inside during a rainstorm to identify leaky spots. Most were near the bed corners closest to the cab; some at window seams.
    I plan to:
    --replace broken screens
    --apply silicone to the window seals before reinstalling them
    --use rubber gaskets at the tailgate/bed interface
    Questions:
    --do I try to apply silicone or auto seam sealer to the vertical truck bed seams nearest the cab?
    --do I put the drop in bed liner back in or leave it out? it steals a bit of space on the interior, and I'm not sure it helps much with the water issue. it also creates a sealing problem at the corners of the bed nearest the cab since it goes *over* the bed adjacent the cab but tucks *under* the side bed rails.
    Thanks for any inputs!
    JV
    Steves104x4 likes this.
  2. Jan 11, 2025 at 8:07 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  3. Jan 12, 2025 at 7:30 AM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I'd also reccomend some putty. They sell putty you can put in the corners to help it seal. The trick is laying the gasket in the corners so it lays flat without cutting it.
  4. Jan 12, 2025 at 10:56 AM
    JuniorVarsity
    PacNW
    funny, this is the exact one I've used before (and have bought again to apply when I put the cap back on).
    Area51Runner[QUOTED] likes this.
  5. Jan 12, 2025 at 10:57 AM
    JuniorVarsity
    PacNW
    I didn't think you could do the corners without cutting the gasket. The instructions say to cut a triangle out of the gasket to allow it to make the 90 degree turn and remain "intact." If you have another technique, I'd love to see pics.
    Area51Runner likes this.
  6. Jan 12, 2025 at 11:08 AM
    tacoman2001$
    That cut is usually how water gets in around the seam. Some of the seals like a heat gun. Sometimes I'll start to bend it then make partial relief cuts not all the way through but just enough to let it curve. This isn't the exact putty I used but something along the lines of this. Id put it at the ends and corners or anywhere you have water leaking.
    https://www.amazon.com/dp/B003MZK122/
  7. Jan 12, 2025 at 12:19 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    If she's going to sleep in the back of the truck, the only advise I can give you is to make a raised bed. That way her sleeping area should stay dry even if it leaks a small amount.
  8. Jan 12, 2025 at 1:09 PM
    Area51Runner
    FWIW, I’ve followed the instructions when installing the seal (slight cuts). No issues to report with water intrusion.
    In the end, every cap leaks. It’s a matter of how much and how often that matter. A platform is a must if sleeping back there.
    SpencerTacoSC likes this.
  9. Jan 12, 2025 at 2:00 PM
    JuniorVarsity
    PacNW
    100%. Building a platform is on the list. Want to minimize risk of plywood getting wet and disintegrating....
  10. Jan 12, 2025 at 2:19 PM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    I've lived in the back of a Toyota for months on end. Platform is key because it lets' you store all your gear underneath and out of the way (and out of sight).
    Does any water leakage end up under the bedliner on in it? If it's under it, I'd lean it in. But if it holds the water skip it, or drill holes to let the water out.
    I never thought to seam seal the front corners of the bed. Not a bad idea. My cap leaks at the rear window by tailgate. Cannot figure out exactly the issue.
    You might also look for a locking tailgate latch. There is one make available but I don't know how good it is. I'm planning to make some locks on the inside of the tailgate so the tailgate cannot be opened even if the cap window is closed.
    good luck--
    JuniorVarsity[OP] likes this.
  11. Jan 13, 2025 at 5:03 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    The front corners of the bed at the top of the rail where the seams are is usually where most of the water will get in. Sometimes there is a slight difference in the level of the front rail to the side rails. Get some butyl tape and pack that area to make it as level as you can.
  12. Jan 13, 2025 at 8:57 PM
    sierra_surfer_taco
    sierra_surfer_taco Well-Known Member
    San Diego
    2000 Tacoma TRD
    Stain and seal the bottoms and corners of the plywood and you'll be fine no matter what happens.
    Like others have said, the foam tape on top of the bed rails is not perfect so you're already miles ahead with that ESI Super Cap Seal (plus window seals as you mentioned). I also put silicone in the corners of the bed near the cab - worked for me, but not sure if others think that's a bad idea in the long term. Rubber gaskets at the tailgate are nice to have to keep dust out, but I found that was never where water entered if you're running short on time before your trip.
  13. Jan 14, 2025 at 1:12 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    JV==>
    the camper's side glass......VERY similar to RV glass
    this vid kinda long but this is how reputable RV shops seal glass
    FF to min 30
    after installing butyl tape(kinda like a putty strip)
    this is where you place 2 lines of painter's tape on outside of window, leaving small gap
    this prevents the sealant spreading everywhere
    https://youtu.be/gdCJcYReegI?si=Kp9DIMoRQRKprh8P
    here is a shorter vid
    but this couple did not seal outside with this painter's tape trick
    https://youtu.be/7Aka0aUGUE0?si=JJdlsL5j25Tdc2TN
    hope this help you!!
