Loctite necessary for wheel spacers?
Discussion in 'Wheels & Tires' started by 16TacoPoke, Sep 13, 2016.
  1. Sep 13, 2016 at 4:03 AM
    16TacoPoke
    16TacoPoke [OP] Active Member
    Just a quick question. I have 1.5" wheel spacers I bought off of eBay, & im thinking about installing them sometime this week. Is it necessary for me to use loctite, would you guys recommend it? & just to add, i am probably going to be removing them later on.
  2. Sep 13, 2016 at 4:53 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    The 243 blue thread locker works perfect!
  3. Sep 13, 2016 at 4:54 AM
    16TacoPoke
    @moe2o4 would I need wheel spacers if I was to do 285's on stock rim with a 3" leveling kit?
    moe2o4 likes this.
  4. Sep 13, 2016 at 4:57 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You'll probably rub depending on wheels. Spacers make he arc of the wheels wider
  5. Sep 13, 2016 at 4:59 AM
    16TacoPoke
    @Aussiek2000 i was gonna go 285's on stock 16" rims. Would I need the wheel spacers? I have a 3" leveling kit on my truck. Trying to avoid rubbing and trimming. All in all, diameter of tire is 32.9 and width is 11.1. If that helps with anything
  6. Sep 13, 2016 at 5:03 AM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Unfortunately, the only way to know for sure is to put the tires on and see whats up. You may be able to get away with some minor modifications, such as a cab mount chop, maybe not. You might need spacers - and I am guessing you will. Only sure way to tell is to try and see. I would say, order the spacers and have them ready. Commit to the size and do whats necessary to make them fit.
    16TacoPoke[OP] likes this.
  7. Sep 13, 2016 at 5:48 AM
    moe2o4
    Corey
    Pittsburgh PA
    Probably depending on your offset of your wheels!
  8. Sep 13, 2016 at 5:57 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    For 285's on stock wheels, you need spacers to prevent rubbing the control arms on the inside. They will cause additional rubbing on cab mount/pinch weld/inner fender wells/fender flairs. (even with 3" lift) Better results with 3/4" or 1" spacers, but even those will still see rubbing on turns and suspension flex.
    285's rub with 3" lift unless you never turn and never drive over anything except perfectly flat, level ground. Unavoidable fact.
    digitaLbraVo likes this.
  9. Sep 13, 2016 at 6:30 AM
    Aussiek2000
    2016 Offroad AC
    You're going to rub unless all you do is drive on the street. This is lifted 3" and the cab mounts cut
  10. Sep 13, 2016 at 7:16 AM
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    I have a 2in front spacer and 285/70/17. My drive is hwy 98% of the time (daily driver to and from work). I did notice I rub on harsh turns at a good acceleration out of like a driveway. Also just noticed yesterday that I do rub when reversing into a parking space. Waiting a week so see if it'll show the rub marks so that I can make some cuts.
  11. Sep 14, 2016 at 12:56 AM
    16TacoPoke
    @Aussiek2000 I believe this truck has a 3" leveling kit, 1.25" spacer, and 285/75R16 nitto trail grapplers, with no rubbing at all. image.jpg
    Clay7160 likes this.
  12. Sep 14, 2016 at 12:57 AM
    16TacoPoke
  13. Sep 14, 2016 at 3:44 AM
    Aussiek2000
    2016 Offroad AC
    Those are AT's with no tread. And you wont know about rubbing until you go offroad.
  14. Sep 14, 2016 at 4:39 AM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    that is a mud tire - trail grappler, lots of side knob
  15. Sep 14, 2016 at 4:52 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Will rub when suspension flexed or full lock turn. Driven slowly on a flat parking lot....you MAY get away without rubbing. Used in real world conditions....it'll rub. Not my first rodeo.
  16. Sep 14, 2016 at 5:46 AM
    Aussiek2000
    2016 Offroad AC
    Prove me wrong then. Not like I don't daily and wheel a 3" lift and 33" MT's
  17. Sep 14, 2016 at 4:41 PM
    Clay7160
    I do not have experience will all tires, just most nitto / toyo in truck tires,
    I sell these tires, i have sold over 200 sets, Nitto Trail grapplers are a mud tire, not as aggressive as there mud grappler, but still a mud tire, not trying to get in a pissing match, but i have mounted these heavy ass tires over and over, the terra grappler is there all terrain, and their new ridge grappler is the hybrid mud/all terrain, even in the link to the tires, it says mud terrain.....
    http://www.nittotire.com/light-truck-tires/trail-grappler-mud-terrain-light-truck-tire/
  18. Sep 14, 2016 at 4:42 PM
    Aussiek2000
    2016 Offroad AC
    I know what the tire is. I thought the post said terra grappler. Prove me wrong a trail grapp or mud grapp 285/70 wont rub off road.
  19. Sep 14, 2016 at 4:44 PM
    16TacoPoke
    @Clay7160 i always thought nitto trail grapplers were a MT as well, not an AT. Anyways, would a 285/75r16 fit on a 16 Tacoma with a 3" leveling kit, and 1.5" spacer?
  20. Sep 14, 2016 at 4:49 PM
    16TacoPoke
    And as I might add, I will be rarely doing any off road, because my truck is only a 2wd.
    Leo4x2 likes this.
