Longest lasting AT tires
Discussion in 'Wheels & Tires' started by beavis87, Nov 26, 2015.
  1. Nov 26, 2015 at 12:14 PM
    beavis87
    beavis87 [OP] Well-Known Member
    El Paso
    '10 Silver TRD OR
    Which tires are the longest lasting, best performing and for the best value on our trucks? Looking around most of the tires below have treadwear warranties of 50-60k. Do any of these meet or exceed that on our trucks? Thamls
    BFGoodrich A/T
    Bridgestone Dueler A/T
    Bridgestone Dueler A/T REVO 2
    Cooper Discoverer A/T3
    Cooper Discoverer A/TW
    Cooper Discoverer S/T
    Dick Cepek Radial FC-II
    Firestone Destination A/T
    General Grabber AT 2
    Goodyear Wrangler AT/S
    Goodyear Wrangler Duratracs
    Goodyear Wrangler SilentArmor
    Hankook DynaPro ATM
    Michelin LTX A/T 2
    Mickey Thompson Baja ATZ P3
    Nitto Terra Grappler
    Pro Comp Xtreme A/T
    Toyo Open Country A/T II
  2. Nov 26, 2015 at 12:21 PM
    doorsidedown
    doorsidedown Well-Known Member
    Way too many variables to give you one answer. However, I've had good luck with cooper AT3 and Nitto Terra Grapplers.
    Tomass321 likes this.
  3. Nov 26, 2015 at 12:23 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    This is going to get interesting :popcorn:
  4. Nov 26, 2015 at 12:31 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    General AT2s with almost 60 thou on em. Getting a bit hard now, but lots of tread left. Good on dry. Pretty good on wet. Good in snow. Ok on ice ( siped) great off-road on rocks, dirt, sand, glop. Going to,run them till February, then replace with E rated. Either same or BFG KO 2s. Note. I rotate EVERY 10k miles.
  5. Nov 26, 2015 at 2:56 PM
    bolio
    bolio Well-Known Member
    San Antonio
    08 trd OR 4x4
    My KO's lasted 100k miles, but got very hard and slippery the last 20k. My current Duratracs are done at 50k miles, very unsafe in the wet and didn't wear as good or evenly. Both in 265-75-16
  6. Nov 28, 2015 at 9:49 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    A general rule on tires is a longer mileage tires are made of a harder compound. A harder tire is less sticky. Also the temp of the road for the intended use also comes into play. So a snow tire wont be a good choice for someone in an Arizona desert. Your tires will melt in the summer sun. Mileage of a tire shouldn't be your only factor when buying tires. YMMV.
  7. Nov 28, 2015 at 9:57 AM
    beavis87
    El Paso
    '10 Silver TRD OR
    Didn't think the OEM Dunlop's were AT tires or had treadwear warranties.
  8. Nov 28, 2015 at 9:58 AM
    beavis87
    El Paso
    '10 Silver TRD OR
    Would an AT tire with kevlar or silica in the compound mitigate the hardness in cold weather or high miles?
  9. Dec 1, 2015 at 8:15 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    The Kevlar has no impact on the tread patch as is typically used only in the body plies and will never actually be contacting the pavement unless the tire fails or you run them beyond bald. Silica is supposed to help with longevity, but I don't think it makes the tire any "softer".
    It really is going to be a compromise. You can't have an infinite tread life and excellent handling the entire time. That being said, I had over 70k miles on a set of Destination ATs and the biggest wear related issue was how loud they got toward the end.
