Leveling kit 2008 double cab 4x4?
Discussion in 'Suspension' started by Terrydw123, Mar 15, 2010.
  1. Mar 15, 2010 at 1:23 PM
    Terrydw123
    Terrydw123 [OP] Member
    San Diego, Ca
    08 4X4 TRD Sport
    2 inch leveling kit, BFG all-terrain, weather tech floor mats, ipod adapter, AFE filter.
    Anyone have any pics, suggestions, tire sizes, ride, etc. I'm considering doing a leveling kit because I don't want to put a lift but, I wish the truck was more level. Also I just put 265/70R17 BFG all terrains on the truck. I'm afraid they would look too small. Any tips would be helpfull. Thanks
  2. Mar 15, 2010 at 3:31 PM
    20Tacoma10
    20Tacoma10 Member
    Marc
    Santa Maria, CA
    2010 Double Cab 4X4 TRD Sport
    Magnaflow cat back, K&N drop in, 3"x1" Truxxx lift & level kit, eagle alloy 079's with goodyear wrangler silent armor 265 70 17
  3. Mar 15, 2010 at 10:21 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Your tire size will look perfect.
  4. Mar 15, 2010 at 10:25 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I have the 2 inch Ready lift leveing kit (front), 1 inch block rear. Stock 265/70R16 size Nitto's. Looks good, rides good.
  5. Mar 16, 2010 at 10:47 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    5100 on the front w/ aftermarket coil springs - eibach. Set the shocks at 0 or .85 and you will get between 1.6 and 2.5 in. lift in the front.
    Get the TSB done on the rear and you will be real close to level. Will not have to worry w/ aligments, UCA, and all of the other stuff that comes with lifting to high.
  6. Mar 16, 2010 at 10:59 AM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    ^^ what he said.
    I put 5100's on my truck last week. Looks damn near level.
  7. Jun 5, 2010 at 12:47 PM
    tenntaco
    tenntaco Member
    TN
    07 Tacoma 4x4 dbl cab
    Ready Lift 2.75 front,1 in. rear.Tires are 285/70/17
    [​IMG] Ride is alot more rough and wheel noise but satisfied
  8. Jun 5, 2010 at 2:41 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i put bilstein 5100's all around, got the TSB rear leafs and set the fronts at .85" it now has the stock rake, and rides great and was very cheap. its not really a lift, rather an upgrade.
  9. Jun 5, 2010 at 2:49 PM
    michaelmad21
    michaelmad21 Well-Known Member
    Michael
    El Paso, Tx
    I just added a 3inch spacer in the front did some trimming and put some 285/70/17's love the look!! Little rubbing on a fulllock but nothing big [​IMG]
