Lifted problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011GTACO, Sep 21, 2016.
  1. Sep 21, 2016 at 8:27 PM
    2011GTACO
    2011GTACO [OP] Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    I'm about to order a complete lift kit from headstrong in a couple of weeks but I just wanted to know what problems might occur when lifting my truck 3". And if you have a 3" inch lifted taco with m/t what mpg are you getting. Is it really worth lifting?
  2. Sep 21, 2016 at 8:30 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Upper control arms maybe needed for alignment.
    Dont offroad too hard with spacers.
  3. Sep 21, 2016 at 8:36 PM
    lesterb315
    lesterb315 Well-Known Member
    Lester
    SoCal
    2012 DCSB Off-Road
    I recently lifted my truck about 3in. Didn't need to swap my UCAs though and all has been well so far. Not many other problems I can think of that can occur by lifting it as long as you're getting all the correct parts. Headstrong seems to a favorite choice of many so you should be good. As far as worth lifting it..well I guess that all depends on your personal choice and if you plan on wheelin'..if so, then yeah it is worth it. Just my two cents..
  4. Sep 21, 2016 at 8:38 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Lifting won't really affect your mileage. Bigger tires will though.
    As far as problems, not much. Harder to get inside.
    Also, do a search this topic has been covered a million times.
    10trdtaco likes this.
  5. Sep 21, 2016 at 9:25 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I recently installed (August '16) an OME lift kit on my 2011 DCSB 4x4 m/t. I have 885 springs and I installed the full Dakar leaf packs in the rear. My kit came with the CB drop spacers, and I installed them at the same time. I also installed LR UCA's, so that alignment wouldn't be an issue.
    The only problem I had was a shudder/vibration right at roll out that would shake the manual shifter up to 10-15 mph. I measured my driveline angles and needed to add 3 degree shims between my Dakars and rear axle. That has eliminated the shudder/vibe.
    As far a mpg are concerned, my truck isn't a daily driver, so I haven't driven it enough to check mpg's. I haven't changed my tire size yet, either. I believe that'll have a bigger effect on mpg's than just the lift.
    I really like how the truck looks lifted. Is it worth it? Depends on what you do with your truck.
    FWIW, Headstrong is top notch to deal with.
    Good luck.
    surforegon and Hellapeno like this.
  6. Sep 21, 2016 at 9:38 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Lift has absolutely no effect on mileage. Tires do. Stay with C rated rubber and you wont lose too much.
    Just Dandee likes this.
  7. Sep 22, 2016 at 10:24 AM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    THanks for posting, this is good guidance. I believe I will have to shim after installing the Dakars since I have developed a nasty little shudder/vibration. How did you measure the pinion angles to determine 3 degrees? Any guidance there is much appreciated.
  8. Sep 22, 2016 at 10:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    If you need that to solve a real off road functional problem you have, absolutely.
    If you are doing it for big tires (that you don't functionally need) and looks, the the judgement of worth it totally up to you and your wallet.
  9. Sep 22, 2016 at 6:30 PM
    Hardscrabble
    Scott
    McDonough, GA
    I viewed several YouTube videos and bought one of the Swanson angle finder gauges like in this video.
    https://youtu.be/wkfndHDiH1M
    I used it and also the "HandyLevel" app on my iPhone to measure the angles of my driveline.
    Good luck.
  10. Sep 22, 2016 at 6:49 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Hardscrabble likes this.
  11. Sep 23, 2016 at 6:35 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yup, I was going to say needle bearing. Also driveshaft vibes.
    Another thing you'll be battling is an overwhelming need to run things over.
    Fitz235[QUOTED] likes this.
  12. Sep 23, 2016 at 10:43 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    3"... cv boot ribs will contact each other... chance of tearing.
  13. Sep 23, 2016 at 12:53 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    This too. Inner boots are the problem here. Search "boot slide mod" or get yourself a pair of high angle inner boots.
    I got mine from CVJ
