Loading a small boat into truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Jan 17, 2019.
  1. Jan 17, 2019 at 9:21 PM
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
  2. Jan 17, 2019 at 9:34 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You could build a couple of ramps from simple boards, but you would need to rig a way to secure them to the tailgate so they wouldn't push up once you started pushing the boat up them. If you just built an "L" with boards at the end such that the short leg faced vertically down, and the long leg laid on the edge of the bed, you could then secure that to the ramp boards by cutting the end of the board at an appropriate angle and screwing them together.
    You probably have no clue what I'm talking about but I can totally visualize it in my mind...
    The other option would be to put tension on the ends by using straps secured to, say, the hitch if you have one. That's how lawnmower ramps are secured.
    A pulley system sounds way too complicated. It would have to hang from something.
  3. Jan 17, 2019 at 9:42 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    How much does it weigh? Seems if you can get the front end up on the tailgate you could slide it in.
    Looks to be 138 pounds. Can you lift 70-100ish pounds? If so set the front end up then push the back in.
    shane100700 likes this.
  4. Jan 17, 2019 at 10:16 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    That's what I was thinking.
    Or tie a rope to the front of the boat, get in the bed of the truck and pull it it. Then hop out and push it in the rest of the way.
  5. Jan 18, 2019 at 8:06 AM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    138 pounds no gear, no motor, no fuel tank or battery. Add 150 pounds unless you unload every time you load the truck. Will it even fit in the bed? I had a similar one and it would not. Unless it goes in crooked. Forget any skid system then. I used a utility trailer when i had mine.
    paleh0rse likes this.
  6. Jan 18, 2019 at 9:08 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I'd put an end of it onto a furniture dolly. Then lift the other end up and onto the tailgate. Grab the other end off the dolly and lift/push into the truck. You'll also need an extender from the hitch to support the portion of the boat that is not sitting on the bed/tailgate.
    Overall looks a lot easier than loading a 500lb motorcycle.
  7. Jan 18, 2019 at 9:10 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I foresee a back injury getting that thing out of the water and onto a tailgate. For your sake, save your back. Get a loading ramp and a dolly.
    arguscanis likes this.
  8. Jan 18, 2019 at 9:15 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Depending where you measure, the inside of the wheels wells are only 42-45” wide. The boat is 49.5” wide so it would be sitting above the wheel wells. You’ll need a platform. Then you will still have half the boat sticking out the back. Even with a long bed, that’s like 4’ sticking out. It will work but seems sketchy.
  9. Jan 18, 2019 at 9:17 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Length = 123" (10'3"). Do you have a long bed or short bed?
    Edit: Looks like shane100700 beat me to it.
  10. Jan 18, 2019 at 9:18 AM
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    it is 49.5" wide, so it doesn't really fit well (it would have to sit on top of the bed rails). Find an old utility trailer, as mentioned above. Check Craigslist. They go pretty cheap.
  11. Jan 18, 2019 at 9:19 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    like this?
    Paul631 and 13txtaco like this.
  12. Jan 18, 2019 at 9:19 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    :facepalm:
  13. Jan 18, 2019 at 9:21 AM
    coopcooper
    alberta canada
    lol that's a functional system.... but I didn't see the boat in question until after, two people could probably lift that little thing
  14. Jan 18, 2019 at 9:27 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    lol lots of things are “functional” and probably work great. I would not feel good about that system.
    Of course I’m not a fan of those sled racks where the snowmobile skids are on the roof of the truck either.
  15. Jan 18, 2019 at 9:29 AM
    coopcooper
    alberta canada
    you would be surprised how many people use those in b.c cause your not allowed to tow your boat behind your trailer haha.
  16. Jan 18, 2019 at 9:29 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Brilliant. That'll save almost 2 dollars at each toll booth. Then you can use those savings for an extra large soda and fries at the nearest drive-thru, a necessary convenience while you're waiting for the insurance adjuster because you just destroyed the nearest drive-thru.
  17. Jan 18, 2019 at 9:30 AM
    coopcooper
    alberta canada
    you just gotta remember you have a boat on your roof and its all smooth sailing from there
  18. Jan 18, 2019 at 9:31 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
  19. Jan 18, 2019 at 9:31 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    lol I’m sure! Don’t know when the laws changed, but when I moved back from HI, I noticed everyone is driving around with a camper and trailer. Each towed behind the other.
  20. Jan 18, 2019 at 9:31 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
