Light out in heater/AC control panel
Discussion in '1st Gen. Tacomas (1995-2004)' started by soccersmitty55, Nov 22, 2013.
  1. Nov 22, 2013 at 12:28 AM
    soccersmitty55
    soccersmitty55 [OP] Member
    The lights are out in my "fan speed" dial and my "blower temperature" dials, but not my dial that controls which vents are open. I checked all my fuses. Any ideas where the problem might lie?
  2. Nov 22, 2013 at 6:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's a common problem. Tap on the panel..... it'll probably come back on.
    I would take the panel out and check the plug. Make sure the main 'plugs' are fully engaged. Unplug them and plug them back in again.
    I think I'm the only one on this forum who's experienced a major setback with this. See the thread here:
    http://www.tacomaworld.com/forum/2n...climate-control-pod-burnt-connection-fyi.html
    Overall, I have a used climate control panel. It does the same thing as yours / my previous one....but not 'as bad' as the original one and my connections are 'new'.
  3. Nov 22, 2013 at 6:44 AM
    Janster
    Jandy
    Lancaster, PA
    Update:
    My used panel is also going out. With a little tap, it comes back on and stays on for longer periods than my previous unit. And not to mention, my connections are newer.
    It is what it is.....$730 is WAY too much to spend for a new part. And even so...how long will that last before it goes out?
  4. Nov 22, 2013 at 6:57 AM
    BamaToy1997
    Bill
    Navarre, FL
    Jan, I work on things like that at my shop all of the time. If you are up for it, would you be willing to send me your old one and let me take it apart to see what I can do? I used to deal with those micro ribbon cables all the time on small electronics like laptop screens and other LCD screens. If this is a common problem, I may be able to come up with a fix. Let me know if you are interested. Thanks.
  5. Nov 22, 2013 at 7:01 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    Sure its not the bulb?
    Halftunn50 likes this.
  6. Nov 22, 2013 at 8:19 AM
    Janster
    Jandy
    Lancaster, PA
    If you're willing to take the time - for the sake of finding a 'fix' for the community - I'm up for it.
    I have a feeling - if you find a fix - it won't be something your average DIY'r is gonna be able to tackle.
    I'm predicting a solder joint - similar to the poor quality in the overhead consoles. They probably used the same electronics manufacturer for both.
    When bulbs are burnt out....they're out. If you tap on the panel and the lights come on again - it's not a bulb.
    It's a poor connection somewhere.
    Manfred likes this.
  7. Nov 22, 2013 at 9:03 AM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    I have the same problem. A light tap and it comes back on ;)
    Manfred likes this.
  8. Nov 22, 2013 at 9:12 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Do a led bulb switch.
  9. Nov 22, 2013 at 9:31 AM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    As far as it being the bulbs, did he mention anything about tapping the panel and the lights coming back on? If not, I'd inspect the bulbs first- those control panel mini bulbs are pretty notorious for going out, especially on a first gen that's 10 yrs or so old. I just replaced one in my '04 tacoma and two in my '98 camry.. just my thought..
  10. Nov 22, 2013 at 2:27 PM
    blakes09
    Blake
    Deep South
    4x4
    well..sometimes that can be the bulb.tapping on it wiggles the filament around and when it makes contact it can weld itself back together for awhile.see them here at work do it all the time..
  11. Nov 22, 2013 at 3:48 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Mine has been out since 09 lol
  12. Nov 22, 2013 at 5:26 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    ^^^That.
    i see alot of bulbs doing this also.not sayin this is your problem,but bulbs can do this
  13. Jan 7, 2014 at 4:32 PM
    parfleet
    parfleet Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    So here's the question.....if my blower motor switch doesn't light on on the Heating/Air Conditioning control panel, the solution would be to pull the panel, disconnect the electric plug connections and reinsert the panel? I have already ordered new bulbs, a set of two from Amazon at a "dirt cheap" price. So again, replacing the bulb is not the solution? If all I have to do is tap on the dial and it lights up, could be a simple loose bulb? Is that even possible?
  14. Jan 7, 2014 at 4:35 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Mine did this and it was the bulbs. Dealer wanted 30 bucks for the two bulbs that go behind there. I got led's instead
    Edit: That panel is easy to pull out, it just pops out. Take it off and check the bulbs. There will be two of them that require a flat head. Its like a quarter turn to the left and theyll come right out
  15. Jan 7, 2014 at 5:22 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Very possible, but more likely a bad filament than the bulb actually being loose.
    Bad filament = bad bulb.
  16. Apr 18, 2014 at 2:58 PM
    jasclair
    jasclair Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
    where can i find LED lights for this?
  17. Apr 18, 2014 at 8:19 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Bulbs are the easiest thing to check. If the is a computer board (I've never checked), a cold solder would also cause the problem. Still easy to fix with a soldering iron and handheld gem scope or magnifying glass.
  18. Apr 18, 2014 at 9:15 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    to change the three bulbs on an 01-04 you have to take off the back of the HVAC unit (black part) to remove the bulbs and replace. they are Neo4 (4mm) type: https://www.superbrightleds.com/moreinfo/221/1002/
    I need to bite the bullet and buy some since I have shit tore apart right now
  19. Apr 21, 2014 at 6:10 PM
    jasclair
    joshua
    Bend oregon
    What kind of lights do I need for My 2010 Tacoma. One of my AC bulbs are out and I just need to get one.
  20. Apr 22, 2014 at 4:20 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    might want to check the 2nd gen forums/posts/DIYs :p
