License Plate Bulb Change procedure NOT from under truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Col4bin, Jul 31, 2020.
  1. Jul 31, 2020 at 4:30 PM
    Col4bin
    Col4bin [OP] Well-Known Member
    Maine
    2018 TRD OR Double Cab
    I thought I read that I should be able to pop off the light lens from the bumper side of the license plate bulbs rather than getting under the truck.
    am I correct?
    my rear ARB summit bumper is great but access to the traditional way to change the bulbs from up and under like I would with the stock bumper is pretty involved
    TIA
  2. Jul 31, 2020 at 5:05 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    i see the inserts on the side of the lens cap on top but i didnt want to keep prying and make indentions on my bumper or maybe crack my lens cause that babdboy refused to give. i did just change out my lights the other day for some diode dynamics (same time i did meso ultimate tails), and imma be straight up. i changed it from underneath and it suuucked.
  3. Jul 31, 2020 at 5:10 PM
    Col4bin
    Maine
    Damn. I swore I read you could do it from outside. Can’t find it in any of my searches. You think the stock bumper sucks, ARB makes you remove this intricate trim/skid plate to get anywhere near it
    Xer0 SiN likes this.
  4. Jul 31, 2020 at 6:44 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Get under the truck and stick your hand to where the license plate light assembly goes and squeeze the friction clip on top and the bottom will follow from outside. That’s what I did. It was very difficult trying to turn that tiny socket 45 degrees without removing the whole unit.
    DAS Taco, MadKatt and 4x4_Taco like this.
  5. Jul 31, 2020 at 6:58 PM
    Col4bin
    Maine
    Yeah but I can even get to the bulb or assembly underneath the truck without removing a bunch of stuff. Sounds like illl need to do that. Just way more of a project than I hoped to do for two bulbs.
  6. Jul 31, 2020 at 7:02 PM
    Tacomike18
    J
    If you don’t have the rear tow hitch then it’s a lot easier. For me, the only problem is there’s a wire harness that needs to be moved before you can even see the bulb socket.
  7. Jul 31, 2020 at 7:03 PM
    Col4bin
    Maine
    Rear hitch and ARB bumper
  8. Aug 1, 2020 at 4:09 PM
    Col4bin
    Maine
    So do future reference i see no way to have them be removed from NOT being able to reach them. But absolutely the easiest way is to squeeze the clips on the housing and push it out of the bumper and do the bulb change where you can access everything. Check polarity and function, screw back in to back of housing and then slide the housing back in the hole. Note the clips go on the sides of the housing hole. NOT the top and bottom.
    diode dynamics upgrade, check!
  9. Aug 2, 2020 at 3:58 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
  10. Aug 2, 2020 at 4:14 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Tried the switch my license plate lights to LED the other day too. I have the stock bumper and tow package. I got the left side but it was very Difficult to do following the instructions on YouTube that 3 or more people posted. Reach up under and turn the thing counter clockwise then pull out. Like I said I got the left side but the right well I couldn't figure out how to get my left hand in position to get it, I'm left handed. I tried with my right hand but due to an injury years ago in don't have as good grip strength with my right hand so I was not able to get it to turn.
    There must be a way to do it from above.
  11. Aug 2, 2020 at 5:42 AM
    Col4bin
    Maine
    If you can squeeze the actual rectangle plastic housing- the whole thing just pushes out. Then do all the turning and bulb swap from up on the bumper. There is plenty of wire. The tabs holding the housing in take almost no force to squeeze and push out
  12. Aug 2, 2020 at 6:04 AM
    Col4bin
    Maine
  13. Aug 2, 2020 at 6:23 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I don’t recall where on the internet I found this ‘from above’ method using a trim tool but it works:
    Use a trim tool like this:
    The trim tool can be pressed in beside the lamp housing to release the clip:
    Then reach behind the bumper and just push the lamp housing out.
    Now you've got it out in the open where it's easy to see and handle. After you've swapped the bulb, the housing simply snaps back into place.
  14. Aug 2, 2020 at 6:40 AM
    Col4bin
    Maine
    i like that. I didn’t think there was enough room for trim tools on either side but if it works, awesome.
    either way you have to push from behind the housing and pinching the tabs from under the truck is just as easy and I bet faster. Now if we could depress the tabs from the outside AND pull it out eliminating getting under the truck all together... that’s the best solution
  15. Aug 2, 2020 at 7:19 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    You're right...i remember swearing a lot when I removed the incandescent bulbs to install LED's.
  16. Aug 2, 2020 at 8:13 AM
    Taco_mike73
    York, PA
    @wiljayhi that is the way I was looking for, thanks so much for posting that.
    I had a set of trim tools handy. Was able to push the tool on front and back of the lens and easily use my right hand under the bumper to push it out. Its Very much easier to turn the thing from above and change the bulb. It all snaps back quickly once you test the new led. Took under 5 minutes to do the remaining side. Didn't even break a sweat over it unlike the last attempt.:thumbsup:
    DAS Taco likes this.
  17. Aug 2, 2020 at 8:16 AM
    Col4bin
    Maine
    I thought the friction clips were on the sides??????????????????? not top and bottom?
  18. Aug 2, 2020 at 8:18 AM
    Taco_mike73
    York, PA
    On mine the clips were on the sides of the lens facing the front and back of the truck. Look for a little indent in the lens. I just did it to mine.
  19. Aug 2, 2020 at 8:21 AM
    Col4bin
    Maine
    we need a solution for pushing those clips in AND pulling it out...all from NOT under the truck. credit card on both sides were too thick. maybe a thin long box cutter blade on each side to depress the clips...and then a 90 degree pick tool to slide it out?
  20. Aug 2, 2020 at 8:28 AM
    Taco_mike73
    York, PA
    I used a thin trim tool like in the post above to press the tabs from the top side. I was able to push it out from under rather easily. I'm good with that. I didn't have to work hard to twist it from under. Just pushed each side out with a few fingers once to tabs are pressed with the tool. Maybe of your hands are too big you can get a helper, like a wife, significant other or some offspring with smaller hands.
