Line Out Converter Help needed- which harness wires to tap?
Discussion in 'Audio & Video' started by Slider57, Mar 6, 2014.
  1. Mar 14, 2014 at 11:54 PM
    Jwheeler
    Jwheeler Active Member
    Josh
    Washington
    trd off-road sr5 leveled
    Leveled with 33's
    Well I'm about to tackle a bit more complex loc either this weekend or next just got my audio control dq-61 today and have the itch to install everything. I will try to remember to take pics a write about it when I do it. Bye bye crappy sound!! You won't be missed!
  2. Mar 23, 2014 at 4:07 AM
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    So for a 2014 non-JBL system would wiring harness adapters like the Best Kits BHA1761 and BHO1761 allow me to add upgrades with the Entune HU without having to modify the OEM wiring harness?
    Norton likes this.
  3. Mar 23, 2014 at 10:10 AM
    looking4vr
    looking4vr Well-Known Member
    Brad
    Lusby, MD
    17 DCSB TRD OffRoad 6MT
    Bone Stock, for now
    That is 100% correct.
  4. Mar 24, 2014 at 11:08 PM
    616tacoma
    616tacoma Active Member
    Richmond,TX
    2013 black taco 4x4
    Which one is the 12v power and ground wire?
    Pin D and pin G?
  5. Mar 25, 2014 at 4:31 AM
    looking4vr
    Brad
    Lusby, MD
    Bone Stock, for now
    That's correct....is this for powering an accessory? They should NEVER be used to power anything that draws any serious current! Anything 4-5 amps and lower "should" be OK but anything higher and you should be grounding to chassis near the component and taking the power source with a fused wire directly from the battery. :thumbsup:
  6. Mar 25, 2014 at 12:02 PM
    616tacoma
    Richmond,TX
    2013 black taco 4x4
    Thanks man it's to power my loc with turn on lead
  7. Mar 25, 2014 at 1:28 PM
    looking4vr
    Brad
    Lusby, MD
    Bone Stock, for now
    Roger that. You're good to go.
  8. Mar 29, 2014 at 7:30 AM
    deadbird8
    Dallas, TX
    14 4x4
    Does that 12V power anything else? I am planning to power a LOC which only has a 1A power draw. I can run a fused link all the way to the battery, but that seems like overkill for such low power draw. If I used that 12V off the radio harness do I just 'T' into it?
  9. Apr 21, 2014 at 9:29 AM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    So for a 2014 Entune, I'd use H and I as the remote turn on to turn on an amplifier? What does it mean to "join wires 1 and 2 to the blue wire?"
  10. Apr 22, 2014 at 9:01 AM
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    Subbing for this info because eventually I will be upgrading everything except the HU
  11. Apr 23, 2014 at 4:34 AM
    deadbird8
    Dallas, TX
    14 4x4
    The blue Pwr Ant wires on the harness have a jumper at the connector on the back of the radio that connects those two wires (H and I) together.
    I just installed a LOC, 4 ch Amp and replaced speakers connected to my 2014 OEM Entune Head Unit. The LOC takes the Head Unit amplified signals and converts to a pre-Amp signal. My LOC is an Audio Control LCQ-1 which is basically a LCi6 with integrated equalizer.
    I used Metra male and female Toyota OEM audio connectors so I didn't have to tap into the stock harness for install, extending the Power (D), Ground (G), Pwr Ant (H/I) and Speaker wires to my LOC under the front seat. I then ran another wire from the LOC Remote Out into the Amp's Remote In to turn it on.
    I am replacing the LCQ-1 as soon as possible. Although there is no distortion in the system. The stock head unit produces a hiss that once you install an amp, you can hear when you put a CD on pause or have the system at low volume. With the Audio Control unit installed, the hiss is really bad and can only be tuned out by taking down the gain on the LOC or turning the Amp gain way down. I was at a shop today where they were checking it out. They installed Audison SLI-2's in place of the LCQ-1 and it cut the hiss down by half to tolerable level without changing any settings on the amp. The LCQ-1 is just adding to the problem.
  12. May 16, 2014 at 6:40 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
  13. May 18, 2014 at 7:04 PM
    AiNoFaKNKeA
    AiNoFaKNKeA Well-Known Member
    Hawaii
    '14 TRD Sport DCSB
    885's w/ 1/2" spacers on OME Sport Nitros OME Dakars w/ Sport Nitros & D29XL AAL 285/65 BFG AT KOs on 18" Dropstars 645B 0 Offset 4.5" BS Spidertrax 1.25" Wheel Spacers LED Interior and Exterior 6K HID Headlamps and Fogs 6K LED DRL Switchbacks Pop and Lock Codeable Smart Lock Tailgate Handle Debadged Wet Okole's Front and Rear Weathertech Digital Fit Floor Liners Husky Liners Custom Molded Mud Guards Tint AMP Research Bed Step AMP Research Bed Extender ImMrYo Rear-View Mirror Lift Bracket Viper Alarm ICE: Alpine PDX-V9 Audio Control LC6i Image Dynamics CTX65CS Image Dynamics CTX65 Image Dynamics IDQ12 KnoKnoise Sound Deadening
    How do wire an amp for a sub on a '14 non-jbl system that has no oem sub, meaning where do I get the sub signal from? Planning on keeping the factory unit and using an Audio Control LC6i.
  14. May 19, 2014 at 4:42 AM
    deadbird8
    Dallas, TX
    14 4x4
    You'll have to find a device that will sum the inputs to produce a sub output. The LC6i is supposed to do that- you wire in the front and back from the HU and it will sum one of those inputs to produce a 3rd RCA output to feed the amp for the sub.
    Just FYI- I didn't have good luck with the Audio Control components (LCQ-1 which is basically an LC6i with equalizer). When hooked up to the stock HU it produced a hiss which I couldn't tune out (tried everything AC suggested, they have had problems with both Toyota and Volkswagen systems with this issue). At a shop we replaced the LCQ-1 with a passive LOC from Audison (SLI-2 I think) and it cut the noise by more than half so the AC component was definitely making it worse. I replaced the LCQ-1 with an Audison Bit Ten processor and am much happier with the system.
  15. May 19, 2014 at 8:25 AM
    #35
    skootx
    Erie, CO
    Do you have a link or part#? I looked on Metra's site and the only harness adapters I found are just for speakers.
  16. May 19, 2014 at 9:40 AM
    #36
    AiNoFaKNKeA
    Hawaii
    '14 TRD Sport DCSB
  17. May 19, 2014 at 10:14 AM
    #37
    AiNoFaKNKeA
    Hawaii
    '14 TRD Sport DCSB
    Do you still have the hissing noise with the Audison Bit Ten?
    Does anyone else have the same problem with with LC6i, as it is something that I planned on using?
  18. May 20, 2014 at 4:47 AM
    #38
    deadbird8
    Dallas, TX
    14 4x4
    Those are the ones (each is a set of 2 connectors), one set is female which plugs into the head unit and one set is male which plugs into the harness. You tap the wires in between.
    The hiss is originally produced from the stock head unit- its a 'feature' that came with the truck. I can plug an iPod into the RCAs on my amp and the signal is flawless so we confirmed its upstream from the amp. Since the gains are very low with the stock system, you can't hear the hiss as its masked in the noise floor. You can eliminate it all together by replacing the stock head unit (which a lot of people recommend on here).
    Now compared to the stock system and speakers, with either the LOC or Processor, amp, and replacing the OEM speakers was a night and day difference in the overall audio. The Bit Ten is more configurable than the AC (you set it up with a lap top plugged into the unit) and you can lower the channel gain on it to really reduce the hiss but turn the amp gains up to compensate without retarding the system. The noise is still there but at a much lower level that you have to really listen for it (especially with the truck running).
    With the LCQ-1 installed, the hiss got much worse. I could really reduce the noise by turning down the Output Levels on the LCQ-1 to ~50% but it retarded the overall system sound output. I could also tone it down by adjusting (-) the 8kHz equalizer setting but that made the music sound like crap. What made me scrap the AC unit was when we set up the system at an audio shop and swapped the LCQ-1 with a high quality passive LOC and the hiss was immediately cut by more than half so we knew the noise was coming from the stock HU and the AC unit was adding to the problem. I went back and forth with Audio Control (who was very helpful) and tried every jumper setting etc... but just put it up on Craigslist in the end.
    I found a lot of information about the hiss after the fact when I was trying to tune it out. On this forum, Tundra sites, Prius sites, DIY Audio, etc.... Example, here is a post from just this week:
    http://www.tacomaworld.com/forum/audio-video/247641-audio-control-lc6i-2.html
    Seems a lot of people just turn up the volume and live with it as the overall system performance is 100% better than the stock setup, but the hiss was very distracting to me and especially noticeable when you put a CD or iPod on Pause. It just drove me nuts.
    Maybe others will chime in as well. Whatever you end up doing, good luck with your decision.
  19. May 28, 2014 at 6:20 PM
    #39
    skootx
    Erie, CO
    Is this the correct jack to tap from? 2014 Entune with nav, no JBL.
  20. May 29, 2014 at 7:09 AM
    #40
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    This is correct. However, this is what I found during my install. First of all I have a 2014 model Entune Plus no/Nav or JBL. Both of the connectors will fit into the chassis harness without a problem. The issue is the radio side. I had to trim both plug ends to accommodate the radio plug. You should take a look and find out what needs to be trimmed. One item is the flat recessed area of the plug. You'll find it needs to be trimmed all the way to the end of the plug. Also needed trimming is one of the slide channels. I had to do this to both plugs in order to easily slide in the back of the radio.
    Brent.Bower likes this.
