License plate lights not working =(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTimmy, Feb 12, 2012.
  1. Feb 12, 2012 at 6:58 PM
    TacoTimmy
    TacoTimmy [OP] Active Member
    Hohenwald, TN
    07 PreRunner SR5
    Hey guys/girls
    I just bought a 2007 Prerunner Double Cab and love it! I noticed the other night the license plate lights were not on. I thought no big deal, I'll replace the bulbs. So today I replaced the bulbs and still nothing. I got out the MultiMeter and I have no power at either pigtail. Can anyone shed some light on this? The parking lights all operate fine and I thought they would be intergated together. Come to think of it when I was testing I was using the ground terminal on the pig tail. Is there a seperate ground for the lp lights that may have worked loose? The truck does have a tow package with the wiring. I plan on diving into it a little deeper on my next day off. I tried to do a search but came up empty handed. Thanks for any advice you might have!
  2. Feb 12, 2012 at 7:00 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome to TW
    Did you check the fuse?
  3. Feb 12, 2012 at 7:00 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    x2 on the fuse
  4. Feb 12, 2012 at 7:01 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    You were checking voltage at the ground?
    You need to check for ground continuity, not voltage.
    x3 on fuse.
  5. Feb 12, 2012 at 7:11 PM
    TacoTimmy
    Hohenwald, TN
    07 PreRunner SR5
    Is there a seprate fuse for the lp lights? I thought they would be on the same circuit as the parking lights....
  6. Feb 13, 2012 at 8:25 PM
    TacoTimmy
    Hohenwald, TN
    07 PreRunner SR5
    Checked fuses today. All was well. I am thinking it has something to do with the factory trailer wiring. Gonna dig a little deeper, I will keep yall posted.
  7. Apr 16, 2012 at 9:44 AM
    Sack17
    Sack17 Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    I am having the same issue currently, did you figure anything out? I've tested with a test light and I have no power at the bulb and the bulbs are brand new. All my fuses are fine too. I'm just sitting here scratching my head...
  8. Apr 17, 2012 at 5:02 AM
    TacoTimmy
    Hohenwald, TN
    07 PreRunner SR5
    No. They just started working. I noticed one was on, then a couple of days later the other one popped on. No problems since.
  9. Apr 30, 2012 at 11:06 AM
    Sack17
    Andrew
    Sanibel, FL
    Haha niiiiice, I love it when stuff just works itself out like that. I wish some shit like that would happen to me lol.
  10. Apr 5, 2013 at 1:09 PM
    Murdog
    Murdog Member
    Florida
    06 Prerunner Off-Road
    Lift, 17'' All-Terrains, Duell Exhaust, Towing Package.
    My first post... I have an 06 Prerunner with towing package. I have the same problem with no license lights. Can't figure out what the problem is. Has anyone figured this one out yet? Pass side was out, took the housing out to check and now the driver side doesn't work either with new bulbs.
  11. Apr 5, 2013 at 1:10 PM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Check the fuse. Check the ground.
    If it isn't the bulb.
  12. Apr 5, 2013 at 2:16 PM
    Murdog
    Murdog Member
    Florida
    Thanks. Will do. P.S. Nice ride:)
  13. Apr 5, 2013 at 2:29 PM
    Murdog
    Murdog Member
    Florida
    Can you recommend where to check ground ? These lights come out of a wiring harness that seems to go several different places.
  14. Jan 22, 2019 at 4:49 PM
    Jasonalex28
    Jasonalex28 Member
    2017 Tacoma TRD Off Road
    Sponsors: king bypass shocks, McNiel fenders, dirt king fabrication long travel, rigid lights, magnaflow exhaust, pedal commander, CBI bumper, TRD intake
    Where is the fuse located?
  15. Jan 22, 2019 at 4:58 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    This threads over 6 years old. You will probably get a better reply if you search or start a thread. But I would check the under hood fuse box. I have a 1st gen so its different.
  16. Jul 16, 2019 at 6:11 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
  17. Jul 16, 2019 at 6:17 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
