limited slip rear vs. locking diff.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dgc1, Feb 23, 2014.
  1. Feb 23, 2014 at 9:00 AM
    dgc1
    dgc1 [OP] Active Member
    I'm looking at 09 Tacoma it has the SR5 package. It is 4x4 with limited slip, with just normal four wheeling do you need a locking diff. What is the good points an the bad?
  2. Feb 23, 2014 at 9:05 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    Rear Locker is superior to limited slip in gaining traction
  3. Feb 23, 2014 at 9:16 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Limited slip & locker are basically what they say.
    Limited slip- limits slip of the wheels. Fairly useless.
    Locker- locks both rear wheels together. Zero difference of wheel speed between the rear tires when the locker is engaged.
  4. Feb 23, 2014 at 9:26 AM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    The benefit of a rear locker is when one of the wheels has no traction and the other one does, all the power gets transferred to the wheel that has traction.
  5. Feb 23, 2014 at 9:38 AM
    Spoonman
    Jamie
    Alberta
    Not quite..
    Each tire gets the same amount of torque, always. Whether a tire is on the ground or in the air.
  6. Feb 23, 2014 at 9:41 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Kind of a big question there. It all boils down to what your doing with your truck. If you aren't offroading too much, i would just stick with the truck your looking at. The sport and offroad models both act the same in 2wd and 4hi, but the offroad has atrac and then the locker in 4lo which is a key factor when buying a tacoma for alot of people. I offroad about every other wknd here in the S.E. and i've never really had an issue with getting stuck. I have a 2010 sport which doesnt have a locker, but have done the yellow wire mod which helps a little. Use the search button on here and you will find alot of valuable info. There are a ton of right ups on this topic. Either way, you will end up with a nice truck. And if you decide you need a locker in the future, get an ARB and be done.
  7. Feb 23, 2014 at 9:42 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Isn't that what limited slip is technically supposed to do? I know it doesn't work right but that's the idea behind it. With a locker, they both spin at the same rate and torque whether they have traction or not.
  8. Feb 23, 2014 at 9:42 AM
    Manwithoutaplan
    ID
    so very true. LS sux ass for off roading.
  9. Feb 23, 2014 at 9:50 AM
    916TacoTruck
    Inyo mom
    2019 Rapturd
    When the rear is locked all torque is transferred to both wheels equally. When one wheel is in the air free spinning, it on uses the torque required to move the wheel. The rest is used by the wheel that is on the ground. Wheel speed is the same.
  10. Feb 23, 2014 at 9:57 AM
    916TacoTruck
    Inyo mom
    2019 Rapturd
    With limited slip in a off road condition, it basically delays when the slip will occur. It can not prevent wheel slip from happening. Don't expect to get out of a situation with limited slip.
  11. Feb 23, 2014 at 10:22 AM
    Grenade187
    Grenade187 Well-Known Member
    Eric
    Vancouver, BC
    07 TRD Sport 4.0L V6 SR5 DCLB
    Camburg +3.5 Long Travel kit, Fox 2.5" Body 8" Coilovers with Remote Res, Radflo Air Bumps, Total Chaos coil bucket gussets, cam tab gussets and spindle gussets; All-Pro front bumper and IFS skid; All-Pro standard leaf pack; Ubolt flip; shackle flip; Timbren bumps; Radflo 2.5" body extended travel rear shocks, remote res with comp adjust; Magnaflow cat-back; Doug Thorley long tube headers, and off-road Y-pipe; URD TCAI
    Another thing to consider is that in 09 they went from a true mechanical LSD to an electronically simulated LSD that uses the brakes to prevent wheel slip. A lot of people think the mechanical one is better, I tend to agree. If you off-road with your truck a lot, you should get a locker, you won't regret it.
    A limited slip is only capable of transferring about 15% of the power from one wheel to the other, so it's just for helping get traction in slippery conditions during normal driving. It's better than an open diff, but for off-roading a locker is the only way to go.
  12. Feb 23, 2014 at 4:38 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    With light wheeling the limited slip will be fine. I wheeled the hell out a rig years ago that had a limited slip as part of its of f road package. I never wished for a locker and always had excellent traction. Wheeling in New Hampshire is rocky, muddy, or any combination of the above on old logging trails or long abandoned roads.
    Beavis can back me up on the off road abilities of a LSD equipped 1st gen nissan pathfinder.
