Looking for a little Help. Broke the caliper bolt off in my caliper.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josephray70, Jan 20, 2025.
  1. Jan 20, 2025 at 7:25 AM
    Josephray70
    Josephray70 [OP] Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace.
    I have a 2017 Tacoma I completed the brakes on one side went to try to break the caliper bolts loose on the passenger side. the top one broke loose the bottom one wouldn’t budge. Used PB blaster then when that wouldn’t work, a torch. and the bolt broke off with about a quarter of an inch sticking into the caliper. I might be able to get it into a shop mid this week. But I was wondering if I could possibly drive on it just using the old pads and rotor until then. Could this harm my caliper at all in anyway. A quarter inch of the bolt is sticking into the caliper hole where the caliper will not come off even with the other bolt out
  2. Jan 20, 2025 at 7:33 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Don't think I would risk it. Maybe move onto the brake bracket and see if you can remove it. That way you just need a new caliper and new bracket...not a new truck because of the caliper coming off inside the wheel.
    Ngneer and SH10151 like this.
  3. Jan 20, 2025 at 7:42 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    The bolt is not inside of the caliper. the broke off piece is in the wheel hub. That’s what the caliper mounts to. There is no caliper bracket like other vehicles have
  4. Jan 20, 2025 at 7:45 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Until the brakes are correct, you should consider that vehicle "out of service". For your own safety as well as the safety of others.
    Ngneer, SH10151 and thomasburk like this.
  5. Jan 20, 2025 at 7:52 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat,
    Short answer, No...
    Long answer, with the lower mounting bolt missing the caliper can move out and away from the caliper bracket/steering knuckle and catch the inside of the wheel and stop the wheel from rotating, can basically lock the wheel with zero warning...
    This happens more often then you would think with brake caliper bracket bolts not being torqued and the bolt falling out...
    Can you maybe get lucky and drive it slowly and make it ok, yes, do you really want to take that chance?? I hope not.. You would be safer to drive in reverse the whole way... lol
    soundman98 and Josephray70[OP] like this.
  6. Jan 20, 2025 at 7:55 AM
    DavesSR5
    Dave
    That would be the steering knuckle not the hub, the hub rotates with the wheel bearing and the hub is what the wheels bolts to... just a FYI..
    BTW you should not need a new caliper, and a good shop will/should be able to remove the broken bolt.. worst case you buy a new knuckle...
    Here is the left knuckle, you can see the caliper mounting bolts towards the right lower big circle/hole in the picture.. should look like yours...
  7. Jan 20, 2025 at 7:57 AM
    Tacoma Mike
    Southern Maine
    There are ways to get it out but you don’t have the equipment to do it..
    I would tow it to an old school guy that has experience.
    If he’s good, nothing will have to be replaced except for the bolt
  8. Jan 20, 2025 at 9:06 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    Yeah I knew it attached to I just didn’t know what it was called. I’m actually taking it to a place in about an hour. I live in Michigan. The roads are really bad. Everybody’s driving about 20 miles an hour. I have everything put back together. There’s a good quarter inch of that bolt sticking into the caliper hole so it ain’t going nowhere.
    DavesSR5[QUOTED] likes this.
  9. Jan 20, 2025 at 9:08 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    Appreciate the advice. Actually I’m taking it to a shop in about an hourand yes, I’m gonna be driving slow. The roads are really bad. Everybody’s doing about 20 miles an hour
  10. Jan 20, 2025 at 9:13 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    I would say this probably happened because I heated up with a torch and the bolt was cold. It’s 7° right now in Michigan. I do have a garage heater, but it ain’t doing shit
  11. Jan 20, 2025 at 2:49 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    so everything got fixed. They were able to get the old bolt out. And just charged me 100 bucks. I was expecting to pay a lot more lol.
    513Mugsy, pyankura, DavesSR5 and 4 others like this.
  12. Jan 20, 2025 at 6:03 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Glad to hear you got it sorted. A good lesson for next time, don't do vehicle repair in horrible weather!
    Josephray70[OP] likes this.
  13. Jan 20, 2025 at 6:41 PM
    DavesSR5
    Dave
    That is great news, glad they took care of you... That is what can make lifelong customers...
