Lightest 265/75/16 tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sean42, Dec 4, 2021.
  1. Dec 4, 2021 at 3:28 PM
    Sean42
    Sean42 [OP] Well-Known Member
    Which A/T tires are you running? Lighter the better and excluding E rated.
    Gen3TacomaOBX likes this.
  2. Dec 4, 2021 at 3:31 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Quite a few SL tires from different brands. Check @Discount Tire.
  3. Dec 4, 2021 at 4:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I have these
    Goodyear Wrangler UltraTerrain AT | Discount Tire
    They are the most aggressive non-LT tire I have found. I'm pleased with them.
    Don't overthink the weight issue. I've had my truck for almost 15 years and over 220,000 miles. I've had P rated tires that weighed 38 lbs and I've had E rated tires that weighed 53 lbs each. The E rated tires cost more, ride a little stiffer, and I could feel a minor loss of acceleration with them. But fuel mileage has never changed.
    I have not gone any bigger than 265/75/16, and I've avoided aggressive mud tires. Those are the things that will kill fuel mileage.
    tacoman45 likes this.
  4. Dec 4, 2021 at 5:16 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Factory load rating
  5. Dec 4, 2021 at 6:16 PM
    Sean42
    I got a single cab 4 cylinder with manual. Options are…
    Stick with wimpy but economical 245/75/16 highway tires.
    Beefy 265/75/16 but SL rated keep that weight down but not the cool brands.
    F it and go K02’s, Goodyear’s and Let the haters hate.
  6. Dec 4, 2021 at 6:27 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Falken Wildpeak AT3W, 265/75r16. Weigh 43lb. Lighter than the KO2 they replaced, which weighed 53lb.
    EDDO likes this.
  7. Dec 4, 2021 at 6:42 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This would be my recommendation as well. I was looking for a good compromise of weight, aggressiveness, performance, looks and price. Ended up going with the Wildpeak and have been very happy. Despite them not being load E they have done FANTASTICALLY on the trails, including some fairly sharp, rocky trails. I've since moved up to some 33" pizza cutter MT's but may go back to an AT.
    Here's a table I made when I was tire shopping. This info is a couple years old now so some of these weights may have changed, there may be new options out there...etc.
  8. Dec 4, 2021 at 6:48 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    The Nokian Rotiiva A/Ts are 37lbs in 265/75/16. I have them in 265/70/17 and they have been good for me.
    Monkeybutt2000 and TacoFergie like this.
  9. Dec 4, 2021 at 10:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    If out put in helium it will also have some weight savings.
    Squirt likes this.
  10. Dec 5, 2021 at 9:53 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Been running these in the 265-75-16 for a year now. Great tire,quiet and awesome in the snow.
    Squirt[QUOTED] likes this.
  11. Dec 5, 2021 at 10:03 AM
    Squirt
    Ben
    That's good. I think I've put around 10k on them and they are wearing even and haven't worn the 100% marker totally off yet because I can still see a little of the number. I did the chalk test right after they were put on to get a correct psi. I didnt see much of a MPG drop either. A tad louder than the worn out Bridgestone Dueler 684ii's but seem just as good if not better with ride and handling.
  12. May 27, 2024 at 10:04 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Goodyear Workhorse AT in 265/75r16 SL rated are 38.25 lbs according to multiple tire websites.
    cjtaylor37 likes this.
