Lift covered in Carmax extended warranty?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucasmac94, Sep 15, 2017.
  1. Sep 15, 2017 at 8:55 PM
    Lucasmac94
    Lucasmac94 [OP] New Member
    Lucas
    5 lug tacoma
    so i bought my tacoma from carmax with the aftermarket lift already installed, about a week ago it started to shake. I purchased an extended warranty and just need to know if that is covered or am I screwed, I have no receipts from the person who installed the lift kit.
  2. Sep 15, 2017 at 8:59 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    I'd say screwed. Aftermarket accessory. But I'm no expert. :notsure:
  3. Sep 15, 2017 at 9:02 PM
    Lucasmac94
    Lucas
    5 lug tacoma
    Well I've read that aftermarket parts can't void the warranty, but it may just need an alignment. Just hoping that they know what to do with it.
  4. Sep 15, 2017 at 9:14 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Who did you buy the extended warranty through? If it was Toyota then don't expect them to fix any suspension related issues. If it was another 3rd party then they may do something since the vehicle was purchased with the lift.
  5. Sep 16, 2017 at 1:19 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Ummmm, How would we know if your extended warranty would cover it? Why don't you pick Up the phone and call the company....
    PackCon likes this.
  6. Sep 16, 2017 at 9:19 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You need to read your warranty.
    Almost certainly the warranty will not cover problems with aftermarket suspension parts or install issues with the lift.
    But tgat doesnt mean the issue isnt with a factory part.
    Is the shaking happening when you brake? Lol
  7. Sep 16, 2017 at 9:44 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Alignment will not fix a shake. Sorry.
  8. Sep 16, 2017 at 9:55 AM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Man people on here are going to be rough on you with a post like this so let me help you out. First, what is the nature of the shake? Does it happen at a certain speed, during braking or accelerating? If it is a balance issue on your tires, you will most likely notice it while braking or at a particular speed. How old are your tires? Have you checked air pressure in the tires? Had them balanced and rotated?
    So if tire problems are eliminated, and depending on your type of lift, you could be developing driveline vibrations which can actually get kind of severe if not corrected. If you have a lift with an add-a-leaf rather than blocks, you may need axle shims and/or carrier bearing spacers to correct the driveshaft alignment. Toyota decided on the two piece driveshaft which creates problems from lifting because without properly aligning the driveshaft after a lift you have two pieces that are at different alignments which causes a wobble. Could be the source of your issue.
    This forum is great for problem solving. Take some time to test your truck and post up what you have done. Good luck!
  9. Sep 16, 2017 at 7:56 PM
    Taco de Plata
    Taco de Plata Well-Known Member
    2009 Silver Prerunner TRD Sport
    The Carmax warranty should cover the vehicle as it was purchased. Take it in.
