Let's see your frugal DIY mods!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Nov 24, 2013.
  1. Apr 9, 2016 at 12:18 PM
    #2181
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good looking headache rack. Nice job!
  2. Apr 16, 2016 at 12:20 PM
    #2182
    Spunky
    Spunky Well-Known Member
    Dean
    Minnesota
    2015 blue
    None yet
    I wanted to lock my tailgate when it if packed for travel. This is my 2nd Prototype. The final is next waffling between aluminum or stainless steel
  3. Apr 16, 2016 at 6:48 PM
    #2183
    Fattony1218
    Fattony1218 Active Member
    Tony
    Hoffman Estates, IL
    2019 TRD Off-Road DCSB
    None...yet!
    uploadfromtaptalk1460857688265.jpg custom made power tailgate lock!
    Pabloeeto and Garfish307 like this.
  4. Apr 16, 2016 at 7:39 PM
    #2184
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  5. Apr 25, 2016 at 7:36 PM
    #2185
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Not a modification to the truck per say but something to use with the truck.
    I do a lot of fly fishing and spend a good bit of time gearing up and down in the dark. This is perfect for those times since I can clamp it on to something and aim it and have a buncha light (and it supplements the bed lights well)
    2065DBE7-D40C-4053-8A8C-C5EB6C29791A_zps_b5f602b7b7aefbb3d984bde60e1f3deaf7ffef22.jpg
    Clamp on 12v LED Spot light. Plugs into the 12v outlet in the bed cubby.
    Spare LED pod, 3$ spring clamp, old junk extension cord, 12v plug from a broken car charger, and 3$ interrupter style inline switch.
    I need to re-egingeer the way the light is attached to the clamp still to make it more adjustable.
  6. Apr 25, 2016 at 7:51 PM
    #2186
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    Built a removable camping platform around 2 weeks ago, holds atleast 300lbs (me:205lbs, gf:90lbs). Put carpet padding (5/8') and outdoor carpet on it recently. In total, i spend under $250 on the entire project (including buying a chisel set and saw blades). Im not quite sure how much it weights, probably close to 200lbs fully assembled and closer to 300 when the storage compartment is fully loaded.
    Its out of the truck right now, im going to stain and water proof it sometime this week.
  7. May 3, 2016 at 2:24 AM
    #2187
    LUSETACO
    LUSETACO [OP] Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Well known mod but frugal nonetheless. Ripped out the giant plastic "organizers" from behind the seat. Much more room and lost some weight. I splurged and bought a roll of shelf liner for the bottom for $1. :D
    I've had these cheapo pedals forever. Finally came in useful after my clutch pedal pad disintegrated. I must say I like having these a lot better than stock.
    And stickers! They're cheap! :D
    Also added some more cheapo LED lights to the interior and scored some projector headlights off CL.
    228b73f1-a535-41d8-a9df-026e2e1af6df_zps_fb962741473c266a467404030de12866b04390d7.jpg
    0C3D323D-2622-4131-BA6B-EB8127CFD9FF_zps_7437a25528e3c09c5610779409ebb6d1b6c4bd23.jpg
    This one is over the top cheezy but I hated not having my outside thermometer anymore. Picked up an indoor/outdoor one at Walmart for $10. Not pretty but it gets the job done. Also found a slick way to mount my radar detector by just removing the suction cups and sliding the bracket under the overhead console.
    5E03F1D5-0B17-462A-9DDD-7EA6658690F9_zps_1b6b4acb43500f8e14a3250a8e8636d645925be3.jpg
    Keep the mods coming!!!! :D
    3274ECEA-578A-43F2-86BF-D908C585B61A_zps_67c2ea520919506e7d5790528f68361bb5949206.jpg
  8. May 3, 2016 at 4:25 PM
    #2188
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Whipped this up this evening.
    9CDF24D9-861C-4B6C-B9B4-FC56511D16A4_zps_3305eb462788b41b14742da03833f5fbd5f3d3b5.jpg
  9. May 3, 2016 at 5:33 PM
    #2189
    stokka
    stokka Well-Known Member
    British Columbia
    2015 DCLB 4x4 SR5
    Nicely done! Very professional, excellent job ERMB.
    Did you have rails on your cap or it is DIY too?
  10. May 3, 2016 at 5:39 PM
    #2190
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Thanks man! I added the rails, but I went back and forth on whether to just use the unistrut for those too but I opted for a name brand one on the off chance i want to go back to something else at a later point. I do plan on adding unistrut to the interior of the cap so i can attach things from the ceiling too.
    stokka[QUOTED] and Blackout14 like this.
  11. Jun 22, 2016 at 6:37 AM
    #2191
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I've had my maglight in the same place for about 5 years. Even under heavy braking situations it has not budged so far. No rattles from it moving around either.
    You have be careful when you position it or else you can place it between the seat and center console. If you do that then the center console will become scratched over time.
    Cmurder likes this.
  12. Jun 22, 2016 at 7:20 AM
    #2192
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Oh, hello frugal thread. :wave:
    Pistol Pete, buzzkill911 and ERMB like this.
  13. Aug 12, 2016 at 6:38 PM
    #2193
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Thanks, now I can re-use the mat from my Z71.
  14. Aug 12, 2016 at 6:47 PM
    #2194
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh man! I haven't heard from this thread in awhile.
  15. Aug 20, 2016 at 12:06 PM
    #2195
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Cup holder for my big mod cup holder (LOL) to hold my hydra flask .Made from 3in to 4in pvc pipe adapter and epoxied a 4in piece of pvc.
    Keeping thread alive ...lol
  16. Aug 20, 2016 at 7:02 PM
    #2196
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    I did something similar the other day... I was just much lazier than you lol
    Bottle pro from Amazon
    mrlee and hemitruk[QUOTED] like this.
  17. Aug 20, 2016 at 8:10 PM
    #2197
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea I had that too but put on silicon skin cover cause always dropping mine lol. The bottle pro was perfect . But me too clumsy lol....
    I had to use the adapters that came with bottle pro cause of my big cup holder mod .Was loose because of the adapters so I just epoxied adapters together and was solid.
  18. Aug 20, 2016 at 8:16 PM
    #2198
    nazlax10
    David
    Woodstock, GA
    Do you mean a cover on your hydro flask? If so details please.
    Edit: I found them lol
  19. Aug 20, 2016 at 8:23 PM
    #2199
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea its a cover made of silicon . Only problem is its a little too big for the bottle pro . Its called hydroskins .This one is for the 40oz flask
  20. Aug 21, 2016 at 2:03 PM
    #2200
    taco07
    taco07 Well-Known Member
    Midland, NC
    2014 TRD OR AC Pyrite Mica
    Leer 100XR, 2016 OR Wheels
    Any idea if this will work with the 32oz yeti cup
