Lightweight vs Bigger tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JackJoachim, Feb 23, 2022.
  1. Feb 23, 2022 at 1:43 PM
    JackJoachim
    JackJoachim [OP] Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Posted this in the Wheel and Tire forum but still undecided.
    Picking my truck up in a few days and have been going back and forth on tire choice for months now.
    Here is the TLDR:
    2022 TRDOR 6MT
    Going to run Enkei RPT1 16x8 ET0, no suspension mods besides SuperSpringsbumpstops.
    I am deciding on 265/75/16 or 286/75/16.
    My two options I am choosing between mainly comes down to weight and looks.
    Would you rather lose 20lbs of unsprung weight, but run the smaller 265/75/16 tires? Or run the larger 285/75/16 tires and gain 36lbs of unsprung weight?
    My main worry is choosing the lighter setup and wishing I went bigger. But also I don’t want to choose the heavier/bigger setup and the truck feel sluggish and ride rough. This is will be my first truck, mainly planning on exploring some national forest in the area and ultimately be my DD.
    Data for nerds:
    WheelWeight (LBS)
    Enkei RPT1 16x8 ET0 18lbs
    Stock TRDOR Wheel 25lbs
    Tires
    Cooper Adventurer XLT 285/75r16 54lbs
    GY WrangerUltraTerrain 265/75r16 40lbs
    GY Stock Tire 265/70r16 38lbs
    Stock:
    Edit: I’ll update the math when I get home.
  2. Feb 23, 2022 at 1:47 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    for your purpose, Daily Driver, and national forest roads, 265/75/16 will work very well.
  3. Feb 23, 2022 at 1:49 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I'll summarize the thread before it starts;
    Its a truck, who cares about mpg, get a prius, blah blah.
    That being said, looks like you've done some research on the matter and trying to make an educated decision, but conflicted with wants vs needs. At the end of the day, just join the crowd and go big and be happy. MPG sucks no matter what you do to the truck, and drivability decreases with each and every mod, so might as well just build it as much as your heart wants. Congrats on the new truck!
    FWIW, my personal opinion is the truck will do what you want it do and more on the stock tires. But our hearts want an aggressive tread pattern and lift, so we go big, and pay the price.
    JackJoachim[OP] and TacoManOne like this.
  4. Feb 23, 2022 at 1:49 PM
    Montana_Actual
    Montana_Actual ;)
    I remember your posting(s).
    As others said: Keep it simple. Don't overthink it. You should avoid the 285's unless you want to deal with rubbing - because stock height you will rub even during DD.
    Don't lose sleep over it. Get the tires and rims you like. 265's won't make that much of a difference in weight. If you have to keep posting over and over, you are over thinking it.
  5. Feb 23, 2022 at 1:50 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Lighter for sure. Less stress on the suspension, better handling, better acceleration, better mileage.
  6. Feb 23, 2022 at 1:51 PM
    Ferball
    Ferball Well-Known Member
    Brent
    Unity, New Hampshire
    2019 Cement TR5
    I would go bigger if you are planning on venturing off pavement. I can't imagine that you will notice a difference in steering geometry and performance if you are not messing with your suspension.
    JackJoachim[OP] likes this.
  7. Feb 23, 2022 at 1:52 PM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    You realize that you're going to have a ton of rubbing issues with 285's on stock suspension right?
  8. Feb 23, 2022 at 1:52 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Its all in what looks best to your eyes. I like the looks of the 285/70/17s but I run a 265/70/17 toyo at2s. I prefer to not cut,trim,loose power, loss of gas mileage, added weight and more wear and calibration issues. I know these can all be overcomed but knowing a 265 will do me just fine as it looks good on a 2/1 lift like I run. I may do 285s but its a long shot.
  9. Feb 23, 2022 at 1:54 PM
    JackJoachim
    Jack
    North MS/Memphis
    Not exactly, 16x8 ET0 plus the smaller 285 that the AT3 XLT is I should only have to do some slight massaging with a heat gun if anything.
  10. Feb 23, 2022 at 1:56 PM
    Off Topic Guy
    If you're not messing with lift or upgrading UCA's to get alignment to push the wheel forward, you may be in for a surprise; especially if you plan to flex any.
  11. Feb 23, 2022 at 1:58 PM
    ndmak
    ndmak Well-Known Member
    edit: my bad didnt read enough to see r16
  12. Feb 23, 2022 at 2:08 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    You theoretically could go with a 255/85R16 as well. Makes them taller and a little skinnier with no trimming/rubbing based on OEM rims. Would unfortunately be heavier due to needing E rated at that size (not sure if it applies to every single tire manufacturer).
  13. Feb 23, 2022 at 2:09 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I went with 265/70/17s. My wife actually has been encouraging me to move up to 285 because they look better. My wife's boyfriend thinks I should stick with the smaller tires... Just no winning.
    You're just stuck. If you get the bigger tires you'll fixate on your gas milage and troubleshoot that rub in reverse while turning. If you get the smaller tires you will look at other trucks and wish you were a little bit taller. Or maybe you are a half-full kind of guy. Then you will be happy every time you fill up your truck because your gas milage would have been worse on bigger tires or smile every time you walk out to your slightly cooler looking truck. For your happiness and sanity I hope you are a glass-half-full kind of guy.
  14. Feb 23, 2022 at 2:11 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    Falken Rubitrek looks like it may be a decent light weight option. Due to me starting to travel for work and high fuel prices I am pulling off my 285s and going to a 245. Plus, I can save my new tires and some cash for my Colorado trip in the spring.
    JackJoachim[OP] and 18CHUÑO like this.
  15. Feb 23, 2022 at 2:25 PM
    Montana_Actual
    Montana_Actual ;)
    No man, you are going to rub the cab mount.
  16. Feb 23, 2022 at 2:32 PM
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    Look at Firestone Destination X/T. They are E-rated but light.
    JackJoachim[OP] and Boco10 like this.
  17. Feb 23, 2022 at 2:35 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Yes!
    10ply E rated LT tires are stiffer, heavier, and will negatively change the acceleration, braking, and suspension characteristics
  18. Feb 23, 2022 at 2:46 PM
    xndak
    xndak Well-Known Member
    2023 Off Road
  19. Feb 23, 2022 at 2:48 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If it's about the width...
    In 265s, there are a some tires that run 1/2" wider(8.5")in tread width when compared to like size(8"). BFG KO2s and Falken AT3W come to mind...
    Most 285s run 9" in tread width, regardless.
  20. Feb 23, 2022 at 3:01 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A skinnier 33” tire would help with weight. I have 16” SCS SR8s and 255/85/16 ST Maxx for a per corner weight increase of 15lbs over the stock wheel/tire combo.
    JackJoachim[OP] and BamBeds like this.
