License Plate Lights not working?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by derekcrichton95, Feb 6, 2022.
  1. Feb 6, 2022 at 5:27 PM
    derekcrichton95
    derekcrichton95 [OP] Member
    Derek
    2022 TRD Tacoma Off Road
    22' OR
    Had the day off so I decided to replace my license plate lights. I was able to successfully remove the old halogen bulbs with both lights still on and working. Took the bulb out and put in the new LED lights and now they don't work. Took the LED lights out and put it in on the opposite side and they still don't work. Tried to put on my old halogen bulbs and now even those don't work. Seems like I did everything right but I don't know why it's not working. It's my first truck so any suggestions would be greatly appreciated!!
  2. Feb 6, 2022 at 5:28 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Replace the fuse you blew yet?
  3. Feb 6, 2022 at 5:29 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Check the fuses?
    Tacospike and skeletron like this.
  4. Feb 6, 2022 at 5:29 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Sounds like a blown fuse. Did you disconnect the battery before replacing the bulbs?
    Tacospike likes this.
  5. Feb 6, 2022 at 5:36 PM
    derekcrichton95
    Derek
    No I did not. Was that something I should've done before changing the lights?
  6. Feb 6, 2022 at 5:37 PM
    Tacospike
    Two Trucks
    Sounds like 22’s are sensitive.
    all above suggestions seem like the cause though
  7. Feb 6, 2022 at 5:42 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    The electronic system can be very sensitive so I'd disconnect the battery before doing anything electrical, even changing bulbs.
    Montana_Actual and Tacospike like this.
  8. Feb 6, 2022 at 5:47 PM
    derekcrichton95
    Derek
    Copy that. Thank u!!
  9. Feb 6, 2022 at 5:47 PM
    derekcrichton95
    Derek
    Thank u for your input!! I appreciate it!!
    Tacospike[QUOTED] likes this.
  10. Feb 6, 2022 at 5:48 PM
    derekcrichton95
    Derek
    Thank u! I will be checking the fuses.
  11. Jun 14, 2022 at 11:08 AM
    Vistascion
    Vistascion Member
    2016 Tacoma trd sport
    Hi,
    I'm new in the forum. 2016 tacoma trd sport. I have the same problem with my brake lights. Can you please let me know what's the fuse for the brake lights? Thanks in advance.
  12. Jun 14, 2022 at 11:14 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Under left side of dash. Second down on the left, labeled 'Tail'
  13. Jun 14, 2022 at 11:15 AM
    Vistascion
    Vistascion Member
    Thank you so much. Have a great day.
    Speedfreak likes this.
