List of Chassis Codes. Do you know yours? VZN??? RVN???
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Jun 24, 2020.
  1. Jun 24, 2020 at 11:08 PM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Tacoma Reg Cab 2.4L 95.5-04
    RWD Chassis Code: RZN140
    Engine Code: 2RZ-FE
    Tacoma Reg Cab 2.7L 95.5-04
    4WD Chassis Code: RZN161
    PreRunner RWD Chassis Code: RZN191 (99-04)
    Engine Code: 3RZ-FE
    Tacoma Reg Cab 3.4L 95.5-97
    4WD Chassis Code: VZN160
    Engine Code: 5VZ-FE
    Tacoma Xtracab 2.4L 95.5-04
    RWD Chassis Code: RZN150
    Engine Code: 2RZ-FE
    Tacoma Xtracab 2.7L 95.5-04
    4WD Chassis Code: RZN171
    PreRunner RWD Chassis Code: RZN191 (98-04)
    Engine Code: 3RZ-FE
    Tacoma Xtracab 3.4L 95.5-04
    RWD Chassis Code: VZN150 (95.5-00)
    4WD Chassis Code: VZN170
    PreRunner RWD Chassis Code: VZN195 (98-04)
    S-Runner RWD Chassis Code: VZN150 (01-04)
    Engine Code: 5VZ-FE
    Tacoma Double Cab 2.7L 01-04
    PreRunner RWD Chassis Code: RZN196
    Engine Code: 3RZ-FE
    Tacoma Double Cab 3.4L 01-04
    Engine Code: 5VZ-FE
    wahoobie, RobA, BatteredTaco and 4 others like this.
  2. Jun 25, 2020 at 7:57 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are these code #s stamped on the chassis anywhere?
    thanks, @mechanicjon
  3. Jun 25, 2020 at 1:39 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You can find it on the white label on the B-Pillar, basically right by the front door striker. Look for the bar code, then it is just above the end of the bar code.
    It is the first half of what Toyota calls the "katashiki". The second half explains some of the upper body options.
    cruiserguy likes this.
  4. Jun 25, 2020 at 3:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so how is one to know if a particular 'chasis only' is the proper one to fit the rest without any code stamped onit?
    that is my curiosity question
  5. Jun 25, 2020 at 7:25 PM
    Wsidr1
    Indiana
    Not 100% sure I understand your question.
    Your frame has (had) VIN labels on it, just like the body. Like in the RH fender area. I recently found one hidden above the spare tire carrier lift when I was tearing the old rear frame off my truck.
  6. Jun 26, 2020 at 7:34 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was told there is a difference in chassis starting in mid '97
  7. Sep 3, 2023 at 3:14 AM
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    what are rcb and xtr chassis codes? often listed with rxn161,171 and vzn170 in parts illus
  8. Sep 3, 2023 at 10:47 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Not sure. Don't recall ever seeing those. Here's all the ones for 2000 Toyota's.
  9. Sep 3, 2023 at 10:51 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  10. Sep 5, 2023 at 11:22 AM
    BatteredTaco
    J Lo
    SoCal
  11. Mar 31, 2025 at 1:12 PM
    Silverwolf
    Silverwolf New Member
    David
    Bangor Pennsylvania
    2004 silver trd Tacoma
    In progress
    Just curious, know this post is a little old, but my sicker say vzn170L. It’s that to differentiate between extra cab and double cab?
