Lightbar shortage turns on by itself HELP
Discussion in 'Lighting' started by Ambiguouse, Dec 9, 2017.
  1. Dec 9, 2017 at 3:53 PM
    Ambiguouse
    Ambiguouse [OP] do you even taco
    Steven
    Riverside, CA
    2015 Tacoma PreRunner Double cab
    -coil spring double wishbone front suspension - rear leaf spring suspension with staggered gas shock absorbers - 16" styld steel wheels BFG tires - engine skid plate - off road tuned suspension with bilstein shocks - 20% front windows tint - limo tint back door widows
    My lightbar switch says it’s off but the bar itself still turns on and starts blinkering while the switch says off. I was washing my truck right now and out of nowhere noticed my bar was turned on not to it’s full power but just a very dim light enough to notice that it’s on. And check the switch button and it’s says off but slowly turns on it’s own. Maybe it’s a shortage?? Some help is really appreciated right now thanks :confused:
  2. Dec 9, 2017 at 4:02 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    It’d help if you explained how you wired it
  3. Dec 9, 2017 at 4:06 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I’d re wire the entire thing
  4. Dec 9, 2017 at 4:11 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    :eek:
    Maybe a pay a professional to wire your light bar :thumbsup:
    Ambiguouse[OP] likes this.
  5. Dec 9, 2017 at 4:14 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Water in connection
    yeos, TomTwo and Ambiguouse[OP] like this.
  6. Dec 9, 2017 at 4:15 PM
    Supertaco12
    Supertaco12 Member
    2012 Tacoma TRD off road
    If Possible, unplug the switch to see if the light bar turns off complete. That should help you eliminate a bad switch.
  7. Dec 9, 2017 at 4:25 PM
    Ambiguouse
    Steven
    Riverside, CA
    Psh i am a professional ...kidding:(
  8. Dec 9, 2017 at 4:27 PM
    Ambiguouse
    Steven
    Riverside, CA
    It’s weird I’ve had my bar for almost 3yrs and it’s never happens before and neither during washing my truck. I just moved a few wires and it seemed to stop flashing and turning on it’s own maybe it was the water ..
  9. Dec 9, 2017 at 4:30 PM
    Ambiguouse
    Steven
    Riverside, CA
  10. Dec 9, 2017 at 4:35 PM
    chrisrocks300
    Brandon, MS
    Well first off I wouldn’t recommend putting two wires in the same connector
  11. Dec 9, 2017 at 4:39 PM
    Ambiguouse
    Steven
    Riverside, CA
    Doesn’t seem to turn on it’s own anymore. I just disconnects and reconnected the white plug a couple times. I don’t even know how long i was Driving with it turning on by its own wow good thing i finally fixed it before i got pulled over for it be on
    chrisrocks300 likes this.
  12. Dec 9, 2017 at 4:42 PM
    Ambiguouse
    Steven
    Riverside, CA
    Really why is that? 4 wheel parts recommended me to do that :(
  13. Dec 9, 2017 at 4:45 PM
    chrisrocks300
    Brandon, MS
    Actually, it might be ok. What is the other wire running to? The switch? I know sometimes when you’re running stacked connections you can get some electrical interference, but that was running a light bar with a cb radio on.
  14. Dec 9, 2017 at 4:48 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I am going to guess the relay is in the engine bay and not waterproof. Remove the relay from the harness and open it up. It probably has buildup on the contacts.
    yeos and Ambiguouse[OP] like this.
  15. Dec 9, 2017 at 4:51 PM
    Ambiguouse
    Steven
    Riverside, CA
    This is the other wire that’s connected the other two red ones are to the battery. I’m not sure maybe the connection was dirty or wasn’t plugged in correctly but it seemed to work once i disconnected them and reconnected
  16. Dec 9, 2017 at 4:53 PM
    chrisrocks300
    Brandon, MS
    That wasn’t the one I was talking about, did the light bar come with a wiring diagram? One of those wires might have supposed to have been run to a switched fuse
  17. Dec 9, 2017 at 5:01 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Disconnect everything and start over or buy a good Fire Extinguisher :bananadead: Just my .02
    Ambiguouse[OP] and chrisrocks300 like this.
  18. Dec 9, 2017 at 5:04 PM
    Ambiguouse
    Steven
    Riverside, CA
    No need for a extinguisher i rather just suffer the consequences :devil:
  19. Dec 9, 2017 at 5:08 PM
    TomTwo
    Bill
    I-85 Southbound
    Daredevil or you have good insurance your call:oldglory:
  20. Dec 9, 2017 at 5:42 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Check the relay for water inside of it. I drove my truck in a snowstorm and my led bar started flickering on and off. I had to pull the fuse to get it to stop. The relay was full of water after snow had collected on the hood, melted, and seeped onto the light bar harness.
