LIFTING 1980 TOYOTA PICKUP?? PLEASE HELP
Discussion in 'Hilux' started by valley1, Apr 20, 2017.
  1. Apr 20, 2017 at 3:57 PM
    valley1
    valley1 [OP] Member
    Hey,
    I am a new member and I'm looking for help. I own a 1980 Toyota Pickup 2wd. I want to lift the front but i CANT FIND ANYTHINGGG. I need help finding parts, i was think maybe; Ball Joint Spacers Or Spindle lifts. but i cannot find a dealer. Thank You!!!!
  2. Apr 20, 2017 at 4:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd start by calling Marie @HeadStrong Off-Road. Even if she doesn't have the parts, she may well know who would.
    All I can suggest is to be careful. Fairly rust free examples of that model are pretty popular in stockish form. Think twice about changes that aren't 100% reversible.
  3. Apr 20, 2017 at 4:02 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    If it's in good shape, find some parts and convert it to 4X4. A good Hilux is priceless
  4. Apr 20, 2017 at 4:07 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
  5. Apr 20, 2017 at 4:11 PM
    valley1
    valley1 [OP] Member
  6. Apr 20, 2017 at 4:14 PM
    02hilux
    Planet: EARTH
    Sell it, buy a 82 to 85 4x4 with factory solid axle. There's tons of parts for those year. Or just buy a 85! You'll get the BEST of both world, 22RE EFI and factory solid axle. It's like going to bed with two beautiful women at the same time :cheers:
    Leaf spring lift the front and rear, add a 4.7 doubler with 37 and your unstoppable...
    Ackrite and Davtopgun like this.
  7. Apr 20, 2017 at 8:28 PM
    valley1
    valley1 [OP] Member
    Im Going for the pre runner look so i want to keep the 2wd
  8. Apr 20, 2017 at 8:37 PM
    02hilux
    Planet: EARTH
    Home made body lift is probably your only option.
    Good luck
  9. Apr 20, 2017 at 8:59 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    You can probably modify a Blazeland or dare I say Total Chaos kit. The suspension would be worth way more than the truck itself though. Anything is possible but you'll need deep pockets. Can I ask why modify a 40 year old truck with little or no aftermarket support?
  10. Apr 20, 2017 at 9:04 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    A wise man, this one.
    :cool:
  11. Apr 20, 2017 at 9:12 PM
    Ackrite
    SoCal
    OP, old Toyotas are not really for those who are looking for a project to build from commercially available parts. Generally speaking, you will have to hack and fab your way to your desired results, as well as bastardize your truck with parts from all kinds of makes and models until you find something that works.
    Your other option is to make a new account at P4x4 and ask away all the questions you need answers to on this build.
  12. Apr 20, 2017 at 9:15 PM
    02hilux
    Planet: EARTH
    He'll be burned alive on P4x4. Won't last a day or two with All the smart answer and cursing.
    It's a rough country with large rock to climb there
  13. Apr 20, 2017 at 9:17 PM
    Ackrite
    SoCal
    No need to ruin the surprise :crapstorm:
  14. Apr 20, 2017 at 9:21 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I had an 89 & 94 pick ups. The suspension needed for lift is torsion bars & UCAs. We used to run 3" body lift with that set up. For the rear you can do the normal add a leaf or shackle. If you cut front fenders or run glass, you can run a 32/11.50/15. Also you can run a ball joint spacer instead of the new UCA to save a few bux.
  15. Apr 20, 2017 at 9:26 PM
    02hilux
    Planet: EARTH
    Oooops, yes open an account and built it there.. hehe
  16. Apr 20, 2017 at 9:28 PM
    02hilux
    Planet: EARTH
    89&94 suspension are completely different from 80 2wd. Those year are possible, not for early 80
  17. Apr 20, 2017 at 9:31 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    So what does the front suspension have and what year did it change? I believe all the 2wd early and late 80s had torsions.
  18. Apr 20, 2017 at 9:39 PM
    Htnswches
    E
    Lost Angels
    That's what I thought, up to 94.5
    TommyG[QUOTED] likes this.
  19. Apr 20, 2017 at 9:45 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I think they also made a few 95s. Along with the 1st gen 95 Tacoma. :notsure:
  20. Apr 20, 2017 at 10:30 PM
    02hilux
    Planet: EARTH
    I could be wrong but I think torsion bar was use between 1984 to 1995. I had not see any early 95.5 taco with them here in California.
