Long Travel on 3rd Gen Tacoma
Discussion in 'Long Travel Suspension' started by erok81, Jul 4, 2017.
  1. Jul 4, 2017 at 9:37 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Is anyone else besides me building a long travel third gen? Let's talk about how fun it is chopping up a new truck!
    I'm curious what others are doing. How the parts are fitting. And of course pics!
    GunderTacos and TheTacoma like this.
  2. Jul 7, 2017 at 11:54 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Lsk is building a bad ass 3rd gen. And dmz has cranked out a handfull lately. I worked on one for a guy a few months back, but can't remember his TW name.
  3. Jul 10, 2017 at 5:10 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I am working on one here at shop LSK, Brand new truck, full kill build. Our Lt kit all bolt on. I can say fitting 35's to tuck was really hard. At the time there was only mcniel front fenders 6" so huge . Now there should be others making it. In the rear it is 4 Linked with 40gal fuel cell. Stock trussed axle. 35" raceline beadlocks. Not sure what the owner is going to regear but we are not doing it. I do know it may hate life unless its geared to 488 or 529. The front suspension seems to be the same as previous years. The rear is same pretty much too. The axle in the rear seems to be wider but I could be wrong its pretty close to being same as wide as my tundra axle. And cab cage I gutted the heck outta this thing. But stock dash with ac was able to stay. All 2" tube so that's pretty rad. There is just enough room to do it. Were doing a 4 seater , full size prp seats. The frames on these are not boxed like the first gens through out but it is double layered. They seemed to copy manythings off the tundra.
  4. Jul 26, 2017 at 10:54 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    mine will be done shortly
    Dalandser likes this.
  5. Aug 2, 2017 at 4:49 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    CaliRaised LED is building a 3rd gen LT truck.
  6. Aug 2, 2017 at 4:54 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
  7. Aug 7, 2017 at 12:24 PM
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    Can you guys explain why LT is so different from regular as far as components? It doesn't sound very bolt on. What all do you have to cut up?
  8. Aug 8, 2017 at 6:28 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I would recommend checking out the stickys at the top of the LT forum. Long story short, your UCAs, LCAs, and axles ALL get moved out wider to a given distance like 2, 3.5, 4.5, or 6 inches wider. The more diagonal the coilover gets, the more potential travel is gained. Think of it like a 30-60-90 triangle. The hypotenuse will always be the greatest of the three sections. When you go LT, you go from being the vertical leg to they hypotenuse. The more drastic the angle and wider, the more travel.
    Keep in mind, with LT you are also committing to getting new UCAs and LCAs that are similar in price to OEM ones. The difference is since you cant mix match different widths of components at once due to geometric incompatibility, you have to commit all at once. This is the main challenge that LT is to the common man. It also forces you to commit to upgraded UCA and LCA while many mid travel guys may never get LCAs depending on their needs. What makes LT strong and able to withstand stuff is your front HAS to have these components which help make it smoother as well since you have nice bushings and what not in the construction.
    Hope that helps to understand on a basic level.
  9. Aug 8, 2017 at 9:03 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    A truck we did in the beginning of the year...
    ticyzabna, Califor2A, Bob1971 and 9 others like this.
  10. Aug 8, 2017 at 9:03 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    RIP Enigma...
    JoeCOVA and Diablo169 like this.
  11. Aug 8, 2017 at 11:08 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Highly Recommend the Total Chaos Kit. Installs perfectly and rides incredible. No Flaws at all. These guys know how to build solid stuff.
    Califor2A, ian2016, KrnTaco08 and 6 others like this.
  12. Aug 11, 2017 at 2:54 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Dont forget strap limiters and extended CVs!
    Coot83[QUOTED] likes this.
  13. Aug 12, 2017 at 11:07 AM
    Sil
    Sil Of the Earth
    Georgia
    2017 Tacoma SR MGM i4 5 speed 4x4 aka. Vulcan
    Pending..
    How is your build coming? Given time and (a lot)money I will go LT.
    After 56 miles of forest service roads yesterday, I had to much fun. I have always wanted to rally cross in some form or fashion. I travel out west a good bit and want to trail and at the same time hit the higher speed dirt roads.
  14. Aug 22, 2017 at 8:15 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    What happened to this truck?
  15. Aug 22, 2017 at 8:17 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Got into a collision with a drunk driver
    It's totaled
    Coot83 likes this.
  16. Aug 22, 2017 at 8:21 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yep, a Ford I believe was backing out without even looking as he hit him at 40 mph. I think the bumper ate it pretty good, but the frame def crunched up to a degree to where it was a loss.
    JoeCOVA likes this.
  17. Aug 22, 2017 at 9:49 AM
    JoeCOVA
    Joe
    Colorado Springs
    I wonder what he ended up buying.
  18. Aug 22, 2017 at 10:15 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I think he got a Chevy or something. I don't think he wanted to invest in a taco again.
  19. Aug 22, 2017 at 10:34 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Man that sucks.
  20. Aug 25, 2017 at 3:01 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    @erok81 any pics of your beast ?
    erok81[OP] likes this.
