Looking for either a 110v or 12v portable air compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Patch Barracks, Dec 31, 2015.
  1. Dec 31, 2015 at 7:00 PM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
  2. Dec 31, 2015 at 7:03 PM
    scottfarm
    Florida
    tacoma 4X4
    You can get the above compressor from Harbor Freight for $39 with a coupon. It works in my bed plug in.
  3. Jan 1, 2016 at 5:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The little pancake compressors draw about 300 watts running and over 800 starting it likely will smoke the inverter in short order you would be far better off with a 12 volt one.
    CusterFan likes this.
  4. Jan 1, 2016 at 7:05 AM
    Rhubarb
    Rhubarb Well-Known Member
    Big D (TX)
    2016 OR, Manual Trans
  5. Jan 1, 2016 at 7:09 AM
    scottfarm
    Florida
    tacoma 4X4
    I have been using it for 1 year on several camping trips. I use it for my firestone bags. Have used it with my nailer. No problems. By using the word likely, it shows me you have no experience using it.
  6. Jan 1, 2016 at 8:20 AM
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    I have a 4 amp compressor like that, and it works fine in the bed plug, but it does draw more than 5 amps on start up, which is bad for the electrical shit In your truck. I strayed away from using it on the chance that I'd be out on the trail and I'd blow a lot of fuses while using it. It has happened plenty of times to people on here.
  7. Jan 1, 2016 at 11:23 AM
    scottfarm
    Florida
    tacoma 4X4
    Which fuse is it that blows. What else is tied in with the fuse that blows. Does anybody know?
  8. Jan 1, 2016 at 12:27 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I bought the biggest viair pump I could find on Amazon along with some deflators. Works great
  9. Jan 1, 2016 at 12:44 PM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    Extra battery behind rear passenger-side seat, 12v outlets and inverter behind rear driver-side seat.
    Compressor lives under rear driver-side seat. Just pull it out and plug it into 110v from inverter, and run air hose to whatever.
    For the number of times I use it, I don't see the need for a built-in. From comparing with friends' 12v units, it seems a 110v unit works a little better, plus don't have to screw around with battery clips.
    To each his own ...
  10. Jan 1, 2016 at 1:27 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Quite right I don't but I am a retired electronics engineer the pancakes draw 312 watts average running wattage a normal motor draws a bit over 200% of running current just to start add head pressure of a compressor your looking at close to 800 watts or twice the capacity of the inverter granted the inverter may have an inrush of 600 watts momentary current capacity but no matter what it is more that the little inverter should be asked to do it is marginal at best. Yes you could buy a bigger inverter but you can also buy a 12 volt compressor a skip the added expense.
  11. Jan 1, 2016 at 8:10 PM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    I stow my Viair 450C behind my driver seat. Happy with its performance. Use as per the operation manual. Also keep a full set of deflators with it.
  12. Jan 1, 2016 at 9:55 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  13. Jan 1, 2016 at 10:53 PM
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    I have a little 12V Husky compressor from Home Depot in each vehicle. Great to have in the trunk or behind the seat, and I've let two co-workers borrow them when they had flats or slow leaks. They have a little flashlight on the front as well which can be handy. Not real heavy duty, so not ideal choice for pumping a tire from a dead flat.
  14. Jan 1, 2016 at 11:29 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  15. Jan 2, 2016 at 4:00 AM
    #35
    mojavejohn
    mojavejohn Well-Known Member
    Mojave Desert, Ca
    2018 Dbl. Cab Off Road MT
  16. Jan 3, 2016 at 8:39 PM
    #36
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I just order my Viair 450P.
  17. Jan 3, 2016 at 8:56 PM
    #37
    007TRUCK
    007TRUCK Well-Known Member
  18. Jan 3, 2016 at 9:09 PM
    #38
    Tacogram
    Apple Valley. CA
  19. Jan 4, 2016 at 7:16 AM
    #39
    ModocTaco
    ModocTaco Active Member
    Gods Country
    2016 TRDOR DCLB Quicksand D.O.B. 1/6/2016
    ARE Overland topper, Frontrunner slimline II rack, TRD pro wheels, Cooper st pros
    Viair 450p here.. Buy once cry once. I ran a arb for a few years in my cj5 that thing was total crap, ran so hot that it was scary.
  20. Jan 4, 2016 at 7:21 AM
    #40
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    If you get the Viair 88P you won't need the battery clip adapter. I was going to go the route you suggested because I was worried about blowing fuses with the 85P plugged into the outlet in the truck. I then went to Viair web site and watched video's on Youtube. I bought the 88P as it has the long hose to reach the back tires without buying an extension hose and no need for the battery clip adapter. Get the tool bag I posted a Ebay link for and everything fits nicely in it for neat storage.
    #40
    007TRUCK[QUOTED] likes this.
