Long travel cvs with manual hubs
Discussion in 'Long Travel Suspension' started by Allex95, Apr 18, 2021.
  1. Apr 19, 2021 at 9:36 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    And wheee did you get those:rofl:
  2. Apr 19, 2021 at 9:38 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Pretty sure they are all the same inners. Total chaos sells LT manual axles IIRC. I have plenty of OEM manual axles if you get me some LT shafts we can get it set up or you can buy then new around $341 each from Toyota.
    Allex95[OP] likes this.
  3. Apr 19, 2021 at 9:40 PM
    Allex95
    allex
    Well the problem is that total chaos would want me to ship my oringial cvs over to change them....
  4. Apr 19, 2021 at 9:42 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I stand corrected, they are ADD. Just get the shafts from CVJ and then put on your own inners hubs and manual outer. If you need some or need help just shoot me a PM.
  5. Apr 19, 2021 at 9:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Wulf has, however we're not talking a freewheel hub like a dana where you just put duct tape in the back of the snout to keep the bearings clean.
  6. Apr 19, 2021 at 9:49 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Why don’t you just order LT shafts from CVJ? Is it the cost? Or will they not just sell the shaft alone.
  7. Apr 19, 2021 at 9:51 PM
    Allex95
    allex
    Well it’s 1100 after shipping. Or I sent them it has to be oem axles and it then takes off 125$ a axle, but yea if I was add cvs the mcm kit would be 2850 and we would be done. But now I’m gonna buy the kit without cvs so 2300 then hopefully figure out which route I wanna go for cvs
    I know someone through king so the I won’t be waiting 30 weeks on shocks
  8. Apr 19, 2021 at 9:53 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    $1100 for a pair of LT shafts?
  9. Apr 19, 2021 at 9:55 PM
    Allex95
    allex
    Yes. 545 a axle everyone I ask for lt cvs are like 1k don’t know why
    zippsub9[QUOTED] likes this.
  10. Apr 19, 2021 at 9:58 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Best of luck, whatever you do, DO NOT google Long Travel Shafts in your searches.
    Dalandser and BrownMike like this.
  11. Apr 19, 2021 at 10:04 PM
    Allex95
    allex
    Yea lmao I know. Just crazy how a kit with cvs is 2800 but if I want manual it’s way out
  12. Apr 20, 2021 at 6:44 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The whole LT platform was built around the compatibility of a Gen 1 Tundra CV. Manual hub trucks never were a big enough percentage of vehicles getting modified in the desert offroad market for anyone to manufacture shafts for them unfortunately. If worst comes to worst and you don't mind spending some more coin, Solo makes spindles that use a Dana 44 manual hubs and special shafts that are a couple grand... but they're truly full float where you could freewheel home regardless if you grenade your axle or diff...
  13. Apr 23, 2021 at 7:15 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Do the manual hub outer CV joints have a different spline or axle shaft length requirement?
  14. Apr 23, 2021 at 7:36 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Completely different spindle.
    Jowett[QUOTED] likes this.
  15. Apr 23, 2021 at 9:20 AM
    #35
    Jowett
    Brian
    North Adams, MA
    Ahhh, I was thinking the outer CV to axle shaft was the issue. I know the differences between the spindle/hubs, I'm working manual hubs/semi float bearing with large CV joints and 30 splines all around for my 3rd Gen.
  16. Apr 23, 2021 at 8:50 PM
    #36
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yes but...
    Same spindle with a different hub / bearing unit which typically makes people want to swap rather than rebuild the spindles.
  17. Apr 23, 2021 at 9:38 PM
    #37
    zippsub9
    Halfmoon, NY
    14 DCLB
    ok, verbiage is different. Same knuckle, different spindle, same bearing, no lockout on one, different hubs between the two. Everybody uses different terms between 1st and current gen designs Completely different outer.
  18. Apr 23, 2021 at 9:43 PM
    #38
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Ah gotcha - yep knuckle or upright is typically referred to as a spindle on here and the spindle that holds the bearings would typically be referred to as the bearing and hub assembly on here - it's funny since I go from the terms usually referred to on here to all the other ones you mentioned immediately when talking about their counterparts on solid axle / dana parts.
  19. Apr 23, 2021 at 9:52 PM
    #39
    Allex95
    allex
    Wish I could mix manual and add but welp. Anyone got some used manual lt cvs lol
  20. Jun 2, 2022 at 10:52 AM
    #40
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    So 1st gen outer has:
    -Manual spline
    -ADD spline (1taco)
    Inner:
    -Manual spline
    -ADD spline
    2nd gen outer has
    -ADD spline (2taco)
    Inner:
    -ADD spline
    1st gen Tundra outer has:
    -ADD spline (1tnd)
    Inner
    -ADD spline
    Are all inner ADD splines the same?
    Are any of the outer splines the same?
