Lexus RX350 Wheels / Fit on '12 base ?
Discussion in '5 Lug' started by ramairglenn, Sep 2, 2013.
  1. Sep 2, 2013 at 9:15 PM
    ramairglenn
    ramairglenn [OP] Member
    Alabama
    Tacoma SR5
  2. Sep 3, 2013 at 8:47 PM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Yup those will fit perfect no problem
    Same bolt pattern 5x114.3
    The rim is only 7" wide and the offset is good at +35
    Should be a lil wider than stock won't look as sunk in the fenders
    In running 19x9.5 +20 and thy are lil wider than the bed but I have a small stretch and I rolled inside and have no problems
    Hope this helps bro!
  3. Sep 5, 2013 at 7:09 PM
    ramairglenn
    Alabama
    Tacoma SR5
    Yeah Brenden, that helped a lot, exactly the info I needed. I am going to keep a fairly small tire; planning on a 225/50/18. Mainly wanting to get rid of the ugly steel wheels. Thanks again.
  4. Sep 16, 2013 at 10:36 PM
    Metal20
    Metal20 Member
    Show pics!
  5. Sep 17, 2013 at 4:38 PM
    ramairglenn
    Alabama
    Tacoma SR5
  6. Sep 17, 2013 at 4:45 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  7. Sep 17, 2013 at 5:48 PM
    Metal20
    Metal20 Member
  8. Sep 18, 2013 at 8:33 AM
    ttaM
    ttaM 4.8.15.16.23.42
    Kentucky
    2002 Tacoma 2.4L 5 Lugger
    Those wheels look so sweet.
  9. Sep 18, 2013 at 1:32 PM
    Steveshred
    Steveshred New Member
    SR5 4 Banger
    I thought the center bore on 5-lug is 67.1.
  10. Sep 18, 2013 at 5:53 PM
    ramairglenn
    Alabama
    Tacoma SR5
    Thanks folks, I was worried about too much 'bling' but I'm getting used to it. The physical fit was spot on; the only problem was the pressure sensors wouldn't transfer wheel to wheel due to the different contour of the inside of the wheels. I went ahead and bought four new sensors from the tire guys and that took care of the problem. BUT, if I had to do it over again, I would probably put regular valve stems in and lived with the light. The sensors were $75 per wheel. Ouch....
  11. Sep 19, 2013 at 4:48 AM
    Metal20
    Metal20 Member
    Yep, ouch. I'm going to do the TPMS Canister Mod.
  12. Sep 20, 2013 at 3:51 AM
    Metal20
    Metal20 Member
    You maybe right on 4wd, but on my 2011 2wd Access Cab 100% pos. its 60.1mm.
  13. Sep 21, 2013 at 1:05 AM
    Steveshred
    SR5 4 Banger
    Oh man, I just bought some rims for my 2013 double cab and they're 67.1.
  14. Sep 21, 2013 at 5:06 AM
    Metal20
    Metal20 Member
    It is not all bad. I know there is a great debate about the bore size. Yes, in a perfect world you want the bore to be exact fit. At least with your new wheels you could add a bore adapter if you want. I've spoken to several wheel distributors and have had a lot of wheels over the past years that the center bore didn't touch the aftermarket wheels and have had "zero" issues with road feel, unnecessary steering vibrations.
    Your 2013 may have that 67.1mm diameter.
    Just my 2 cents...
  15. Sep 21, 2013 at 8:51 AM
    Steveshred
    SR5 4 Banger
    Thx for the good info, I'll take a wheel off and measure.
  16. Sep 21, 2013 at 3:18 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    They look sharp man!
  17. Oct 5, 2013 at 7:58 PM
    NorCalTaco510
    NorCalTaco510 Member
    G
    California
    2011 Base 2wd Access Cab
    Nice wheels
