Lift? 285/70/17 Ridge Grapplers
Discussion in 'Wheels & Tires' started by dgmagum, Nov 2, 2019.
  1. Nov 2, 2019 at 12:25 PM
    dgmagum
    dgmagum [OP] Member
    Need some suggestions..I want to install 285/70/17' Nitto Ridge Grapplers on my 2019 Taco. How much do I need to lift it for clearance? I've used Billstein 5100 in the past and like em a lot.. Just not sure if they'll get me enough... Had a similar set up on my Ram 1500 but this is a new game for me.. Thanks
  2. Nov 2, 2019 at 12:54 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Unless you're going with a 4"+ drop bracket lift, the amount of lift won't make a difference, at least for Tacoma's.
    There is a portion of the frame that the cab mounts to that almost any tire that is 33" tall will hit, with the possible exception of a 255/80R17, due to it being much narrower. This also has a lot to do with wheel width, offset, and backspacing since this determines the arc that the tire will move in when turning and compressing the suspension.
    So you really have two options here.
    1. Lift it with whatever lift suits your liking, trim some plastic and do a Cab Mount Chop (lots of info on it here, just search for "CMC" or cab mount chop). Make sure you choose a wheel with a backspacing of 4 inches for 8" wide, or 4.5 inches for up to a 9" wide wheel. I wouldn't recommend trying to fit a wheel wider than 9 inches on a lift this small as it will rub more. is a great website for figuring out how all these things work.
    2. The second option if you want more lift is a drop bracket lift. These are typically 4 inches or more, and require cutting your frame. These are fairly permanent lifts and you should do a lot of research before choosing one as there are huge differences in quality between brands. The upside to this is that it gets the wheel and tire out of the wheel well and you no longer have to trim to run large tires. The downside is that these lifts generally look huge on our trucks.
    It really just depends on how much trimming/cutting/hammering you're comfortable with, and what look you want to have in the end. Good luck!
    dgmagum[OP] likes this.
  3. Nov 2, 2019 at 5:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I have a 2nd gen. I run a 285/70/17 on 17x8.5 -10 offset with a toytec 3” lift. Bilstein with toytec coils, jba ucas and caster set at 4* no cmc . I would think you could do the same on the 3rd endless maybe the cab mount is a bit further forward.
    Ccrames2018 likes this.
  4. Nov 2, 2019 at 5:05 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Look at my Sig. I have those tires and no rub ever. 5100 x 4 and 888 springs. Cheap 1500 lift.20190825_182937_HDR.jpg
  5. Nov 2, 2019 at 5:06 PM
    grubburg
    2019 TRD OR MT
  6. Nov 2, 2019 at 5:07 PM
    grubburg
    2019 TRD OR MT
    This was not my experience at all.
    Edit: but I have read a hundred people who agree with you based on their personal experiences
    Ccrames2018[QUOTED] likes this.
  7. Nov 2, 2019 at 5:09 PM
    grubburg
    2019 TRD OR MT
  8. Nov 3, 2019 at 9:23 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah there's a lot of factors that come into play so I'm sure some people could run it and have no issues. It seems like the majority have some rub when flexing the suspension, but then again not a lot of people have 4 degrees caster either.
    I'm hoping to barely squeeze by without a CMC using 305/70R16s (33x12.2) with 4.1 degrees of caster and 16x8 -12s. I doubt it'll work without a CMC on my 2nd gen though. I'll try to remember to report back at least for the 2nd gen guys, maybe it'll help someone.
  9. Nov 3, 2019 at 9:31 AM
    grubburg
    2019 TRD OR MT
    I only have 2.5 caster
  10. Nov 3, 2019 at 7:28 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Nice, maybe I'll get away with the 305s then. I'm doing the Falken Wildpeak AT3W and they run a little skinnier than some.
    grubburg[QUOTED] likes this.
  11. Dec 3, 2019 at 7:58 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Truck looks great. What did you do in the rear, lift wise? I'm going to 888 coils, spc UCAs and 285/70/17 tires. I ordered a 3 leaf AAL, but not sure to keep the overload in or not.
  12. Dec 3, 2019 at 8:34 AM
    grubburg
    2019 TRD OR MT
    Rear: 5100s, headstrong 3 leaf, carrier bearing drop. nothing else.
    we should have identical lifts. (details of my stuff on the left)
    thanks!
  13. Dec 3, 2019 at 8:38 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I was one of the few to get away with no CMC with 285s
