Light Pattern Recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NJOffRoad, Nov 13, 2022.
  1. Nov 13, 2022 at 4:42 PM
    NJOffRoad
    NJOffRoad [OP] Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    Hey guys,
    I'm thinking about adding a SSO hybrid front bumper to the truck to give me a spot for a winch and add some protection. I figure it can't hurt to add the light bar cutout also, but it might look a bit odd to have 2 light bars so maybe I go without one.
    Question is, if I add the light cutout, which light beam pattern should I go with? I currently have:
    2 Squadron Pros on A pillars - Wide Cornering Amber
    2 Squadron Sport Fog Lights - Wide Cornering Amber
    1 30" S8 Bar - Driving Combo Amber
    Future Additions Anticipated - 40" S8 on the roof with a spot pattern (also amber)
    This currently gives pretty awesome coverage all over, and I can't really decide on what would be the best pattern to add to the metal bumper. Maybe Spot pattern? Or would another Driving/Combo really light up the scene and make more sense, since the spot pattern will be covered when I get a roof rack and mount another bar up there?
    I get this is kind of a ridiculous problem to have, but I'm really unsure what pattern would be the best addition for the 2nd front bumper light bar. I could go without a light bar here altogether, but the bumpers look better with the light bars I think.
    @Baja Designs what say you? Would I get any real benefit from adding a second driving/combo light bar (say adding a 20" S8 driving pattern to the 30" S8 driving pattern I already have) or should I go with something different like Spot or Wide Cornering? Maybe go with clear lenses instead of amber? Any input is appreciated and I apologize in advance for having such a "1st world problem", but I don't know of a better place for advice.
    Baja Designs likes this.
  2. Nov 14, 2022 at 9:28 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @NJOffRoad,
    Adding an additional 20inch S8 will only give you an option for less light when needed. If you are planning on running the 30inch and the 20inch at the same time you will get the same distance out for each size but your left-to-right spread will be much greater with the 30inch. One option if you are looking into adding in an additional 20inch light bar would be the ONX6+. This will be more powerful and you will get more distance out of this if you were looking to run it with the 30inch as well. for the lens pattern, you could pair the S8 20inch in an amber-wide cornering to get more nearsighted light since you won't gain distance while utilizing the 30inch S8. If you do the ONX6+ I would use a spot lens pattern.
    S8 20inch Wide Corner Amber:https://www.bajadesigns.com/products/s8-straight-led-light-bar/?sku=702014
    ONX6+ 20inch Spot:https://www.bajadesigns.com/products/onx6-straight-led-light-bar/?sku=452001
    Best,
    Brandon
  3. Nov 15, 2022 at 7:17 AM
    NJOffRoad
    Anthony
    Pine Barrens, NJ
    @Baja Designs I appreciate you giving me some feedback. Question... Do you make either light bar, S8 or Onx6, in amber with a spot pattern? Can't seem to find that, only clear lenses. I know you do the squadrons in spot & amber configuration, so I thought you would for the bars too.
  4. Nov 15, 2022 at 8:11 AM
    Baja Designs
    San Marcos, CA
    Hey @NJOffRoad, We unfortunately don't have an amber spot lens pattern as of now. The only way to achieve this will be to use and amber rock guard over the clear spot light bar.
    Best,
    Brandon
