Lightest A/T?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REC, Apr 5, 2022.
  1. Apr 5, 2022 at 10:35 AM
    REC
    REC [OP] New Member
    Ron
    09 Tacoma 4x4 V6
    3” coil overs, rear air bags, 33” Super Swampers on 17” for off-road and spare mounted underneath and A/T on 16” highway.
    Looking for lightest A/Ts on Stock 16”for 09 Tacoma 4x4 V6. Driving on pavement for best mileage
  2. Apr 5, 2022 at 10:37 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    What size? Your profile says 33"
  3. Apr 5, 2022 at 10:39 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Stay with anything C-Rated and you should be fine with any tire in that load range. Most people having mpg issues are e-rated tires.
    Island Cruiser and TegoTaco like this.
  4. Apr 5, 2022 at 10:45 AM
    REC
    REC [OP] New Member
    Ron
    09 Tacoma 4x4 V6
    Yes, I have 33” on 17” for off road ( mileage is around 11).I also have a set of A/T wranglers on 17”(up to 21 on mileage) But, I would like to put some light A/Ts on my stock rims for the highest mileage I can get.
  5. Apr 5, 2022 at 11:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you are looking for highest MPG, an AT tire is NOT what you should be looking at.
    You need something like the Michelin Defender LTX M/S in a SL rating, if you really want the mpgs go with a 245/75R16
    https://www.tirerack.com/tires/tire... White Letters&partnum=47TR6DLTXOWL&tab=Sizes
    You also wont find a better longer lasting tire than the LTX M/S. It easily beats out an AT tire in EVERYTHING (road noise, rolling resistance, longevity, dry grip, wet grip, ice grip). About the ONLY thing an AT tire will be better at its looks, and MAYBE deeper snow/mud.
    ardrummer292 and TacomaMike37 like this.
  6. Apr 5, 2022 at 11:08 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A few pounds of tire weight has very little to do with your fuel mileage. I've had tires that weighed 38 lbs each, and tires that weighed 53 lbs each. My fuel mileage never changed. But I stayed with the same size, and a similar mildly aggressive tread pattern. The heavier tires do hurt acceleration. You'll notice it when pulling away from a stop, especially if driving aggressively or when merging into traffic from an on-ramp. But once up to speed it doesn't take any more power, or gas, to keep heavier tires moving. It might require more brakes to stop you and potentially you'll wear out brakes sooner.
    It is when you go to larger diameter tires, wider tires, and tires with aggressive tread that kills fuel mileage. Keeping them properly inflated matters too.
    I currently have a set of these on my Tacoma in 265/75/16. That is a 31.5" tire and about the most aggressive tread I've found in a non-LT rated tire. If you're going to stay with a 33" tire you're gong to have to get a heavier LT which will cost more and have an impact on acceleration. The larger size will also impact fuel mileage, but not the weight. If you want to stay with 33" height get the narrowest tire you can find and avoid mud tread.
  7. Apr 5, 2022 at 11:27 AM
    REC
    REC [OP] New Member
    Ron
    09 Tacoma 4x4 V6
    Well, let’s see. My SS are 33”x9.5 heavy estimate (62 pounds)my wranglers are 32x10s and nothing now on my stock rims. I competed in mud a long life ago. 35 years ago. Full size 79 Ford 1 ton with 40s. Had a lot of fun. Too old and hurt to do that anymore. I do know about mud and snow. But tires have changed so much. I was thinking with so many people driving all types of tires on and off road. I would like to see who has the lightest tire for a 16” rim for the best mileage. I figured I could get a A/T or highway tire.
    Thank you all for help. REC
  8. Apr 5, 2022 at 11:33 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Hey. So I work in construction which requires me to sometimes go off road. What type of tires would I need?
  9. Apr 5, 2022 at 11:35 AM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
  10. Apr 5, 2022 at 12:05 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    What he said. Great tire.
    But then again, 90% of the trucks/jeeps I see with AT heavy threaded tires, well, they havent ever left the pavement. All about looks over function for most people.
    SwollenGoat and nd4spdbh[QUOTED] like this.
  11. Apr 5, 2022 at 3:46 PM
    REC
    REC [OP] New Member
    Ron
    09 Tacoma 4x4 V6
    I love Super Swampers. But that being said. They are strictly off road only for me. I like my A/T wranglers for driving on pavement. It usually only takes me less then an hour to switch them myself. I will have to keep looking at specs for my 16” wheels. I saw some at 30 plus pounds. Thanks REC
  12. Apr 5, 2022 at 5:08 PM
    SwollenGoat
    Could get a second of wheels, takes me 10 minutes to pull off my snows and swap on the summers. Think it takes me longer to pull the jack and tools out of the garage than swapping the wheels.
