Looking for aftermarket aluminum rear bumper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Clymber, Jul 28, 2024.
  1. Jul 28, 2024 at 3:32 AM
    Clymber
    Clymber [OP] Well-Known Member
    Vermont
    Trd
    I'm looking for companies that make aluminum rear bumpers for a 3rd gen Tacoma. I'm trying to drop weight and living in the northeast I am fed up with the steel rusting. Yes I know it wont be as strong as steel and all the other drawbacks. Also in bare metal so I can get it painted. Powder coating in the northeast is useless always chips and flakes off
    JDSmith likes this.
  2. Jul 28, 2024 at 6:24 AM
    Kcruisin
    Kcruisin Well-Known Member
    North Alabama
    '21 TRD OffRoad
    Bumpers and winch
    Check HookeRoad, I got my set from eBay. They fit well and look good.
  3. Jul 28, 2024 at 10:23 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Victory used to make front and rear bumpers in aluminum, but not anymore. I should have pulled the trigger back then. A google search suggests there are still some aluminum bumpers on the market.
    Here’s one:
    https://www.demello-offroad.com/aluminum-2016-2021-tacoma-bumpers
    Side note: aluminum parts are not necessarily weaker than steel. Aluminum parts made with more material can equal the strength of a steel part. Compare an aluminum and steel bicycle frame. However, typical aluminum armor is 1/4” and steel armor is typically 3/16”. Depending on the alloys used, the steel armor is likely stronger. The biggest disadvantage of aluminum, IMHO, is the price.
    soundman98 likes this.
  4. Jul 28, 2024 at 5:03 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    +1. it also tends to fatigue differently, and has a different thermal expansion rate, but also accepts anodizing better as the surface opens up more during the process to retain the pigment.
    personally, i don't think you'll save all that much in the overall truck weight getting an aluminum rear bumper-- maybe 50 pounds max once the thicker aluminum is used to combat the differing properties. and realistically, the trucks are very front-heavy, so saving weight in front would generally be more ideal, but the front plastic bumper is the best weight saver for that situation...
  5. Jul 28, 2024 at 6:36 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Are your bumpers magnetic?
    BabyBilly likes this.
  6. Jul 29, 2024 at 5:51 AM
    Kcruisin
    North Alabama
    '21 TRD OffRoad
    Bumpers and winch
    IDK, they are powder coated and oxidize orange.
  7. Jul 29, 2024 at 6:00 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Your bumpers are not aluminum. Hooke Road makes cheap bumpers out of thin steel.
    @eurowner asked if they're magnetic because ferrous metals (i.e. steel) allow magnets stick to them, while non-ferrous metals (i.e. aluminum) do not react to magnets.
    K9tacoma and eurowner like this.
  8. Jul 29, 2024 at 6:08 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Thev OP specifically ask about aluminum rear bumpers. Yours are steel.
    K9tacoma and BabyBilly like this.
  9. Jul 29, 2024 at 6:13 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    To address the weight concerns, I build bumpers in NH and with this design I had a total weight gain of 6 lbs
    I checked a few companies I know about and cant find any aluminum rear bumpers. I thought for sure Greenlane offroad would sense they build aluminum sliders, but they do not. I do not recommend aluminum sliders either.
  10. Jul 29, 2024 at 6:23 AM
    Clymber
    Vermont
    Trd
    I currently have an aluminum CBI front and steel CBI rear.
    Current setup minus the new wheels.
    JDSmith likes this.
  11. Jul 31, 2024 at 8:14 PM
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    I looked for a long time in 2022 for an aluminum rear bumper for my 2020 OR. After a few months of looking pretty hard online, came to the conclusion that nobody makes them. Anybody who did make them stopped. Don't know why, but I think that most likely they didn't stand up to use that they were put to.
  12. Aug 1, 2024 at 4:34 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    I did find that coastal offroad makes a aluminium WIY kit.
    https://www.coastaloffroad.com/product-page/3rd-gen-tacoma-high-clearance-rear-bumper-kit/
