Longer tie rods?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eddie4rivera, Feb 4, 2019.
  1. Feb 4, 2019 at 7:28 PM
    Eddie4rivera
    Eddie4rivera [OP] Active Member
    Eddie
    Hawaii
    2004 Toyota Tacoma
    Ok so here’s the deal, I lifted my truck a couple months ago, everything was fine, alignment was done and everything seemed to be good. I then went ahead and replaced my lower control arms and when I went back to get another alignment done they told me they did the best they could but they couldn’t align it correctly because my tie rods were maxed out. So pretty much both of my tie rods are only screwed in about a 1/2” which I’m pretty sure can’t be good lol. Steering rack I thought was bad so I replaced over the weekend, still same problem. Thinking the lift and upgraded lower control arms maxed things out but how should I know. So my question here is, has anyone had this problem? Or what can anyone recommend me check or do at this point? I’ve been looking online and I’ve come across some long travel tie rods with Heim joints that I could possibly put on there but not sure if they’re too long? Does anyone know how much longer over stock the long travel tie rods are? Open to suggestions.
    Here’s the long travel tie rods I’m looking at: Here’s a pic of the maxed out tie rod:
  2. Feb 4, 2019 at 7:36 PM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    I have no advice except be sure to install cotter pins in those castle nuts on the rod ends before you drive. Good luck.
  3. Feb 4, 2019 at 7:38 PM
    Eddie4rivera
    Eddie
    Hawaii
    2004 Toyota Tacoma
    This was right after changing the lower arms, cotter pins were put in right after, but thanks lol.
    Boneretreiver[QUOTED] likes this.
  4. Feb 4, 2019 at 7:40 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Well is that a stock length lower...?....
    And are you running 5” wheel spacers or what?
  5. Feb 4, 2019 at 7:41 PM
    Eddie4rivera
    Eddie
    Hawaii
    2004 Toyota Tacoma
    Yes, part specified lower control arms were stock length.
  6. Feb 4, 2019 at 7:46 PM
    anthony250f
    Anthony
    San Diego, CA
    Find a new shop. Same issue happened to me and The shop just didn’t know what they were doing
  7. Feb 4, 2019 at 7:48 PM
    Eddie4rivera
    Eddie
    Hawaii
    2004 Toyota Tacoma
    Guess it wouldn’t hurt going somewhere else, I’ll try taking it somewhere else see what they say. Thanks.
  8. Mar 26, 2022 at 9:19 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    im having this same issues how did you correct them, thanks B046C05A-1557-495B-B1F6-6BF1DEB9A027.jpgafter installing aftermarket LCAs my tie rods were short how do you fix yours???
  9. Mar 26, 2022 at 9:35 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Where did u get that steering rack.....I dont think that is the right one....
    that one goes in the 5lug rwd.........
    Your tie rods show look like the earlier post..'S' shaped......
    And they're not inter changeable.....the inner thread size on the inner tie(4x4) is much larger.....like m15.....
    so its not physically possible to put wrong tie rods on wrong rack.....5lug vs 6lug
  10. Mar 26, 2022 at 9:44 PM
    neegdogdig
    3rd Gen DC V6
    Those are originally stock tie rods from the factory never touch it til now
  11. Mar 26, 2022 at 10:03 PM
    O'Silver_Taco
    MD
  12. Mar 26, 2022 at 10:43 PM
    neegdogdig
    3rd Gen DC V6
  13. Mar 26, 2022 at 11:23 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    It really depends on the shop and how long they will deal with working on it. One shop wanted 100$ for aligning my LT truck but I had one do it for 80$ within 36 mins
  14. Mar 26, 2022 at 11:26 PM
    neegdogdig
    3rd Gen DC V6
    No alignment yet just finished installing
  15. May 14, 2022 at 10:07 AM
    Nickk123
    Nickk123 Member
    Nick
    2019 Tacoma off road cement
    6” BDS FOX SHOCKS 12k RC SYNTHETIC FRONT HEADACHE 4500 SYNTHETIC BOTH REMOVABLE 33 NITTO EXO GRAPPLER 20X11 HD PRO LHD 1
    I’m having the same problem I put a 6in bds on 33s and my tie rods are maxed out has anyone added extensions if so what brand and length?
  16. Oct 31, 2022 at 10:54 PM
    EvanDykesOlYeller
    EvanDykesOlYeller Well-Known Member
    Evan
    2003 4WD 5SP Supercharged Taco Shitrunner
    whole thing modded out to be a Prerunner
    Guys I’m in the same boat did any of you guys ever get a good answer?! I just did a rack warranty swap but couldn’t get my extenders off so I surrendered them with the rack trade in. Now I’m searching the internet and can’t find jack for a gen 1 taco D; it’s a total chaos mid travel in the front
