List of T-SBs, etc.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by salmonmigration, Aug 9, 2018.
  1. Aug 9, 2018 at 10:37 AM
    salmonmigration
    salmonmigration [OP] Well-Known Member
    2018 TRD Sport 6MT
    **I've compiled a list of all the Toyota Technical Service Bulletins for the third gen Tacoma. They are all linked below. This list is up to date as of the last edit date shown at the bottom of this post.
    **These are in chronological order.
    **Imgur likes to reorder your photos arbitrarily and will not save changes you make to photo orders. A lot of these are out of order, sorry.
    T-SB-0186-12 R2: Clutch Pedal Squeak/Creak Noise
    T-SB-0187-12 R2: Tire Repair Resources
    T-SB-0229-12 R1: Flood Damaged Vehicle Inspection and Handling
    T-SB-0083-13: A/C System Diagnosis After Component Failure
    T-SB-0026-14 R1: Tire Positioning Before New Vehicle Delivery
    T-SB-0028-14 R1: Long-Term Vehicle Storage Guidelines
    T-SB-0029-14 R1: Floor Mat Installation During PDS
    T-SB-0043-14 R2: Immobilizer and Smart Key Reset
    T-SB-0025-15: Battery Maintenance for In-Stock Vehicles
    T-SB-0072-15: Initial Calibration of Compass during PDS
    T-SB-0074-15: 2016 Tacoma Pre-Delivery Service (PDS)
    T-SB-0079-15: Intermittent 2nd - 3rd Up Shift Flare
    T-SB-0124-15: Battery Maintenance During PDS
    T-SB-0010-16: Blind Spot Monitor DTC C1AB2 or C1AB3
    T-SB-0037-16: Smart Key System Check During PDS
    T-SB-0038-16: Floor Mat Installation During PDS
    T-SB-0039-16 R1: Battery Maintenance During PDS
    T-SB-0042-16: Tire Positioning Before New Vehicle Delivery
    T-SB-0044-16 R1: Paint Stains Under Rapgard
    T-SB-0045-16: Long-Term Vehicle Storage Guidelines
    T-SB-0053-16 R1: Howling or Whistle Noise from Front Lower Control Arms
    T-SB-0077-16 R1: ECM Calibration: Shift Feeling Enhancements *thread link*
    T-SB-0088-16 R1: Difficult to Shift Out of Gear After Long Drives
    T-SB-0134-16 R1: Techstream ECU Flash Reprogramming Procedure
    T-SB-0148-16: Combination Meter - Trip Meter Intermittently Resets *thread link*
    T-SB-0170-16 R1: Wind (Reed/Buzz) Noise From Front Doors - CrossWind Conditions *thread link*
    T-SB-0171-16 R1: Driveline Vibration Under Deceleration Around 10 - 30 MPH *thread link*
    T-SB-0182-17: Interior Electrical Component Precaution
    T-SB-0185-17 R1: Smart Key System Check During PDS
    T-SB-0186-17: High Pitch Whine Noise from Manual Transmission
    T-SB-0188-17 R1: Floor Mat Installation During PDS
    T-SB-0192-17 R1: Tire Positioning Before New Vehicle Delivery
    T-SB-0195-17 R1: Battery Maintenance During PDS
    T-SB-0196-17 R1: Long-Term Vehicle Storage Guidelines
    T-SB-0213-17: License Plate Lamp Moisture and/or Blind Spot Monitor Abnormal Operation *thread link*
    T-SB-0218-17 R1: SRS Component Disposal as Hazardous Material Treatment
    T-SB-0222-17: Tonneau Cover Strap Replacement Procedure
    T-SB-0237-17: Cowl Ice Accumulation
    T-SB-0273-17 R2: Rear Suspension Silencer Pad Squeak Noise *thread link*
    T-SB-0304-17 R2: Replacement Certification Labels and VIN Plates
    T-SB-0306-17: 2018 Pre-Delivery Service Check Sheet
    T-SB-0307-17: 2018 Tacoma Pre-Delivery Service (PDS)
    T-SB-0313-17: Brake Vibration and Lug Nut Torque
    T-SB-0316-17: Knocking Noise From Vacuum Pump
    SET-SB-17-007: LED Fog and DRL 2 N 1 Light Inoperative
    T-SB-0009-18: Leather and Synthetic Leather Care Best Practices
    T-SB-0013-18 R1: Whine Noise From Rear of Vehicle
    T-SB-0016-18: Chirping Noise From High-Pressure Fuel Pump *thread link*
    T-SB-0022-18: Poor JBL Audio System Sound Quality
    T-SB-0023-18 R1: Rear Vibration or Noise While Braking
    T-SB-0024-18: Automatic/Continuously Variable Transmission Replacement Precautions
    T-SB-0053-18: Rear Door Wire Harness Symptoms and Diagnosis
    T-SB-0055-18: Water Leak at Rear of Cab - Center High Mount Stop Lamp
    T-SB-0057-18: Immobilizer and Smart Key Reset
    T-SB-0058-18 R1: Vehicle Surge Between 40 and 50 mph
    T-SB-0062-18: Stumble at Wide Open Throttle Takeoff *thread link*
    T-SB-0063-18: Lack of A/C Performance at Idle in High Ambient Temperature
    T-SB-0073-18: 2GR-FKS Engine Oil Leak From Cam Sensor Bolt Hole(s)
    T-SB-0125-18: Engine Idle Surge With Steering Input *thread link*
    T-SB-0021-19: Rust/Paint Blistering on Door Sills *thread link*
    **Below are some really old service bulletins that still apply to 3rd gens. They're kind of interesting.
    TS-PA005-04: Iron Particle Rust Contamination Repair
    TS-PD017-04: Wheel Film for Brake Rotor Rust Prevention
    BO92-005: New Vehicle Washing Schedule For Paint Protection
    BO020-91: Prevention and Repair of Acid Rain Damage
    PG94-005: Dealer Removal Procedures for Rapgard Protective Film
    **Below are "Tech Tips". They're directives to the mechanic, some of them might be helpful and a lot definitely aren't.
    T-TT-0375-15: Diagnosis of Microphone Connection
    T-TT-0377-15: Adjustment of Bluetooth Hands Free Sound Quality
    T-TT-0414-16: Diagnosis of Bluetooth Connectivity Complaints
    T-TT-0437-17: Common Head Unit Lockouts
    T-TT-0441-17: Precautions Regarding Usage of A/C Stop Leak During A/C System Service
    T-TT-0468-17: HVAC Drain Tube Blocked/Clogged
    T-TT-0475-18: Special Service Tools: Injector Seal Tool Sets
    T-TT-0476-18: Rear Differential Torque Confirmation
    T-TT-0477-18: MY17-18 Tacoma Bed Gap Measurement Method (RR Bumper x Bed & Bed x Cab)17-18 MY Tacoma Bed Gap Measurement Method (RR Bumper x Bed & Bed x Cab)
    T-TT-0484-18: Bluetooth Hands Free Call Echo
    T-TT-0490-18: Squeak Noise from Front of Vehicle On Uneven Surfaces - FR RH (No.1) Body Mount BushingOn Uneven Surfaces - FR RH (No.1) Body Mount Bushing
    T-TT-0494-18: Squeak Noise from Front of Vehicle While Driven on Uneven Surfaces - NO.1 Body Mount
  2. Aug 9, 2018 at 10:59 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
  3. Aug 9, 2018 at 11:01 AM
    salmonmigration
    2018 TRD Sport 6MT
    Thank you. I have the PDFs for this and everything else for MY 16-18 downloaded, I just need to update the OP.
  4. Aug 9, 2018 at 4:48 PM
    salmonmigration
    2018 TRD Sport 6MT
    If people want to post here with links to any threads for specific TSBs I will edit that link in the OP.
    Spike Strip and PzTank like this.
  5. Aug 9, 2018 at 4:56 PM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    Good idea. Would be nice if we could search. Maybe a sub forum with threads for each?
    bshammer0 likes this.
  6. Aug 9, 2018 at 5:43 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Great job Salmon...!! I was hoping there was one place to go and find these. they are so hard to find sometimes......:thumbsup::thumbsup::thumbsup::canada:
    kgilly likes this.
  7. Aug 9, 2018 at 6:03 PM
    tcjacado
    tcjacado Well-Known Member
    There is also this one. I don't know if it's on your list
    Taco16LB likes this.
  8. Aug 9, 2018 at 6:41 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Sticky this mods
  9. Aug 9, 2018 at 6:44 PM
    salmonmigration
    2018 TRD Sport 6MT
    I'd love to but I'll settle for posting the actual TSB documents once I get time.
    If something else wants to go through and type all that out I'm cool with that
  10. Aug 9, 2018 at 6:48 PM
    salmonmigration
    2018 TRD Sport 6MT
    Yep I just have to convert all the PDF files to images, upload them to imgur and then edit the first post with links to each. I'll get around to it.
  11. Aug 9, 2018 at 6:49 PM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Sub for later
  12. Aug 9, 2018 at 8:33 PM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    This should be stickied :thumbsup:
    KY_Rob likes this.
  13. Aug 10, 2018 at 7:23 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    This is great! My primary recommendation to keep this thread valuable would be to trim this list to the actual ISSUES folks may experience with their trucks vs. more of the maintenance, care, tip sort of stuff.
  14. Aug 10, 2018 at 9:21 AM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    why not just post the PDFs?
    tacoguy88 likes this.
  15. Aug 10, 2018 at 9:46 AM
    salmonmigration
    2018 TRD Sport 6MT
    You know a good pdf hosting website?
  16. Aug 10, 2018 at 9:49 AM
    Double Phister
    Sacramento, CA
    you can put PDFs in your post. Is there a limit?
  17. Aug 10, 2018 at 10:13 AM
    salmonmigration
    2018 TRD Sport 6MT
    I don't really want to upload 488 pages of TSBs into one post even if the site lets me.
    wvandinter likes this.
  18. Aug 10, 2018 at 11:39 AM
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    So is every Tacoma made after July now have this larger a/c cooler from the factory ??
    pwalkerttu likes this.
  19. Aug 10, 2018 at 11:42 AM
    tcjacado
    I don't know
  20. Aug 10, 2018 at 11:56 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I wonder if there’s a way to tell if you have the updated radiator? Mine blows ice cold and it’s been HOT lately?
