Left Foot High Beam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Oct 4, 2020.
  1. Oct 6, 2020 at 3:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I started driving in the 1970's and I've owned more vehicles with the dimmer switch on the floor than the column. I just don't see an advantage either way. I could operate a column mounted dimmer switch just fine with a cigar in the hand, or put it in my mouth if I couldn't. The only possible advantage to having it on the floor is to make it easier to replace if it does go bad. And I've had to replace a couple of bad ones over the years. I've never had a column mounted dimmer switch go bad.
  2. Oct 24, 2020 at 6:54 AM
    mgord
    mgord [OP] Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    I started poking around at the wiring in the truck to try and find the high-beam lines.
    Below are a couple of pictures and a wiring diagram for the body ecu.
    Would be great of someone could point out the terminal / ecu / place where the wires are located? Was thinking of just disconnecting and see when the lights no longer worked but thought I'd try this first...
    Specifically the "Body ECU".
    Left / bottom of drivers side.
    Fuse box left of the steering wheel.
  3. Oct 24, 2020 at 7:11 AM
    DG92071
    DG92071 Well-Known Member
    The floor mounted dimmer switch could be mounted under the dead pedal, above the floor, poking through the dead pedal. Just a thought.
  4. Oct 24, 2020 at 7:16 AM
    mgord
    Harrisburg, PA
    07 TRD
    Excellent idea! Hadn't gotten that far but will do that.
    DG92071[QUOTED] likes this.
  5. Oct 24, 2020 at 7:20 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Sounds awesome! My '58 Bug had the foot switch!
  6. Oct 24, 2020 at 7:36 AM
    unclebuck
    unclebuck Well-Known Member
    2nd Gen Taco
    Stock
    I too miss the foot switch, so I will keep an eye on this thread!
    I imagine the biggest reason it was moved to the stalk was to accommodate drivers with disabilities.
  7. Oct 24, 2020 at 9:15 AM
    Muddinfun
    Muddinfun Well-Known Member
    I’m 95% sure this is the red/green wire. It’s on the back side. It would probably be easier to find the wire where it goes up to the steering column.
  8. Oct 24, 2020 at 2:10 PM
    mgord
    Harrisburg, PA
    07 TRD
    So if I'm thinking about this correctly the HF or red/white would go to the center post of the switch and the HU red/green would go to either left or right side. Doesn't matter since it switches between. This way the switch would not be active unless the low beams were on. Sound correct?
  9. Oct 24, 2020 at 2:37 PM
    medic2230
    Murph
    Bama! Roll Tide
    What I was thinking. Mount to the upper underside of the dead pedal. No holes through the cab at all that way.
    I had a ‘79 CJ 7 with the switch in the floor. Was on the side of a mountain one night out in the country. Hit the high beams and everything went out. Ended up pulling over and not hitting anything and messed with it till I got it working again. Good times. Lol
    D2. and DG92071[QUOTED] like this.
  10. Oct 24, 2020 at 4:05 PM
    Muddinfun
    No. The red/white wire is some kind of Voodoo black magic hocus pocus shit. It gets grounded on the flash so the headlights come on when you flash with the headlight switch turned off. Don’t do anything with red/white wire. Are we clear on that?
    The only thing you want to do is ground the red/green wire for high beams and have the red/green wire not connected to ground for low beam.
  11. Oct 24, 2020 at 4:20 PM
    mgord
    Harrisburg, PA
    07 TRD
    Ok. So the red/green goes to the center post and a ground (to the frame) is on the left or right on the switch. Stretching my knowledge on electricity. Wouldn't grounding the red/green blow a fuse if it is hot?
  12. Oct 24, 2020 at 4:30 PM
    Muddinfun
    Yes, that is what you need to do. The red/green wire is only a signal for the ECU to let it know that it should turn on the high beams. It’s like if someone knocks on your front door, it’s a signal for you to open the door. They haven’t done anything to open the door. They just sent the signal.
  13. Oct 24, 2020 at 4:35 PM
    Muddinfun
    Also, if you’re following the red/green wire up to the steering column, make sure the red/green wire you are following actually goes to the headlight switch. There may or may not be other red/green wires that go to something else.
    DG92071 likes this.
  14. Nov 8, 2020 at 6:36 AM
    mgord
    Harrisburg, PA
    07 TRD
    So there are 2 clusters of wire going to the steering column. One goes to the passenger side and up (I'm thinking the instrument cluster). The other goes to the fuse panel. I've found a green/red wire on the one going to the instrument cluster. Picture below. Seem to be green red to me and not red green. Same thing? I'm thinking horn relay.
  15. Nov 26, 2020 at 6:09 PM
    #35
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    Haha, I came here to say the same thing.
    How's this coming along?
  16. Nov 27, 2020 at 4:10 AM
    #36
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Any updates on how it's going??
  17. Nov 30, 2020 at 10:51 AM
    #37
    mgord
    Harrisburg, PA
    07 TRD
    Got home last weekend and catching up on house stuff. Going to be a couple of weeks before I get back to the left foot high beams. Stay tuned....
  18. Jan 5, 2021 at 7:46 PM
    #38
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    I am also a big fan of the floor mounted dimmer switch. I'm waiting patiently for someone to positively identify the correct wires to tap. (@caribe makaira).
    Until then, i've started a prototype using the dead pedal, without drilling thru the floor. Works great so far, just need to wire it in.
    20210105_192148.jpg 20210105_192023.jpg 20210105_191912.jpg 20210105_191841.jpg
  19. Jan 5, 2021 at 8:00 PM
    #39
    caribe makaira
    Caribbean, Puerto Rico
    C11 is connector to turn/headlight stalk, under the steering covers (bottom)
  20. Jan 5, 2021 at 8:02 PM
    #40
    Lthompson
    Lthompson Well-Known Member
    i gotta learn not to rush my reading.. I spent half my time trying to figure out why you were shifting with your left hand, holding a cigar, and steering with your right..
