line x pros and cons??
Discussion in 'Product Reviews' started by ross123, Apr 24, 2012.
  1. Apr 24, 2012 at 8:45 AM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    just wondering whos line Xed there after market bumpers. and if they like it or not. i should be getting my relentless bumper by the end of may and im thinking of having it line Xed. any reviews would be great. thanks
    Rudolph_the_Taco likes this.
  2. Apr 24, 2012 at 5:18 PM
    ross123
    fort bragg
    Anyone?
  3. Apr 25, 2012 at 7:15 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I have my sliders line x'd...they haven't been done very long but so far it was well worth it! If I ever go with a plate bumper I am going to get it line x'd as well. Make sure to get the UV protected line x.
  4. Apr 26, 2012 at 12:41 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Pros: It's sprayed to last a long time..
    Cons: It's more expensive than putting on your own bedliner
    Lol If I HAD to make a con...really its 99% Pro
  5. Apr 26, 2012 at 12:43 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    If you plan on wheeling a lot, shit is going to get scratched up. Line-X is awesome, but it is hard to clean and when a rock takes a chunk off then what? IMO, you are better off using some rubberized undercoat and some rattle cans. It will cost a LOT less and will make touch ups much easier.
  6. Apr 26, 2012 at 2:08 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    For use on a bumper, I say Line-X would definitely hold up to any abuse. If your taking chunks out, you have bigger issues and your bumper is mangled. This stuff is TOUGH, especially if the shop that does it preps the surface like they are supposed too.
    As for sliders, You are right, spray paint, undercoating etc. will for sure cost a lot less. I have no intentions of "bouldering" and turning my truck into a hardcore rock crawler....so I went with Line-X. I don't see any issues with the Line X holding up to moderate/heavy trail use, and hi-lift jack usage.
  7. Apr 26, 2012 at 2:13 PM
    ross123
    fort bragg
    thanks for your input so far im leaning towards line x. but we'll see once i finally get the bumper. and thanks for the tip about the uv protected line x.
  8. Apr 26, 2012 at 3:03 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    True. I dunno in my mind I just can't justify paying to have something Line-X'd when I know it is going to get beat up. With rattle cans, I can do touch ups much easier and I am still way under what I would have to pay to get it Line-X'd. Then again my money is pretty tight so if I can cut corners somewhere I will lol.
  9. Apr 26, 2012 at 3:38 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    if your worried about 3lbs?then maybe some other issues
  10. Apr 26, 2012 at 7:36 PM
    ross123
    fort bragg
    nice!
  11. Apr 26, 2012 at 7:43 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    I had my sliders Line-X'd, last spring, just have to finally get around to putting them on. I'm looking forward to it because they look *fantastic*. The shop blasted then primed them with a line-x primer, then coated them. Kept the material away from the mounting brackets in case I did decide to weld vs. bolt.
    Not to hijack the thread, but these sliders (Trail Gear?) give me the option to drill and bolt or weld on. Comments? My new MIG lays down some pretty darn nice beads, so I'm really tempted to go that route...
    Cheers,
    Marc
  12. Apr 26, 2012 at 7:47 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Is the MIG STRONG enough?
