Loating which tire pressure sensor is bad.
Discussion in 'Technical Chat' started by bluboy, Jan 22, 2015.
  1. Jan 22, 2015 at 7:55 PM
    bluboy
    bluboy [OP] Member
    06 PreRunner Sport
    My tire pressure sensor light on the dash of my 2006 Tacoma TRD Sport blinks continuously. My Toyota dealer says I have a bad sensor in one of my wheels.They want over $200 dollars to repair it. I want to fix it myself.How do I find which sensor is bad?
  2. Jan 22, 2015 at 8:12 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    if it blinks either the pressure is over 50psi or you have a bad sensor. new sensors from toyota are bout 110ish from a dealer and then you have dismount the tire and then program the new sensor
  3. Jan 23, 2015 at 10:40 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    First make sure all 5 tires are within 5psi of each other, (early 2nd gens have a sensor in the spare) then hold the reset button on the dash under the steering wheel down for like 5 sec. IIRC. Not sure of time so check owners man.
    If that doesn't fix it, you can go to just about any tire store and get the sensors read and tell you which one is bad.
    I know the store I go to sells sensors for about 50 bucks apiece and 20 to install.
