Line-X Rustproofing/Undercoating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cb2589, Nov 8, 2010.
  1. Nov 8, 2010 at 5:04 PM
    Cb2589
    Cb2589 [OP] Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    So I've read a little bit about this stuff, I tried searching on here to see if anyone has done it but couldn't come up with anything..
    Apparently it's the only undercoating OEM endorses? Has anyone gotten their truck undercoated with this stuff? If so how well does it hold up? Was it expensive? Did they coat the inside of the frame?
    I'm looking into it, as my 97 is virtually rust free with only 102K miles on it. And most likely won't be rusted out by the end of the 15 year warranty period!
  2. Nov 8, 2010 at 5:11 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Line-X undercoating? I've never heard of that...I thought it was a spray on bed liner. Got any links??
    edit: found this link...http://www.line-x.com/faq.htm
    scroll down towards the bottom...
  3. Nov 8, 2010 at 5:26 PM
    Cb2589
    Corey
    VA
    Yeah that's one of the things I read. I saw some pictures of a Dodge that had the whole underside of it done, body panels and all. I just wonder if they spray the whole outside and if they can spray inside of the frame.
  4. Mar 10, 2011 at 5:20 PM
    Blackbear
    Blackbear Hardtooree Member
    Maine
    2008 Blk SR5 2.7 4X4 5 spd ACab
    (DIY)...Fog lights, alloys, wheelwell liners, tonneau, frame cleanup & rustproofing, floor mats, trailer hitch.
    Old thread but good topic. From what I've read, bed liner coatings don't make the best rustproofing because they tend to chip out over time...which can let water under the coating. That's not good. Rust tends to develop fastest when moisture is allowed to enter via surface breaks, cracks and crevices...like around welds, joints, flat spots inside the frame and wherever else sand/dirt/salt can collect. A flexible barrier that 'gives' when hit or scraped but stays sealed is a better bet. I suppose that's why lots of people find that annually coating their frames with oil or grease works pretty well for rust control...it doesn't crack. Pretty messy, though.
    GQ7227 likes this.
  5. Mar 11, 2011 at 5:54 AM
    Ajl9791
    Ajl9791 New Member
    06 Tacoma TRD Access Cab
    I know this is an older thread but I have had great luck with a
    product called WaxOxy. It consists of beeswax and a rust inhibitor- oil .It stays
    soft but not sticky as to grab dirt ect. Best coating results ive ever had. The only
    site ive found it at is www.roversnorth.com . I used 4 500ml hardwax cans on my
    02 tacoma and if touched up every year your truck wont rust . Im not a salesman for
    this stuff , it works great and ive tried all meens of rustproofing.
    GQ7227 likes this.
  6. Mar 12, 2011 at 3:53 PM
    Blackbear
    Maine
    I'd like to see what DIY rust protection potions folks are using. I've heard of a 'home-made' waxoyl made of paraffin, ATF and mineral spirits. Even a thick layer of car wax (pasted or sprayed on, not rubbed off) might work as a passable seasonal winter frame/undercarriage protector. Oiling the undercarriage works, but it's wicked messy. There should be a thread on this to discuss ideas...there are too many perfectly good Tacos rusting away to ignore it.
