Leveling Kit Questions on a 2nd Gen
Discussion in 'Suspension' started by mrobey442, Mar 25, 2010.
  1. Mar 25, 2010 at 2:08 PM
    mrobey442
    mrobey442 [OP] Well-Known Member
    Little Rock, AR
    09 Access Cab TRD 4x4
    smoked out tails, a few avs parts, and BHLM, Alpine Head unit, 2 12 Directed Comp subs, 1200 directed class D amp, Blackhand Cap, besttop
    I am debating getting a 2 - 2.5 leveling kit for my 2009 access cab TRD to fit a bit larger tires. Kinda wanting to get some advice on multiple things, i am low on cash and wanting to save a bit of cash. Should i go with the leveling kit or save up and get a full suspension lift, i am not wanting to go extreme with tire size since this truck sees tons of highway miles. Also how large of a tire could i fit without rubbing on the 2.5 leveling kit?
  2. Mar 25, 2010 at 2:29 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    from what i hear stay away from em, but they seem ok to me..do a seach for them
  3. Mar 25, 2010 at 2:31 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
    best bet is a full suspension kit. i have a leveling kit on mine and a friend who has full suspension. his is alot smoother and will probably last longer.
    the spacers puts more stress on the shocks than normal.
    also i have 33x12.5 on mine with minor rubbing.
  4. Mar 25, 2010 at 2:54 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    First I'd say go full coilovers, but if you just want a level kit go with the 2", a 2.5" will make you nose-high (unless you like that look). Also, 32's will fit without a lift and look good with a lift. 33's run the risk of some minor rubbing and some minor fender trimming will likely be in order.
    Run a search or two on here, there are lots of pics with Tacos running 2", 2.5", and 3" lifts/levels with 32s and 33s.
    Good luck!
  5. Mar 25, 2010 at 5:37 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    1.75" will level you out if you have the non tsb rear springs. with the tsb springs you can go 2.5" to level it out.
  6. Mar 26, 2010 at 6:50 AM
    mrobey442
    Little Rock, AR
    Ok thanks for the input, I think what i am going to do is the 2.5 and run 32's in the truck for now and then switch to a full suspension set up once i make some money.
  7. Mar 26, 2010 at 6:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Good plan!;)
  8. Mar 26, 2010 at 11:13 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    just get a spacer lift if your low on cash! thats what i did!
  9. Mar 26, 2010 at 11:14 AM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    I did mine while on a student budget-
    Works awesome, looks good, and im running 33" baja claws
  10. Mar 26, 2010 at 5:36 PM
    mrobey442
    Little Rock, AR
    I had always been told to stay away from spacer lifts, due to odd noises and handling changes. Are those issues somewhat true or just BS for those of you with the spacer lifts?
  11. Mar 26, 2010 at 5:45 PM
    TacoSupreem
    Hayden
    Kentucky
    I had a spacer lift when I first got the truck mostly because I wanted to keep the suspension I had just paid extra for(trd or) intact. It worked just fine for everyday driving and mild offroading. I didn't experience any vibes or noises. Was just a little stiff!
  12. Mar 26, 2010 at 5:53 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    i'm happy with mine no vibes, noises, etc... either i added the one inch blocks with mine perfectly level
  13. Mar 26, 2010 at 6:02 PM
    ab1984
    ab1984 Member
    sylmar ca
    06 prerunner, access cab, TRD off road,silver
    3" spacer lift, 32" BFG all-terrains, homemade ram-air intake, DTR lights mod,blacked out billet grille, black westin bullbar, debadged, color matched grill surround, pro comp 7089's
    i had just the 2.5" on mine and it sat kinda high in the front so i added 1" blocks in the rear and it sits pretty level, maybe about 1/4" higher in the rear. i fit 265/75/16 with the stock wheels and no rubbing. if you wanna run 285's you'll have to get wider rims and might have to trim some plastic in your wheel wells.
  14. Mar 26, 2010 at 10:09 PM
    mrobey442
    Little Rock, AR
    i thought about adding wheel spacers for 285s to hopefully avoid the rubbing, would that help?
  15. Mar 26, 2010 at 10:21 PM
    JCMINIS
    JCMINIS Well-Known Member
    Old fort NC
    07 sport,white 4x4,SR5
    Custom fr bumper,2.5 HBS front lift,rear TSB,K&N
    I have stock steelies,with 2.5 level and tsb with 285's. Zero rub, although I have a custom front bumper.Not sure where others rub.
  16. Mar 26, 2010 at 10:47 PM
    trdtrav
    trdtrav Member
    dumont, mn
    07 tacoma trd
    k&n cold air intake, trd cat back exhaust
    I have an 06 TRD double cab, i just put a 2 1/4 inch pro comp strut spacer in the front and a toytec 2" add a leaf in the rear with 265/75/16 interco trxus mt's. The ride is a little more firm in the front and rides more like a truck in the rear than it did stock. Plus it doesn't bottom out like it used to when i have my portable fish house and gear in the back! It is still lower in the front than the rear, but for now it works great. No rubbing issues.:)
  17. Aug 29, 2011 at 3:46 PM
    JJ5685
    JJ5685 Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    has anybody tried 3" in front and 1" in rear. I think itll be about perfect level. I just ordered and hope i didnt make a mistake and its nose high
  18. Aug 29, 2011 at 3:53 PM
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    I have a 3" spacer lift in the front and I haven't had any problems with it. I'm in the woods a lot (hunting), so mild offroading and the ride's fine. I started out with 1.5" blocks in the rear and ended up taking them out because it was a little higher in the rear. Now it sits a little nose high but I love it :D And I've got 285's, just took off the mudflaps and cut a very little bit of plastic and now no rubbing.
    And JJ5685, I think you should be about level
  19. Aug 29, 2011 at 4:00 PM
    JJ5685
    NC
    thanks, now i can quit worrying that i made a wrong purchase
  20. Aug 29, 2011 at 4:03 PM
    GatorComa
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    Yeah I think you should be good. With the 1.5" rear blocks, my truck was almost level, just a little bit high in the rear, but not much at all, and with stock rear it's just a little lower in the back
