Leveling the truck without spacers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Babytruck7690, Aug 17, 2020.
  1. Aug 17, 2020 at 4:03 AM
    Babytruck7690
    Babytruck7690 [OP] New Member
    Kai
    Virginia
    2018 white TRD sport 4x4
    I decided to buy a used 2018 4x4 sport and now I have so much to learn. The previous owner seems to have bought the 3in RC lift with a spacer to level the truck and blocks for the rear. New to the tacoma world, I am hearing that's a bad thing.
    What are some recommendations for a 3in lift kit but getting rid of the factory rake without spacers?
  2. Aug 17, 2020 at 6:41 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    Unless you are off-road more than 50% of the time spacers will do just fine. They are not the best option but they have been used for decades for a reason.
    Thunder Fist likes this.
  3. Aug 17, 2020 at 6:44 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Agreed. You'll get some push back on here, but most trucks you seen on the road that are leveled are using spacers. However, if you want to drop the coin on a suspensions lift, you have a lot of great options that will also increase the capability of your truck.
  4. Aug 17, 2020 at 6:46 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Do you know why it’s a “bad thing”? In many cases a spacer lift is just fine for certain uses. Don’t just take Tacomaworld’s word for it. Research why!
    su.b.rat and 71tattooguy like this.
  5. Aug 17, 2020 at 6:49 AM
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    My friend has had a spacer/block lift on his 2020 off-road since he bought it almost a year ago. He wheels harder than all of us, and more often. He's yet to have any issues.
    Not saying problems can't or won't happen, but spacers also aren't some thing to fear either, especially if you aren't going hardcore offroading.
  6. Aug 17, 2020 at 8:23 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Remove and replace with Bilsteins or Eibach. Been down that road with spacers never again. Yes they are fine but when you research and see what can happen might just change your mind Considering our trucks cost lots of money.
    Good luck.
    I do like the sumo springs though
  7. Aug 17, 2020 at 8:58 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
  8. Aug 17, 2020 at 9:05 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    They are fine if you don’t see much more than gravel roads or aren’t taking a parking lot speedbump at 60mph.
    For street use they are fine. The ride may however be harsh.
  9. Aug 17, 2020 at 9:12 AM
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
    Spacers are good for looks and anything you would do on your stock suspension. No complaints. Don’t let fools tell you they are bad just because they spent thousands on suspension to drive on pavement 360 days of the year
    Astr0Aar0n and Bleep100 like this.
  10. Aug 17, 2020 at 9:14 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Fools LMAO!! Why? Because we are offering honest help.
