Les Schwab brakes suck. Now what?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by T-Dozzer, Jan 9, 2022.
  1. Jan 9, 2022 at 9:17 PM
    T-Dozzer
    T-Dozzer [OP] Well-Known Member
    Long story short-
    Gen 2 taco. Toyota brakes weren't terrible, but Les Schwab has toiled over both front & rear brakes & they still suck. I think its the quality of parts. Both front/rear have lots of life left, but the braking power leaves a lot to be desired. Do I eventually switch to OEM, get a second look at them or upgrade? Just dropped about $7k on it so Ide rarher not get too carried away.
  2. Jan 9, 2022 at 10:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just go back to OEM Brake pads and shoes. They work very well IMO.
    TomTwo, tacoman45, vtown and 2 others like this.
  3. Jan 9, 2022 at 10:47 PM
    TacoTuesday1
    FL
    stock brake sizing: StopTech cryo slotted rotors w/ TRD Ceramic pads or that one race pad company, I forget the name
    or going bigger like Tundra MC + 4runner calipers + whatever else
    some people let the brakes slowly bed themselves in first and then perform an actual bed in procedure to help. As well as knowing fluid is good/bled and possibly upgrading to SS lines.
    But if the pads and rotors are low quality then they're low quality and nothing else is gonna make up for it.
    They make money on parts and labor. If they charged you $200 for parts, they bought them for $100.
    If they charged $300 out the door, they are going to lower the price of parts as much as they can, to keep the profit. Regardless of what bottom of the barrel shit they might give you.
    Les Schwab is not a specialist, dealership, or DIY'er who knows what they're doing. That DIY'er could be you, your friend, potentially anyone.
    they're not gonna charge you $300, spend $290 on high quality parts, and pay themselves $10 for hours of labor to do the job.
    Having done brakes many times and knowing the prices of them, I always marveled at how a friend's uncle would do his brakes for $60. Unless he paid for it. Because that's literally less than what parts cost.
    I understand shops get better pricing through WorldPac and IMC. I have used these programs before. But still. It only saves so much and high quality comes with a price.
    I don't know what they used. 2g Taco has a reputation for stock brakes warping under any significant (or even regular) use.
    I'm not using Centric High Carbon Premium rotors, which they advertise as being G3500 or G4000 metallurgy.
    But if someone told me they were using Centric C-Tek Standard regular rotors on a Tacoma (lower metallurgy, not high carbon) it would sound like a mistake, even though it technically "fits"
    Some shops also use a lathe. The rotor may be within minimum spec. Less metal grinded off = less heatsink dissipation.
    I put my old stock rotors on a lathe to fix the warp with a fresh surface. It came back in a week.
    Current Stoptechs haven't done it. Even after wheeling and mountain towing.
    T-Dozzer[OP] likes this.
  4. Jan 10, 2022 at 12:21 AM
    FishWolf
    FishWolf Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Local Toyota dealership actually went through my front brakes, new calipers, rotors etc with OEM parts for $500, didnt seem to bad, Les Schwab is crazy, they wanted something like $600 more than Discount Tire for a set of 4 Nitto Exo Grappler tires
  5. Jan 10, 2022 at 12:45 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Air in system, maybe
    TomTwo, tacoman45 and ZMan2k2 like this.
  6. Jan 10, 2022 at 10:13 AM
    T-Dozzer
    They did the front & rear at seperate times. Both times, I had to go back several times to get it adjusted. They said something along the lines of Taco's are tricky to adjust with rotors in front & drums in the rear. They bled the lines.
  7. Jan 10, 2022 at 10:18 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    There are 2 different OEM pads available for the 2nd gen (or at least there were 5 or so years ago when I replaced mine). The pricier ones seem to be what comes stock -- the cheaper ones seem to be available to compete with other aftermarket options. I went for the pricier ones, so no experience with the cheaper ones. My TRD OR would stop on a dime if I stepped hard on the brakes.
  8. Jan 10, 2022 at 10:20 AM
    DG92071
    DG92071 Well-Known Member
    LMAO
  9. Jan 10, 2022 at 11:17 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    My Tacoma was by far the easiest brake job I've done in a long time. Especially if you have a TRD OR since the booster makes bleeding the brakes very simple w no pumping the pedal needed. Drums are a little more complicated but even still, super simple compared to other vehicles.
    If you end up swapping the front pads out, go with a set of the original OEM Toyota ADVICS pads or grab a set of Akebonos. Did you swap out the rotors too?
  10. Jan 10, 2022 at 11:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    Surely that wasn't the brakes alone? You at least got an oil change too, right?
    They'd say your open septic tank smells good too.
    When a tech at a big box store blames the uniqueness of a vehicle, 98.74% of the time it means the tech is the problem.
    Jojee117 likes this.
  11. Jan 10, 2022 at 1:07 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Surprised no one posted this thread yet: https://www.tacomaworld.com/threads/brake-upgrade-stoptech-rotors-trd-performance-pads.523829/
    Short of an expensive and more complicated upgrade in the size of the brakes the above is probably the best you're gonna get with the stock brake system. My truck was terrible when I bought it. I honestly didn't understand how there was so much love for these trucks when the brakes are GARBAGE. Did the upgrade outlined in the thread above and it was a massive improvement. I'd say they're on par with a regular, modern vehicle now. Nothing special, but perfectly suitable - this should have been how the truck came from the factory.
  12. Jan 10, 2022 at 1:46 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Jeez... and here I am frustrated with how strong and grabby my brakes on my TRD OR are.
    I've had extremely good luck with Wagner thermoquiet ceramics. They are like $30 on Amazon.
    tacoman45 likes this.
  13. Jan 10, 2022 at 1:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What year is your truck? They may need to use the tool to cycle the ABS module.
  14. Jan 10, 2022 at 1:56 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Went with StopTech Big Brake Kit. Will do the master cylinder some time next year.
  15. Jan 10, 2022 at 1:56 PM
    clenkeit
    Colin
    Lakewood, CA
    Maybe I'm just used to sports cars and have high standards? Although, the '99 F150 I had prior to my Tacoma had way better brakes than my Tacoma. But it also wasn't lifted with larger/heavier tires.
  16. Jan 10, 2022 at 1:57 PM
    T-Dozzer
    Its a 2006
  17. Jan 10, 2022 at 2:00 PM
    tacoman45
    Orygun
    I agree - my TRD OR brakes are nearly as grabby as my M3 & my FIL's Carerra.
    Maybe it's a Sport thing. The TRD OR's do use a hydraulic brake booster to make A-TRAC possible whereas the Sports & other non OR trims use a simple vacuum system for the lower demand of a TRAC-only system. Several threads on here about the differences between the two
  18. Jan 10, 2022 at 2:02 PM
    T-Dozzer
    The $$ was on other non essential stuff. Cuz Im a dummy.
    They had 3 or 4 techs working in it. I even called the manager & he joined in. Needless to say I was pretty annoyed.
  19. Jan 10, 2022 at 2:46 PM
    ZColorado
    13 DCSB OR 6MT
    I'd love for my TRD OR to have brakes like my WRX (calling it a sports car is mildly generous) My WRX has much more variable pedal then my truck. My truck chirps my 35s if I am quick on the pedal at all. It goes from squish to firm grab in about 2mm
  20. Jan 10, 2022 at 3:16 PM
    T-Dozzer
    Yes. The shysters did the rotors as well.
