Location of Camshaft position sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by luvs2fsh, Jan 10, 2023.
  1. Jan 10, 2023 at 2:47 PM
    luvs2fsh
    luvs2fsh [OP] New Member
    Hi I'm new here and was wondering if I could get a little help. OBD2 said replace Camshaft position sensor but I can't find where it goes. 1998 Toyota Tacoma 2.4L
    A picture would really help. Thanks
  2. Jan 10, 2023 at 2:49 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Edit: shit, you said 2.4. Check out the linked thread. The pic I grabbed is of the 2.7. My bad.
    Pic is from this post. Check out that thread.
    gobraphil and luvs2fsh[OP] like this.
  3. Jan 10, 2023 at 3:15 PM
    luvs2fsh
    Thanks I saw that. I just saw a thread from long ago same year. They said between injectors 2 and 3. I'll check . Thanks for responding..
  4. Jan 10, 2023 at 8:25 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah that's right under the upper part of the intake plenum.....
    there's a forest of wires, hoses, vac switches in your way......
    Heads exactly same on 2.7 and 2.4.......thats an excellent pic of the single bolt that holds that sensor on the engine head.....
    ITs real tight under that fuel rail.....not much room.....might have to pull fuel rail and/or throttle body out of way.....
    way down below it....you can see the knock sensor........
    I may have to steal that picture......file it........
