left cubby switch panel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Peru4x4, Nov 25, 2018.
  1. Nov 25, 2018 at 1:42 PM
    Peru4x4
    Peru4x4 [OP] Member
    NoCal
    2017 Tacoma trd off road
    does anyone have any suggestions for the left cubby switch panel?? I like Mesos' but not sure he will have time to make more so looking around, thanks.
  2. Nov 25, 2018 at 1:50 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Check out CaliRaisedLED, they make one just for the cubby.
  3. Nov 25, 2018 at 1:52 PM
    Diddymac
    Diddymac Well-Known Member
    David
    Florida
    2017 Tacoma SR5
    Yep that’s the one I have and it looks great
  4. Nov 25, 2018 at 2:12 PM
    Peru4x4
    Peru4x4 [OP] Member
    NoCal
    will do thanks
  5. Nov 25, 2018 at 2:52 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    What configuration are you wanting
    ETsemaj likes this.
  6. Nov 25, 2018 at 3:06 PM
    Peru4x4
    Peru4x4 [OP] Member
    NoCal
    meso I like the cp6.1w
  7. Nov 25, 2018 at 3:08 PM
    MESO
    State of Jefferson
    Those are in stock on my website :)
  8. Nov 25, 2018 at 3:13 PM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Shapeways is where I got mine.
    Peru4x4[OP] and vicali like this.
  9. Nov 25, 2018 at 3:15 PM
    CrabClaw
    CrabClaw Member
    Wyoming
    White 2017 TRD Off Road DCLB, White 2003 TRD Off Road ACLB
    SCS Ray 10 wheels, Leer 100 SQ Topper, rigid lights, OVtune, prinsu racks, SCS ray 10's.
    helix66 and Peru4x4[OP] like this.
  10. Nov 25, 2018 at 4:57 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
  11. Nov 25, 2018 at 5:05 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    781E5210-427C-4023-9BC9-69C111F3E40B.jpg I installed the Curt brake controller with Shapeway panel. Room for additional switch.
    CoastieRon likes this.
  12. Nov 25, 2018 at 5:12 PM
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    Does anyone know how to remove that panel? I just tried trim removal tools and it won’t budge. Do I need to remove that section of the lower dash? Any help would be appreciated.
  13. Nov 25, 2018 at 5:14 PM
    Diddymac
    David
    Florida
    2017 Tacoma SR5
    I just took a flat head and went into the corner and gently pried it and then pulled it out. You don’t need to remove the dash.
    CenCal805[QUOTED] likes this.
  14. Nov 25, 2018 at 5:15 PM
    Diddymac
    David
    Florida
    2017 Tacoma SR5
  15. Nov 25, 2018 at 5:15 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    It's tight and you might need to do the whole lower trim which is basically (1) driver door sill trim, (2) driver kick panel, and (3) lower trim. Should be clips for the first two (so just yank) and 3 screws (low side) plus clips (top side) for the lower trim.
    After the first time I was able to do it from the front but it's tough doing it without damaging the surrounding trim.
  16. Nov 25, 2018 at 5:17 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Gotta take off entire panel under steering column. Pretty easy when u know how. First take off the two doir trim pieces. 3 bolts and pull it off from bottom left corner moving right. Mind the red clips, cuz they need to go back on the panel
  17. Nov 25, 2018 at 5:20 PM
    RBaptist
    Newnan, Ga
    I honestly didn’t need any tools or to remove any panels to Pop it out. Just put your fingers on each side and pull out firmly. Mine popped out that way.
    You could use a plastic putty knife or something as well, but make sure you put some tape around the end of it and on your panel so you don’t scratch it.
  18. Nov 25, 2018 at 5:21 PM
    cruxx
    Huy
    2017 TRD Sport
    If you see that back of it, you’ll realize it wasnt meant to be popped iff that way
  19. Nov 25, 2018 at 5:25 PM
    RBaptist
    Newnan, Ga
    Lol @CrabClaw .... where did you get that custom ‘rear lights’ switch made. Bahahahahahaahahaaha!!!
  20. Nov 25, 2018 at 5:35 PM
    RBaptist
    Newnan, Ga
    To pop the trim piece out (which includes the cubby) it works fine. You’ll have to remove the 4 screws to remove the cubby once it’s out ...but that’s implied.
    Ironically, now that the cubby on mine is gone (replaced with a Redarc) I’ll likely have to take the kick panel off since there’s nothing left to grab onto....
    CenCal805 likes this.
