Leveling Kit Recommendation? Will it void my warrenty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomsen3, Oct 5, 2021.
  1. Oct 5, 2021 at 1:02 PM
    thomsen3
    thomsen3 [OP] New Member
    2021 TRD Sport
    Looking to get a leveling kit for my Tacoma but I have a warranty from the dealership that I do not want to void. Any recommendations on brand and size?
  2. Oct 5, 2021 at 1:11 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Any lift will void the warranty on those parts. But they can also try to blame other issues on the lift too.
    Examples -
    You get a lift (springs, struts, and rear leafs) and you get a clunk in the suspension later. The dealer may say its because of the lift without looking at it, even if its not due to the lift.
    You get your lift and one of the springs breaks, since its a aftermarket part it wont be covered under your toyota warranty.
    If you have a issue with the TSS system with a lift, the dealer will say its because of the lift without checking it out unless you pay for the checkout.
    If you install the lift and end up with a radio problem, they can not and will not blame the lift on it and will fix under warranty.
    CalcityRenegade likes this.
  3. Oct 5, 2021 at 1:13 PM
    Crosbaugh
    Crosbaugh Well-Known Member
    In order to void your warranty, they must prove that the modification is what caused the issue. Technically, you're in good shape then, but it's a much different matter when you have to fight them and you need the truck for transportation. Keep the lift under 3 inches to avoid most issues.
  4. Oct 5, 2021 at 1:14 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I mean, if you just want to level the front for the aesthetics, you can do a spacer lift for very little money and it won't hurt your truck (despite what you might hear to the contrary) lol. You do not have to do a full suspension swap to bring the front up by an inch.
  5. Oct 5, 2021 at 1:14 PM
    5nahalf
    Erik
    Minnesota
    This is a key thing. Even if you know the issue your having is not caused by the lift, the hassle and expense of trying to get it covered is often not even worth fighting.
  6. Oct 5, 2021 at 1:15 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    @5nahalf summed it up perfectly. Also consider that it is common for the driver side needle bearing to cause a vibration after lifting the truck. Remedy for that is removing the bushing and installing a sleeve (ECGS Bushing).
    5nahalf likes this.
  7. Oct 5, 2021 at 1:20 PM
    thomsen3
    2021 TRD Sport
    https://www.extremeterrain.com/rough-country-2-leveling-kit-0519-6lug-tacoma.html
    Something like this is what I was thinking. Is this what you mean when you say spacer lift?
  8. Oct 5, 2021 at 1:24 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
  9. Oct 5, 2021 at 1:55 PM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Seeing the truck is new keep away from any lift for 3 years or until your warranties are over to save you headaches with Toyota. Other wise you will be faced with the problems mentioned earlier about dealer blaming it on the lift. It's up to you. Just saying.
    thomsen3[OP] likes this.
  10. Oct 5, 2021 at 1:57 PM
    5nahalf
    Erik
    Minnesota
    You can also get the factory lift kit, it will be covered under warranty if installed by the dealer. Its not a great kit for the money, but at least you'll keep the warranty intact.
    Warranty on the OEM kit is 3 year 36k miles when put on a new truck, 1 year 12k miles on a used truck.
  11. Oct 5, 2021 at 1:57 PM
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
    cosmic65charlie likes this.
  12. Oct 5, 2021 at 1:58 PM
    TacoPacific
    TacoPacific Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    You could look at the Toyota TRD Performance Lift kit.
    Basically a 2 and 1, using a riser for the rear.
    they swap your grille for a Pro style (all black letters) grill and you get re-valves Bilstein shocks with TRD graphics. And they swap front camera and radar locations to keep the TSS working (allegedly).
    I have the kit; it’s dynamite, but expensive for what it is.
    Good road feel, stops most brake dive when braking too!
    Huge thread here - https://www.tacomaworld.com/threads/toyota-trd-oem-lift-kit.695620/
  13. Oct 5, 2021 at 1:59 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Lots of dealers sell TRD suspension components. To completely rule out any chances of not being covered buy the parts from your dealer and have them do the install. Yes it’s going to cost you but they might do some price matching on the struts if you show them a cheaper online price.
  14. Oct 5, 2021 at 2:03 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I've heard that leveling does not void warranty, but switching out the shocks does.
    I think its all up to toyota and what they decide
  15. Oct 5, 2021 at 2:07 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    The radio problems in these trucks is not fixable in the first place. I gave up after the warranty head replacement was a piece of shit too.
  16. Oct 5, 2021 at 2:08 PM
    5nahalf
    Erik
    Minnesota
    Also true, I replaced my radio after my XM trial ended.
  17. Oct 5, 2021 at 2:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Here is free legal advice:
    https://www.findlaw.com/consumer/consumer-transactions/what-will-void-a-warranty-.htm
    l.
    One key thing stated in that article is that you need to read your warranty if you really care about this issue. I bet few if any people on here have read it. I have not.
    Regardless of the laws it really comes down to a judgement call of someone at Toyota, because litigating is not likely have a large ROI unless it is a class action lawsuit being financed by someone with deep pockets.
  18. Oct 5, 2021 at 2:42 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    I went with a leveling kit when my truck was practically new and it rode the same as it did before. Spacers are good as a cheap upgrade. If you plan on doing any significant off-roading I would stay away from a spacer lift. I do not like how soft the suspension is on the Sport so I will be going with 5100's in the near future.
  19. Oct 5, 2021 at 3:06 PM
    gudujarlson
    Minnesota
    I think I understand what you are trying to say, but this is a bit misleading. If the part is warrantied by Toyota, I assume it is still warrantied after being removed and then reinstalled on my truck (or another truck?). I think what you are trying to say is that replacing one part of the truck with a non-OEM part does not void the warranty for the entire truck. Non-automobile warranties might work that way but automobile warranties don’t typically work that way.
  20. Oct 5, 2021 at 3:10 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    TRD lift, dealer installed. Full warranty.
    TacoPacific and Fedup13 like this.
