Light bar and battery for RIGID ADAPT
Discussion in 'Lighting' started by RHED808, Aug 17, 2020.
  1. Aug 17, 2020 at 1:26 AM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    RIGID DSS PRO KO2 265/75r16
    I don't have a lot of knowledge on the RIGID ADAPT light bars or auxiliary lights in general and what precautions you would take when putting extra power draw from the truck
    I am curious if you guys changed the battery for light bars, or what you would change to be able to run the light bars in general. I heard (if its correct) that a certain amount of auxiliary lights taking X amount of amps/watts/volts would harm the battery. What could I do to prevent that
    If it helps I want to get the RIGID ADAPT 40" light bar, no other lighting is planned to get added.
    I just need help deciding where to mount the power for the light bar and if I would need to change something for the light bar and the truck to run correctly?
    First post here so if this was discussed here before sorry ahead of time.
    Mahalo
  2. Aug 17, 2020 at 6:13 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! When your truck is running the alternator is providing the power for your light bar, not the battery. It is only when the truck is off and you have your light bar on for an extended period that upgrading the battery to something with greater reserve capacity (RC) would be helpful.
  3. Aug 18, 2020 at 1:09 AM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    I see thanks for the help. Really appreciate it !
  4. Aug 20, 2020 at 10:21 PM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    Quick question, would you have to change the alternator to a certain spec if you put more auxiliary lights ? and do you think I'd be able to run the rigid adapt light bar with little to no problems if i plan to use it while the truck is on? What about idle, would using the bar at idle be okay with power draw ?
  5. Aug 20, 2020 at 10:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you have a TRD truck you already have the high output alternator from the factory, there is no need to upgrade to run a light bar. If you were running an extreme draw device like a winch for extended periods and very often that the battery reserve capacity was an insufficient buffer, then you might consider upgrading the alternator and battery. But if you have never seen the battery alarm sound in your truck, then there is no practical need for an alternator upgrade for some lights.
  6. Aug 20, 2020 at 10:38 PM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    alright sounds good thanks for replying so quick so many questions that I have, because I am fairly new to electronics in the car and know little to none. I will probably get the bar when I save up the money :spending: depends what I am interested in about a year from now.... 3/36k expires next year and i might lift her instead.
  7. Aug 20, 2020 at 10:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I shaved down my Supercharger snout, and way over-boosted my trucks supercharger before the warranty expired. You only live once. Send it. :)
  8. Aug 20, 2020 at 10:46 PM
    Shellshock
    Iowa
    I run 2 rigid SR30 and a pair of dually SS plus a fridge. All off the factory charging system. You’ll be fine. You don’t need to worry about it until you are running way more stuff.
    crashnburn80 likes this.
  9. Aug 20, 2020 at 11:13 PM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    I am excited to hear that ! Sounds good I appreciate your input too
  10. Aug 20, 2020 at 11:14 PM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    I just seen the gen 3 tacoma superchargers that magnusun released and I was thinking about that. But the only person that i know that had experience with boosted vehicles is my dad...
