left e brake on driving down the interstate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DSMissed, Aug 25, 2010.
  1. Aug 25, 2010 at 7:29 AM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    I couldn't find where anyone else had done this (I'm an idiot sometimes) so I thought I'd post it up. I left my e brake on for about 5 miles of freeway. My brakes still work and the e brake works a little, but what damage did I do? Should I replace the shoes, or did I probably just stretch the cable? I don't know much about drum brakes, do they squeal at you when they are worn out? Is there a link for how to adjust the e brake cable? Thanks.
  2. Aug 25, 2010 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont think you did any damage. I have driven MILES with the E-brake on (intentionally), and the worst that can happen, is you glaze the drums. If that happens, you will notice reduced stopping power from the rear brakes. Does the parking brake still hold the truck still when parked?
  3. Aug 25, 2010 at 7:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your cable is probably fine. It's the shoes and drum that should be looked at. There is no warning when the shoes wear thin. You should at least inspect the shoes and drums; shoes for thickness and galling, drums for warp and hot spots.
  4. Aug 25, 2010 at 7:40 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    agreed, I dont think you did any irreversible damage. The drum brakes may have holes to check for pad wear. I dont think drum brakes incorporate separate "ebrake" pads, so the drum's pads are the same as the ebrakes iirc. W/ that said, 5 miles worth of minimal brake application due to the ebrake being applied probably wont justify new rear brakes.
    As for a diy on cable adjustment, I havent seen one.
  5. Aug 25, 2010 at 7:40 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Yea i would definitely inspect the brakes but I wouldn't think you did any damage. I did that same thing to a 92 yota I owned and nothing was damaged.
  6. Aug 25, 2010 at 7:55 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2...5 miles isn't too bad, you're probably ok. Just inspect the brakes next opportunity and replace/service parts if necessary.
  7. Aug 25, 2010 at 8:02 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    probably nothing too serious...if the drums looked glazed just swap the pads and you should be fine...if your really worried you could always upgrade to rear discs...:D
    when we were in Cabo San Lucas a few years ago getting ready to do an ATV tour...there was an old school Toyota Hard Body Pickup (looked like a 93-94 4x2)...his e-brake must have been stuck for days...cause when he pulled up to the red light everyone turned around from hearing the rear brakes locked up and squealing like a pig...next thing you know everyone in the bed/cabin of the Yota jumped out and the rear end went up in flames...it could have been the regular drum brakes and/or the e-brake locked up but either way that was 1st time i've seen a vehicle on fire in person...
  8. Aug 25, 2010 at 8:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I did it on an old Corolla I had. Most likely it wore the shoes down until they no longer touched the drum firmly (surprising very little amount of binder to do that) that's why you think you stretched the cable. You'll have to replace shoes sooner, that's most likely all that'll come of it.
    As well as the parking brake being looser, I bet you're brakes feel a little looser than before with more pedal travel before they feel tight. Adjust the rear brakes and that should make both right.
    You can do that by backing up some distant applying/releasing/applying the brakes a lot to make the auto-adjusters adjust them up. OR, just get under there and adjust 'em manually.
  9. Aug 25, 2010 at 9:08 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Hey Chris, just curious why did you ride the e-brake on purpose?
  10. Aug 25, 2010 at 9:18 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    In my truck when I pull away and forget to release the emergency brake it will roll forward/backwards a little then lock up somewhat ..............does your truck not do that?...........or do I just push down too damn hard on the e-brake?
  11. Aug 25, 2010 at 10:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    We had an old beater Volkswagon Golf Deisel, and wanted to see how long before the rear drums wore out, seized, or burned up. We went about 25 miles and the brakes began to smoke at about the 15 mile mark.
  12. Aug 25, 2010 at 11:50 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    I wouldnt say too hard. I mean, the ebrake is supposed to STOP the vehicle ;)
  13. Aug 25, 2010 at 12:26 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's a front wheel drive right? I'd imagine they'd lock up the rear wheels...did you keep them just tight enough the rear wheels wouldn't lock up, at first. Or they were really weak rear brakes? hmmm
  14. Aug 25, 2010 at 12:56 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Awesome info, I do feel alot of slack in the e brake lever and the brake pedal too, I'll try that backing up thing and see if it helps. Thanks!
