Less expensive brake controller
Discussion in 'Towing' started by HawkShot99, Mar 9, 2020.
  1. Mar 9, 2020 at 2:15 PM
    HawkShot99
    HawkShot99 [OP] Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I am about to get a enclosed trailer with brakes, so I need a controller. Every where I read about the tekonsha p3 being a great controller, and I'm sure it is. However I will most likely be trading in the Tacoma this summer for a full sized, and most of them come with a built in controller. There are many controllers out for 1/3 the price as the tekonsha, are any of them a good basic controller that I'll be happy with for the time being?
    What makes the tekonsha so great?
  2. Mar 9, 2020 at 7:02 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Try Craigslist? Just looked in my area. P2's btwn $30-$50. P3's $50-$75. I've got a P@. Had it for years on different trucks.
  3. Mar 17, 2020 at 3:37 PM
    Thunder chicken
    Thunder chicken Well-Known Member
    NW Ontario
    ‘18 access cab manual
    I have a "Tekonsha 9030 - Voyager Brake Controller"
    it works fine enough and should be cheaper than the p3. i believe i paid around $100 (cdn) at our local expensive auto parts store cause i needed one 'now'.
    HawkShot99[OP] likes this.
  4. Mar 17, 2020 at 3:49 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I have the Primus IQ. It serves me just as well as a P3, just not as good looking, and without the memory bit for running multiple trailers.
    https://www.amazon.com/dp/B001P11SCM/ref=cm_sw_r_apa_i_SgvCEbKG2CNSA
    There are two essential features that you absolutely need and one additional thing that is nice:
    You need one that is truly proportional (accelerometer built into the circuitry), and you need one with a wide range of mounting positions. Cheap proportionals have a relatively narrow range of mounting positions. The P3 can be mounted anywhere from level to vertical, which is one of the reasons why it's so pricey.
    To find one with a halfway decent mounting range and accelerometer, it's hard to find for under 50 bucks.
    The luxury bit: Tekonsha sells a wiring harness that is plug and play for the tacomas, compatible with most of their controllers. No wire splicing needed.
  5. Mar 18, 2020 at 5:36 AM
    Indy
    Indy Master of all I survey.
    People have been towing for decades and a tiny tiny percentage of them have used the most expensive controllers. Its definitely not a requirement.
  6. Mar 18, 2020 at 7:16 AM
    RVguy
    RVguy Member
    2015 Tacoma
    When I sell a camper, and a brake control is needed, we install the TEKONSHA.
  7. May 10, 2020 at 9:53 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    get the one that WONT flat spot the tires
    in an urgent stop
    ive seen many that will work on the average mundane stoplite stop
    good luck
