Looking at Michelin Defender LTX M/S vs Cooper Discovery AT3 4s vs Toyo Open Country AT2
Discussion in 'Wheels & Tires' started by Flyfishing, Mar 13, 2020.
  1. Mar 13, 2020 at 11:09 AM
    Flyfishing
    Flyfishing [OP] Well-Known Member
    North Carolina
    22 sr access cab
    Hello everyone I am looking at the Michelin Defender LTX M/S vs the Cooper Discovery at3 4s vs the Toyo Open Country At2 . My truck is stock 2.7 4 cyl.. so the ltx has a 70,000 mile warranty and the two sets of at tires have 65,000 miles .. so I am going to stay with the 245/75/16 size . And really wanted to know if I switch to one of the all terrain tires will my fuel mileage go down drastically or stay about the same ? Or if I am better off going with the highway tire ltx for better ride and longevity of tire. Thanks in advance
  2. Mar 13, 2020 at 11:15 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Mar 13, 2020 at 11:32 AM
    Flyfishing
    North Carolina
    22 sr access cab
    I will look those up now thanks
    BillsSR5 likes this.
  4. Mar 13, 2020 at 11:39 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    In my experience the all terrains will be slightly louder, slightly less in mileage, and a lot less in longevity. As to how much exactly depends a lot on how aggressive the tire looks.
    For a highway tire I do like the Michelins or the Toyo. I originally ran the Firestones that came on some 2016s stock and would avoid those at all costs now. I hated those things with a passion.
    rev25sharp and mallege like this.
  5. Mar 13, 2020 at 11:40 AM
    mallege
    mallege Well-Known Member
    George
    SW Idaho
    2019 Tacoma SR Gray SB Auto V6
    Extang tonneau cover, variable speed wiper stalk, hood struts, ScangaugeII.
    IN a 245/75/16 tire size, you will have 28 pounds (7 pounds per tire) more rubber rotating with the Toyo Open Country ATII tire than you will be with the Michelin LTX. So yes your mileage may drop around 1-1.5 miles per gallon depending on the driving you do. With the Coopers you will have 12 pounds more (3 pounds more per tire) than the Michelin LTX so I would expect less of a milage drop than the Toyo ATII tire.
    I downsized from 265/70R17 Dunlop AT20 tires and now have two sets of wheels in 245/75R/16. One set is Yokohama G056 tires and the other set is the Cooper AT3 4S tires. I can notice the mileage difference between the two sets of 245/75r16 sets. The Cooper tires are 3 pounds heavier and the rims I am using with them are also ~ 3 pounds heavier. So yes, it all adds up and it is slightly noticeable between the 16 sets, but both of these 16 sets are better than the 17 set that I was running with Dunlop tire as far as mpg.
    Your picture shows your truck in the mud. I got the AT3 4S tires for the winter and because I do use Forest Service roads when I go backpacking.
    Highway - Michelin LTX
    Mix - more towards the Cooper AT3 4S
    More BLM/Forest Service roads then towards the Toyo ATII.
    https://www.tirerack.com/tires/Tire...3140&cjevent=2981cc49655611ea810200900a1c0e10
  6. Mar 13, 2020 at 11:45 AM
    BillsSR5
    bill
    2014 SR5
    those are quality tires Made in Japan, very good all around and seem to be wearing very well, cant beat the price
  7. Mar 13, 2020 at 11:53 AM
    Flyfishing
    North Carolina
    22 sr access cab
    Well I have the stock hankooks Rh 12 with 42,000 miles on them and I rotate them every 5 k and they seem to be wearing faster on the outer part of the tire and some on the inner most part of the tires and there are some high and low spots on the tire . I don’t haul any trailers or anything like that . I just don’t think they will go to 70k as they are advertising on the website . 95 percent of my driving is on the highway or city .. I do hunt and fish and wanted a little more bite for wet grass and a little mud .. but being a 4 cylinder this truck already does not have a lot of power lol .. but the fuel mileage is great . So now I am thinking I need to stay with a high way tire over the all terrain tires .. thank you to every one who has replied to this thread.
  8. Mar 13, 2020 at 12:09 PM
    BillsSR5
    bill
    2014 SR5
    yeah I agree I have the 2.7l and its my daily driver I wouldn't use a AT tire or bigger sized tire than the P245 highway tread, if your having wear on the outside edge of the tires you need to have the Camber adjusted properly especially if your rotating every 5k miles, its the front end alignment>camber
    mallege likes this.
  9. Mar 13, 2020 at 12:11 PM
    mallege
    George
    SW Idaho
    I agree with BillSR5, likely need an alignment. Also be sure to look at the UTQG rating for the tires you are considering.
  10. Mar 13, 2020 at 12:48 PM
    Flyfishing
    North Carolina
    22 sr access cab
    So what does UTQG stand for ? I know some tires are 500-600. 700 - 800 . There is no play in the steering and the truck drives in a straight line going down the road.. but i will get it looked at .
  11. Mar 13, 2020 at 12:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    If youll explore the technical sections of Tire Rack.com you'll find great explanations for all tire symbols, how to read dates, etc. Worth the time if that stuff matters to you.
    Buy for 90% of your mileage.
    If that's street the Defenders are a good choice.
  12. Mar 13, 2020 at 1:03 PM
    Flyfishing
    North Carolina
    22 sr access cab
    I looked at it and I now l is what I ab liking as far as the different numbers thanks
  13. Mar 13, 2020 at 1:49 PM
    mallege
    George
    SW Idaho
    The Michelin has a good UTQG rating - 800AB.
  14. Mar 14, 2020 at 5:46 AM
    Nick2014
    Nick2014 Active Member
    Vermont
    2014 AC Sr V6 4X4
    Check out the Michelin at2 a little more aggressive then the defenders but still great mileage
  15. Feb 19, 2021 at 12:45 PM
    Sammy4x4Taco
    Sammy4x4Taco Well-Known Member
    Sam
    Silver 2014 Tacoma Limited Double Cab Long Bed
    Stock
    Got myself some Michelin Defender LTX's the other day. These are amazing in every way. Been snowing for two days and I haven't needed 4wd yet. They were hella expensive but worth it. These are 275/65r18 on factory limited wheels. Two inch leveling lift in the front.
    rev25sharp, knayrb and Fast1 like this.
  16. Feb 20, 2021 at 6:07 AM
    taco pops
    taco pops Well-Known Member
    Russ
    West Michigan
    2016 black SR5 Tacoma DCSB
    Side Steps, Tonneau cover
    Michelin LTX Defender and you won't be unhappy.
    TreeFortRichard and knayrb like this.
  17. Feb 24, 2021 at 7:30 PM
    MtnMoose
    MtnMoose The Moose is loose
    Utah
    98 XCab SR5 TRDOR SC (Sold) 2020 DCSB TRDOR SW (New)
    1.5 Lift, Bilstein 5100s, Rear AAL, Tint, BedRug, Skid Hitch, Shovel/Saw Mnt, Elec tailgate lock & retention device,
    Agreed :cheers:
    rev25sharp and knayrb like this.
  18. Mar 12, 2021 at 7:02 AM
    cpenn
    cpenn New Member
    Casey
    2016 TRD Sport 4x4
    3" Superlift
    Sammy, Do you by chance know the offset of the stock limited wheels you are running? I'm getting ready to put 18x9 Fuels on my son's 2016 TRD Sport with a 3" Superlift (3" front, 1.5" rear). I can get them with 0 or -12 offset and am wanting to run 270/65/R18s. Just don't want any rubbing and would prefer not to trim. Not sure which offset to get on the wheels and if the tires will work. Any thoughts appreciated. I'm pretty new to the Taco world.
  19. Mar 12, 2021 at 2:28 PM
    Sammy4x4Taco
    Sam
    Stock
    Not 100% sure. This is the only thing I could find on the web which says 25mm
    https://www.hubcaphaven.com/p/8743/...Zyhc4nnwAvhHqgDzsCTrYG6avf4Ahwd8aApQZEALw_wcB
  20. Mar 13, 2021 at 9:56 AM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Michelin Defender 265/75-16
