Lifting Clyde
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tfree, Oct 31, 2016.
  1. Jan 18, 2017 at 12:46 PM
    GTM
    GTM Member
    SW Pa.
    2016 TRD DCOR
    New, thanks a lot for the reply Ill have same setup but leaving overload in for the farm and heavy gear. I just ordered the drivers side Eastern clamshell to be installed with lift.
  2. Jan 18, 2017 at 12:55 PM
    newimage
    newimage Well-Known Member
    No problem.
  3. Jan 18, 2017 at 12:55 PM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I like it. Just right for what I'm looking for. I'm just questioning if I want the AAl or HS 3 leaf for towing/hauling.
  4. Jan 18, 2017 at 12:58 PM
    GTM
    GTM Member
    SW Pa.
    2016 TRD DCOR
    Headstrong told me to go with the heavy AAL's cause I'm hauling heavy loads sometimes.
  5. Jan 18, 2017 at 1:13 PM
    Blktre
    Land of Oz....
    A buddy told me he bent straight his single aal hauling his boat. So the 3 leaf with overload sounds more like I want to try before splurging on the dakars.
  6. Jan 18, 2017 at 1:18 PM
    GTM
    GTM Member
    SW Pa.
    2016 TRD DCOR
    Ill see how the heavy one handles the loads I can always switch to three pack later.
  7. Jan 18, 2017 at 1:29 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    It is always hard to say exactly how much lift you will gain from any one coil because so many factors come into play like condition of the factory components, trim of truck, and any add-ons or additional options you may have. The lift gained from a coil spring is a variable rate and can be directly affected by the overall weight of the vehicle. The op has an access cab and on average they can see around 1/4"-1/2" more lift from the coils then what is spec'd out. When the additional up front weight would be added that can offset the gain of lift seen from the cab size. There is always a settling period on the coils so the measurements taken right after the lift is installed will calm down with driving. This usually gives people the excuse to plan an off-road trip. ;)
    (link to spec guide http://www.headstrongoffroad.com/uploads/1/1/8/4/11846658/lift_guide_shock_and_coil_selection.pdf approximate lift heights achieved after settling)
    Blktre likes this.
  8. Jan 18, 2017 at 1:29 PM
    tfree
    tfree [OP] Well-Known Member
    Nebraska
    2017 TRD ORAC
    I would just return the front spring for the 884 or 885. Or do what I did with the original spring.
  9. Jan 18, 2017 at 1:31 PM
    tfree
    Nebraska
    2017 TRD ORAC
    Headstrong did tell me their would be more lift with the access cab.
  10. Jan 18, 2017 at 1:35 PM
    HeadStrong Off-Road
    After you add your upfront weight you may want to go back to the coils. Totally up to you though. If you do they will settle in as you use them.
    Blktre likes this.
