Lifted my Shark Fin - how to fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hoyle, Sep 7, 2016.
  1. Sep 7, 2016 at 10:31 AM
    Hoyle
    Hoyle [OP] Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Photo Sep 07, 11 25 04 AM.jpg Photo Sep 07, 11 25 10 AM.jpg Photo Sep 07, 11 25 38 AM.jpg Yesterday I did a bone-head, backed into the bottom of garage door that was not open all the way.. It hit my fin antenna and lifted it just a bit. Please advice on how to I get it back to seated again before the rains come.. Please be specific - I haven't been very bright this week. This is my 2nd bone-head in 2 days.. usually I only get a few a year ..
  2. Sep 7, 2016 at 12:00 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Think mounting point of antenna bent on roof . Going have to pull head linner and look if roof is bent .Maybe you can look under base now to have an idea whats wrong. You could just put a nice bead of silicon around base for now till you can check it better. Doesn't look like an easy fix but hope I'm wrong.
    sanchez and ChadsPride like this.
  3. Sep 7, 2016 at 12:02 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Silicone...3m emblem tape. ..
    I'm sure someone on tw gotta to have answer. .
  4. Sep 7, 2016 at 12:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Trade it in. I'm sorry, I had to.
    Skyway likes this.
  5. Sep 7, 2016 at 12:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    You can see that the roof is definitely dented. You could try the old compressed air and hair dryer trick and it might just pop right out. You can also try letting it sit in direct sunlight for an hour two first. It might pop itself out that way too.
  6. Sep 7, 2016 at 12:11 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    sanchez and kgarrett11 like this.
  7. Sep 7, 2016 at 12:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Roof is bent. Paintless dent removal may work, but that headliner will probably have to come out.
    1992SR5V6 likes this.
  8. Sep 7, 2016 at 5:58 PM
    icegrill
    icegrill Well-Known Member
    Oregon
    2015 Tacoma TRD (sold) bmw F80 M3 current
    PDR is the only way
  9. Nov 23, 2017 at 4:42 PM
    dave_brez
    dave_brez Well-Known Member
    Dave
    Nashville, TN
    2015 TRD Sport
    Bilsteins/OME leafs, KO2's, Bankruptbilt front bumper, Baja designs lights, winches and tents and stuff.
    I did the EXACT same thing this morning. I’m thinking of using a thin silicone seal in the crack unless anyone has discovered better solutions.
    Hoyle[OP] likes this.
  10. Nov 8, 2018 at 3:40 PM
    Trdtaco123
    Trdtaco123 Active Member
    @Hoyle did you find a solution for this?
  11. Nov 8, 2018 at 4:19 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    FYI he won't get alerted unless you tag him
    @Hoyle
  12. Nov 8, 2018 at 4:28 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    As a few people already mentioned, the attachment point sheet metal is bent. You can either be an ape and pull on the shark fin in an opposing direction as the bend and hope that it straightens you out and doesn't distort the sheet metal further, or you can be a bit more technical about it and remove the shark fin to better address the sheet metal. This involved dropping the headliner to get to the retaining nut on the underside, BTW. It isn't particularly hard, but can be a bit tedious and involved:
    https://www.tacomaworld.com/threads/removing-your-headliner-and-insulating-sound-deadening.394469/
    Expect actual metal work similar to PDR or even hammer/dolly work if the distortion is real bad.
    Another (easier) option is the boiling water/heat method to remove dents (search youtube), but if you've already disturbed the seal, you might get water in the cab.
  13. Nov 8, 2018 at 5:41 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I would probably opt for being an ape and pulling on the fin in the opposite direction and see if it helps at all... probably not the smartest move though.
  14. Nov 9, 2018 at 7:02 AM
    Hoyle
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    The solution was to simply apply some clear outdoor silicon seal around the antenna. It's been fine.. it's not noticeable and as of now I simply forgot about it.. but today I will check to ensure the seal is not peeling after the heated summer exposure now that the rains are coming in..
    Starman2112, jojotoo and Billgram like this.
  15. Jun 1, 2020 at 6:49 PM
    Billgram
    Billgram Member
    2017 4x4 Double Cab SR5
    @Hoyle How did the silicone hold up? Thinking of doing this to mine, similar issue
  16. Jun 1, 2020 at 8:50 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I was wondering what the purpose of that shark fin was, as I have one + the traditional antennae. Why do I have two?
    2012 trd sport, new to me since April.
  17. Jun 1, 2020 at 8:52 PM
    Billgram
    Billgram Member
    I believe the shark fin is for XM radio on your model. I could be wrong but that’s what I’ve been reading on TW @Marc70
    Marc70 likes this.
