Load range C tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp5385, May 12, 2022.
  1. May 12, 2022 at 2:02 AM
    Jp5385
    Jp5385 [OP] Well-Known Member
    2014 TRD Sport V6 4x4
    Can anyone tell me if load range C tires look more like P metric tires or load E tires? I like the durable rugged look the Load range E tires have. Was wondering if the Load C tires had the similar look and feel with the less weight. Thanks
  2. May 12, 2022 at 2:51 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Your main issue is availability and selections depending on your preferred tire size. Go bigger and you will find very little selections in either of those load ranges. Unless you use your truck like a honda civic, go with the load C range vs a p-metric tire for payload and sidewall protection. If you decide to go up to 285's, you won't find too many choices in a C-load.
  3. May 12, 2022 at 2:55 AM
    Jp5385
    I was going to get the Cooper Discoverer AT3 LT in load C, they are available in my size. Was wondering how the Load C looked and feel compare to the E. I had load E tires on my 3rd gen 4Runner before and they were too stiff and rough for my use. I just don’t want the load C to look and feel like a p metric tire tho. So I was wondering if the C load tires are at least similar to a load E tire in looks and durability. Thanks for the reply.
  4. May 12, 2022 at 3:06 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    You will definitely feel the ride quality difference between a C vs. E-load tire given the same tire pressure. E-load is way overkill for a mid size truck like ours. I run the Cooper ATP II in a D-load at 34 psi and rides smooth for a lifted truck. Keep in mind that the quality of lift also have alot to do with ride qualty.
    wi_taco and Jp5385[QUOTED][OP] like this.
  5. May 12, 2022 at 3:11 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Here's the C version of that very tire. My third set in 265/75/16. Love em! Never had an E rated tire on my Tacoma, so I can't compare.
    jeminyned and Jp5385[QUOTED][OP] like this.
  6. May 12, 2022 at 3:25 AM
    Jp5385
    yeah the Load E were too much for me, so I’ll be sticking with the Load C this time around.
    They look nice! I’m going with the Coopers because I heard they are the best all terrain tires in the rain. I’m in NC and it rains a lot here.
    Sig45[QUOTED] likes this.
  7. May 12, 2022 at 3:37 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    The AT3 is very close to the ATP II design. Just recently got mine right before my family 2k miles trip to moab. First time going with Coopers and very happy with them. Rode great running 85 on the hwy.
    Jp5385[OP] likes this.
  8. May 12, 2022 at 4:21 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    I have had good experience with load C AT3's as well. Have about 45k on mine and they still look great. Will get another pair when they wear out.
  9. May 12, 2022 at 6:00 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I ran C Load Range BJG AT KO's on my 08 Sport 4x4 for a long time, and from what I recall, there is no visible difference in the way the tires look compared to the E Load Range tire. The difference is all internal with the number of plys within the tire.
  10. May 12, 2022 at 6:57 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    P rated tires are rated to carry more weight than your truck is rated for but generally only come in less aggressive All Terrain or street tires. If you want to use a more aggressive tread it will have to be an LT rated tire. They come in C, D, and E ratings based on how much weight they are rated for. In the same size C rated tires are rated for LESS weight than P rated tires. D rated tires are rated for the same weight and E rated tires considerably more than P's. There are other ratings, but not in sizes that would fit light duty trucks.
    C rated tires aren't really designed for hauling weight, but for guys driving SUV's like Jeep Wranglers who want a more aggressive tire. They can be used on a Tacoma, and all things being the same expect a similar ride. Personally, unless I just had to have an aggressive mud tire between C's ad P's, I'd save the money and get P's.
    E rated tires will be a tougher tire and hold up better to harsh off road driving. They are less likely to fail when driving over rocks, logs, etc. But they do ride a little stiffer. Especially on a light Tacoma.
    I've had them all at one point or another. The real difference has more to do with the tire width, diameter, and tread pattern than P, C, D, or E ratings or tire weight. Wider, taller tires rob power and hurt fuel mileage. More aggressive tires ride worse and get worse fuel mileage. If you compare the same size and type tire in both a P and E rating there is very little difference in ride quality, or fuel mileage. The problem is that few people change just one thing and it makes it harder to identify what factor is causing loss of fuel mileage and a harsher ride.
    Pedro2598 and Jp5385[OP] like this.
  11. May 12, 2022 at 7:06 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The C vs E load ride quality thing is REALLY blown out of proportion on tacomaworld. I was running C load range duratracs and got a sidewall flat so I had to replace 2 of them (less than a year old tires). Due to supply chain issues C load duratracs weren’t available at the time so I had them throw a pair of Es on.
    I’ve been running Cs in the front and Es in the rear since December and I can tell zero difference in MPG or ride since I swapped the rears to E load range. Still running the same tire pressure too.
    I was afraid it was gonna drive like a dump truck based on what folks say on here but in reality noticed zero difference.
    Pedro2598 and steveo27 like this.
  12. May 12, 2022 at 7:10 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    I went with the C-rated Nitto RidgeGrappler in 285/70/17. As others have said: Not many options at 285 for load range C but these checked all my boxes and I do like their looks compared to almost all the other c-rated tires I found in this size.
    wi_taco, jeminyned and Jp5385[OP] like this.
  13. May 12, 2022 at 9:26 AM
    Jp5385
    This was actually the answer I was looking for, thanks!
    Rocketball[QUOTED] likes this.
  14. May 12, 2022 at 11:00 AM
    plurpimpin
    PDX
    That answer is going to depend on the tire manufacturer as well. There isn't really a definitive answer to your question. Some companies make Cs look as aggressive as Es and some make Cs look less aggressive like P rated tires. Totally depends on the company and even specific model of tire.
    To contribute to the data set in my case my C and E load Goodyear Wrangler Duratracs have the exact same tread depth and appearance.
  15. May 12, 2022 at 12:40 PM
    TacoTuesday1
    FL
    I don’t understand what you mean by appearance difference. Wildpeak in C or E looks the same. E is a thicker 10-ply meant for a dually diesel towing a trailer as big as a house. I’ve heard of Fords pulling up to 40,000 pounds.
    Most ive pulled is tools and a 5x10 Uhaul trailer moving. Or loaded a pallet of wood.
    a pallet of anything from Home Depot such as bricks is usually up to 3-4K lbs.
    Have I gone over rocks? Yes.
    I have never seen a jagged rock with the point facing me on a trail and decided to floor into it like driving into a harpoon. I have literally never seen one.
    Which makes me wonder the point of E.
    If you are going slow and not doing that, or tree branches, you are probably fine.
    Then again my co worker did pop a C ko2 like that once.
    E means I never worry about popping or even puncturing it.
    my 255/80r17 tall skinnies only come as E. Probably to compensate for the lack of width.
    if I had to do it again I’d want to try C. I hope 33 285/70 or 35’s can come in C.
    e is heavy and messed up my gas mileage and acceleration
    Which probably does not affect a ford diesel because if they have a V8 with 1 or 2 turbos running diesel (a more efficient and powerful fuel than gasoline) it probably makes no difference to them
  16. May 12, 2022 at 12:57 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    actually they don’t. The c load has a more shallow tire depth, and they have less groves.
    I looked at a 285 c load vs e load. I believe the c load was like a 13-32” tire depth new and the e load is like 17-32” tire depth.
    Also on each “block” on the tire, the c load has 2 siphon cuts for the water. The e load has 3
