Locking hubs on rear axle?
Discussion in 'Technical Chat' started by 757yotas, Oct 4, 2016.
  1. Oct 4, 2016 at 8:25 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    the rear axle on my truck has an open diff (no locker). Is it even possible to just add locking hubs on the back instead of a whole new locker?
  2. Oct 4, 2016 at 8:31 PM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    Nope, and that's a different kind of locker altogether. Locking hubs disconnect the hub from the axle and won't help offroad, the only reason they exist is to be able to switch between 2wd and 4wd. Adding them to the rear would give you the option of 0wd, or front wheel drive if you have 4wd and unlock the rear.
  3. Oct 4, 2016 at 8:38 PM
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    Adding them to the rear would give you the option of 0wd, or front wheel drive if you have 4wd and unlock the rear.[/QUOTE]
    Sounds like a Honda Ridgeline
  4. Oct 5, 2016 at 8:23 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    From what I've heard, some jeepers have swap in 'full-floating' rear axles that have those manual hubs. No real offroad advantage, but it allows them to flat-tow the jeep long distances without removing the driveshaft.
    MyWyfsRnnr likes this.
  5. Oct 6, 2016 at 12:33 PM
    tgear.shead
    tgear.shead Well-Known Member
    You don't need that to flat tow a jeep, just put the transfer case in neutral. Floating hubs are pretty silly for something as light as a jeep -- their purpose is for carrying incredibly heavy loads without needing an axle that can hold it directly.
  6. Oct 6, 2016 at 12:49 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    The original WW2 era jeeps had full floating rear axles and 3 shift levers, we've gone downhill since then :mad:
  7. Oct 6, 2016 at 12:51 PM
    tgear.shead
    WW2 era jeeps were heavy trucks that would actually carry heavy loads. Nothing at all common to Fiat's "Jeep" brand of tin cans.
  8. Oct 6, 2016 at 12:53 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    There's more reasons than just payload rating for full floating rear axles on off road trucks, primarily that breaking an axle doesn't result in the wheel coming out of the axle.
    Seeing this in your rear view is pretty deflating.
  9. Oct 6, 2016 at 12:56 PM
    cosmicfires
    David
    Everett, WA
    They were referred to as "1/4 ton". They are smaller than the current 2 door CJ jeeps.
    jmaack and DaveInDenver like this.
  10. Oct 6, 2016 at 12:57 PM
    cosmicfires
    David
    Everett, WA
    I hate C clip axles, lucky tacomas don't have that crap.
  11. Oct 6, 2016 at 3:34 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    You mean Willys? They are the size of golf carts.
  12. Oct 6, 2016 at 3:42 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    While free-float axles do avoid this, lots of load-bearing axles avoid this problem too. Most have retainer plates that hold the axle/bearing assembly in place even if you break an axle, as long as the break isn't just behind the hub, which would be unusual. The c-clip Dana 30 and 35 are complete garbage, which is why Jeep stopped using them. Most Jeepers and rock crawlers just use Dana 44 or 60's with standard load-bearing axles.
  13. Oct 6, 2016 at 3:50 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is even more fun when the wheel and axle go rolling past just as the backing plate hits the ground
  14. Oct 6, 2016 at 4:02 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    This being a Toyota board, it's probably worth mentioning that FJ40, FJ60, FJ62, 79-95 mini trucks can all benefit from full floating axles because their axles are C-clip retained. So a twisted axle can lead to a wheel backing out like that. Not that it's really a big enough issue until you really start pushing stuff and even then it's the guys running 35+ and Marlin Ultimates that really destroy stuff. Oh and the heavy Cruisers can twist splines, too. Of course full floater add their own problems, broken studs, wheel bearing repacks.
  15. Oct 6, 2016 at 5:46 PM
    cosmicfires
    David
    Everett, WA
    My 1978 2wd Toyota pickup did not have a C clip rear end, it had ball bearing pressed onto the axles. If the axle broke the wheel and axle wouldn't come off but since it's not a full floating axle it wouldn't be usable. These ball bearings are much better than the bearings in C clip axles. I believe Tacomas use the same design. I do not know what 79-95 mini trucks used but I suspect they are not C clip.
    C clip axles are bad not only because only the C clip holds the axle in but because they have needle bearing that run on the axle. These are the worst bearings you can use find for carrying a load and when the bearing wears out the journal surface on the axle is worn out too so the axles need to be replaced.
    DaveInDenver[QUOTED] likes this.
  16. Oct 7, 2016 at 6:03 AM
    tgear.shead
    If they didn't undo the nuts it wouldn't have popped out like that....
    But no, that isn't actually a reason for floating rear. If you blow your bearing, even a floating hub will pop off.
  17. Oct 7, 2016 at 7:23 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I was thinking older Cruisers, which have the c-clip axles and the rear pumpkin cover to access it.
    It's the wobble when your axle breaks that destroys the bearing in a semi-floating axle. If you decouple the two functions then you're less likely to lose a wheel bearing. In either case of course the bearing failing would result in the wheel coming off.
